Ko2 vs ko2dt
Discussion in 'Wheels & Tires' started by sivillian, Mar 5, 2019.
  1. Mar 5, 2019 at 12:53 PM
    sivillian
    sivillian [OP] Member
    2018 Tacoma off road
    Exhaust and intake.
    Has anyone had experience with the bfg ko2 dt? Ordered a set online thinking they were regular ko2’s and they are the dt model. I know the differences, but has anyone driven them in snow vs the regular ones? If so how did they perform compared to the other ones?
  2. Mar 5, 2019 at 12:57 PM
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
  3. Mar 5, 2019 at 12:58 PM
    sivillian
    Exhaust and intake.
    Confused? Me too.
  4. Mar 5, 2019 at 1:05 PM
    sivillian
    Exhaust and intake.
    Moe2o4, the dt version stands for different tread. Basically a harder rubber compound which makes the tire last longer, but also loses the 3peak snow rating. I need them for snow so I’m curious to see if they’re really that different.
  5. Mar 5, 2019 at 1:07 PM
    moe2o4
    Corey
    Pittsburgh PA
    If you are buying KBro2's for the snow you better look into another tire cause they absolutely suck in the snow let alone all other conditions!
    Paul631, inwood customs and na8rboy like this.
  6. Mar 5, 2019 at 1:08 PM
    Siblue
    Siblue Well-Known Member
    So Cal
    25 Tundra TRD pro
  7. Mar 5, 2019 at 1:48 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    They sound like they are the complete opposite, of what you want.
    Paul631 likes this.
  8. Mar 5, 2019 at 3:12 PM
    sivillian
    Exhaust and intake.
    The size I’m getting is all load E, but there are still two versions of that load size. And moe2o4, what would you suggest?
  9. Mar 5, 2019 at 3:14 PM
    moe2o4
    Corey
    Pittsburgh PA
    Ummmmmm Actual snow tires maybe.....
  10. Mar 5, 2019 at 3:14 PM
    Dirtridercrf250
    Dirtridercrf250 Well-Known Member
    Different compound, I have 87k on mine they wear like iron.
    sivillian[OP] likes this.
  11. Mar 5, 2019 at 3:20 PM
    sivillian
    Exhaust and intake.
    Moe2o4 ok dude. Thanks
  12. Mar 5, 2019 at 4:41 PM
    Dirtridercrf250
    Actual snow tires are good for ice,but lack the performance in deep snow.
  13. Mar 5, 2019 at 4:46 PM
    sivillian
    Exhaust and intake.
    Exactly.
  14. Mar 5, 2019 at 7:23 PM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    found this on Tire Rack (under Description)
    All-Terrain T/A KO2 tires labeled "DT" utilize a different tread compound designed to improve wear in high-torque applications and improved chip and tear resistance in gravel. Tires featuring this compound carry a 50,000-Mile Treadwear Warranty and are NOT branded with the three-peak mountain snowflake symbol. They can be identified by the "DT" branding on the sidewall immediately following the service description, and are labeled on the Specs page and in search results.
    https://www.tirerack.com/tires/tire...eModel=All-Terrain+T/A+KO2&partnum=17SR7KO2V2
  15. Mar 6, 2019 at 6:33 AM
    moe2o4
    Corey
    Pittsburgh PA
    I run a set of Cooper M+S Snow Tires all winter and haven't had any issues in light or deep snow. Truck goes great in either conditions. The Cooper's don't pack snow at all!
  16. Mar 6, 2019 at 6:43 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Ahh yes, this is starting to sound familiar. I looked into it a while back trying to sell one spare KO2 I have kicking around. Other than the 3PMSF its kinda hard to tell them apart - Im not sure most people even know theres a difference
    To answer your question directly, no. I run the 3PMSF version. And for what its worth, I think they are pretty damn good for an AT tire. Yes you will get better traction out of a snow tire (duhh), but thats expensive. You can add a few sandbags over the rear axle and that will help a ton.
    https://www.bfgoodrichtires.com/upload/bfgoodrich/specifications/specs-all-terrain-t-a-ko2.pdf
    Dirtridercrf250 likes this.
