KO2 265 70r17 tire pressure
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Hankstone, Mar 12, 2016.
  1. Mar 12, 2016 at 12:35 PM
    Hankstone
    Hankstone [OP] Well-Known Member
    2016 Tacoma Sport DCLB
    What tire pressure are u running?
  2. Mar 12, 2016 at 1:11 PM
    mij
    mij Day work
    My 2015 Rav4 with K02's is 58psi on the road adjust for traction off road
  3. Mar 12, 2016 at 1:11 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Do the chalk test.
    T4RFTMFW likes this.
  4. Mar 12, 2016 at 1:19 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    This.
    Nothing else matters.
  5. Mar 12, 2016 at 1:19 PM
    T4RFTMFW
    :bananadead:
    Lawfarin, mello03 and DustStorm4x4 like this.
  6. Mar 12, 2016 at 2:01 PM
    Hankstone
    Its just one line of chaulk across the tire tread, roll forward and adjust pressure so solid line on pavement right?
  7. Mar 12, 2016 at 2:07 PM
    Sbpark
    Sbpark Well-Known Member
    2017 Subaru Outback 2.5i Limited
    40psi on the road.
  8. Mar 12, 2016 at 2:08 PM
    Sbpark
    Huh?!
  9. Mar 12, 2016 at 2:08 PM
    Hankstone
    Someone said do the chalk test... I was just putting what I took that to mean
  10. Mar 12, 2016 at 5:25 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    You can google it. It's pretty simple. One line across the tire. Roll forward for a few rotations, see where the chalk wears. If it wears in the middle, deflate it a little. If it wears on the outside, inflate it a little. Keep adjusting until it wears evenly.
  11. Mar 12, 2016 at 5:27 PM
    JoeRacer302
    JoeRacer302 Well-Known Member
    Joe
    Pasadena, CA
    2016 DCSB OR MT Inferno
    Front: 5100's @ 0.85 Rear: 1/2" spacers 265/75r16 on RAY10
    :proposetoast:
  12. Mar 12, 2016 at 5:29 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    For reference, my 285/75/16s are set at about 33-35psi. In my opinion 40psi in a 265 is way too much. Let alone 58.
  13. Mar 12, 2016 at 5:30 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    If your going to do the chalk method, buy a bottle of contractors chalk.
  14. Mar 12, 2016 at 5:31 PM
    JoeRacer302
    Joe
    Pasadena, CA
    Look up the tire specs for your specific tire. Inflate to your vehicle weight (accounting for weight distribution).
    splitbolt likes this.
  15. Mar 12, 2016 at 5:33 PM
    Sbpark
    I get it now. The reason I questioned the other posters reply because it didn't make sense when I read it. Turned out it had a spelling error which threw me off, which he ended up correcting after my quote.
    Hankstone[OP] likes this.
  16. Mar 12, 2016 at 5:37 PM
    splitbolt
    NW Arkansas
    That's crazy talk.
    Around here, we use PSI to adjust mileage, handling, transverse contact patch that doesn't account for scrub and alignment...anything but weight.
  17. Mar 12, 2016 at 5:39 PM
    JoeRacer302
    Joe
    Pasadena, CA
    Muh'bad :cookiemonster:
  18. Mar 12, 2016 at 5:46 PM
    mosquitoTaco
    mosquitoTaco Has an attractive member
    Anthony
    SouthTennessee
    14' DCSB offroadsport-sold =2005 T4R V8
    Bilstien 5100@ 0, OME 885(+10 mm drivers side spacer for taco lean, 5mm passenger), b110 rears w/ allpro standard leaf pack, wheelers ubolt flip, superbump bump stops, extended brake lines steal braided(front and rear), Dick Cepek extreme country 305/65/17 tires on FN six shooters=17x8, street tires are 285/75/16 duratrac w/FN countersteer type X= 16x8, a healthy cab mount chop, SPC LR UCA's, TC cam tab gussets, Wet okole seat covers, husky x-act fit floor liners, SOS aluminum front skid, SOS mid skid, SOS sliders (bolt on), ECGS bushing for needle bearing, uniden PRO520XL cb. BAMF tailgate antenna mount, 4' firestick, A.R.E. Z series camper top, Factory roof rack, Pioneer avh-5800x head unit. Front and rear anytime cameras, Rear diff. Breather relocate. 42" highlift. Tow straps/All-PRO snatch strap, tow hitch w/D-ring, traction pads, Tacoma bed mat, Rago Fab ditch light brackets with jap special light pods
    I run mine at 35psi in the front and 32psi in the rear if I'm not hauling anything. Seems to be pretty good so far. The dumb ass tire guy that put them on cranked them to 50psi, even after I asked him not to. Needless to say it drove like shit my first time around the block(tires squeeling, and makeing alot of noise) until I adjusted them down. He lost a lot of business that quick.
    Chalk test is the best method though
  19. Mar 12, 2016 at 6:03 PM
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    Kids sidewalk chalk is best.
    33psi front. 31psi back.
    mosquitoTaco likes this.
