KO2s or Toyo Open Country AT3s?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AMGTRDPRO, Aug 8, 2021.
  1. Aug 9, 2021 at 10:15 AM
    bzzr2
    bzzr2 Well-Known Member
    you could look at more weight potentially meaning thicker sidewalls etc from a durability standpoint if you expect to be off the pavement much.
    i have never been a fan of the KO2 but when it is tire time again if the 34x10.5 are available at a decent price compared to the 255’s i run i would give them a go..
    how is that for a mixed message to not help at all !?!?!?!
  2. Aug 9, 2021 at 10:27 AM
    AMGTRDPRO
    AMGTRDPRO [OP] Well-Known Member
    2021 Lunar Rock TRD PRO
    :duel: I knew it would be like this lol when you go down the rabbit hole with anything really supercharger vs turbo, which tint is better 3M vs Xpel which ceramic coating last longer and don't get me started on which oil is the best you be reading for hours and still be like WTF did I just read ? lol I'm going to just have to commit and see for myself. I do value peoples opinions on this forum being I'M new to the truck world. thanks to all once again
    Junkhead likes this.
  3. Aug 9, 2021 at 11:13 PM
    HoytK9
    HoytK9 Well-Known Member
    Voodoo Blue 2019 TRD Pro
    Snug Top Hi-Liner
    I’ll chime in a bit since I have the KO2s on my Land Cruiser, and the AT3s on my Tacoma. Both were only available as ‘E’ rated tires. I upped one size (taller) from stock on my Land Cruiser, and went with a 295/75/16 on my Tacoma.
    The LC drives remarkably quiet, but it’s to be expected since the SUV has a lot more sound deadening material. Took it off-road in a couple of mild and moderate trails, and it did fantastic. I really cannot complain about the KO2s and love the look of the white lettering.
    Before going to the AT3s (295/75/16s) on my Taco, I briefly ran KM3s in size 285/75/16s. It was way too loud for the road, and I literally took them off in less than 50 miles. The AT3s, were of course much quieter. I would say that it’s slightly louder than the KO2s at highway speeds. My guess is that in water or snow, it will have a slight traction advantage over the BFGs due to the design.
    The price was about the same, so I really don’t think you can go wrong with either. That being said, the TOYO AT3s is the newer tire and may have some advantages for being the latest and greatest.
  4. Aug 9, 2021 at 11:26 PM
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    There’s no need for a E rated tire if you go with the open country at3’s. They come in SL like you’re factory tire.
    You won’t have the loss of power from adding 16lbs of unnecessary unsprung weight to each corner to a truck that is not know for being a powerhouse to begin with.
    DAS Taco and OmahTako like this.
  5. Aug 9, 2021 at 11:37 PM
    HoytK9
    Snug Top Hi-Liner
    Tell me I’m wrong.. but I wasn’t aware there’s an option besides E rated for my size: 295/75/16.
    Nice TRD PRO by the way! We’ve got matching rigs.
  6. Aug 9, 2021 at 11:50 PM
    dfanonymous
    Thanks, it’s less stock now lol.
    I have no idea. It’s my bad, I was referring to the OP, mentioning 265 75s, and between ko2 vs toyos at3. I should have quoted.
    I would assume that a 34 inch tire would not come in a SL lol, and would be more than 16 lbs unsprung weight.
    HoytK9[QUOTED] likes this.
  7. Aug 11, 2021 at 12:04 PM
    AMGTRDPRO
    thanks that is what I was thinking. I have read a lot about the unsprung weight making the truck feel much slower with Ko2s being they are 53 pounds or so. I do see toyo makes the at3 in a 265/75/16 SL. also have read something about one side of the toyo being more aggressive depending which side is mounted out. can anyone confirm this ? or is it just for the larger tires that are E/F rated ?
  8. Aug 11, 2021 at 1:11 PM
    dfanonymous
    No just people on Tacoma world making things more than it is.
    I have the US made owl that dudes said has the more aggressive side wall…it’s not aggressive. Not compared to the wildpeaks.
  9. Aug 11, 2021 at 1:22 PM
    Raijin822
    Raijin822 Well-Known Member
    Canada
    2021 TRD OR
    Seems like a bit of a mess on the side wall lug/aggressiveness with the Toyo At3's. From what I read and understand on the big Toyo thread here is that the 265/75r16's will be pretty watered down side walls even if you go from SL or LT. Then any other size tire that are made in the USA would have a more pronounced side wall lugs/aggressiveness compared to ones coming from Japan.
    I ordered 265/75r16 SL OWL from my local tire shop, should be here sometime next week. Will post some pics once I get them on.
  10. Aug 11, 2021 at 1:32 PM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Nice truck my brother, nice truck.
    homegrown_xt[QUOTED] likes this.
  11. Aug 11, 2021 at 3:25 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Toyo ATIII
    DAS Taco, Junkhead and MikeyMcFly like this.
  12. Aug 12, 2021 at 7:45 PM
    bzzr2
    This is the solution OP..... just buy the AT tire that you think looks the best and forget the weight, ppl toss that around way way too much here.
    Tacomod likes this.
  13. Aug 12, 2021 at 7:53 PM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    Yeah I went from E to C in the same tire and size and only gained 1 mpg, no huge gains.
  14. Aug 12, 2021 at 8:12 PM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    I've been a bfg mud terrain guy for a long time and what I can say is bfg's rubber compound for longevity is the best . I too am on the fence of the new at3's or the ko2's . I've grown outta playing in the mud . I've had buddies get farther in deep snow with the bfg ko's or ko2's vs my km2's or km3's. That's snow though. I love my km3's and going on 2yrs with just under half tread life , I can see them making it into next spring or summer. Bfg as they say on their tires "Baja Champions".
  15. Aug 12, 2021 at 8:40 PM
    #35
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    It does look good, IMO the thread pattern is superior to the KO2s. The sidewall is lacking though...
  16. Aug 12, 2021 at 9:02 PM
    #36
    Tacomod
    Tacomod Well-Known Member
    get whatever is cheaper. I love my AT3s but KO2s are cool too. Neither is worth the premium. Tires are consumable and you will be replacing them in the future
  17. Aug 12, 2021 at 9:10 PM
    #37
    dfanonymous
    I mean, there’s merit to “tossing around” information about weight. Some people don’t want the loss of power for example. If loss of torque wasn’t a concern, then there would be no market to regearing vehicles.
    Same can be said about ride quality, wear and tear on the drive train, fuel economy etc. Not everyone’s idea of an “upgrade” is to make their vehicle’s ride, stiff, noisy and slow up hill.
  18. Aug 12, 2021 at 10:11 PM
    #38
    bzzr2
    Agreed, the open dialogue is good.
    I've had stock, then Falken AT3W 265/75r16, then 255/85r16 Toyo Open Country MT on my 2018 TRD Offroad, and didn't note any major difference when going from the 32's to the 33.5's when it came to fuel consumption for my driving. I preferred the firmer ride of the quality E rated MT tire over the SL AT3W tire as I like a firmer ride. Noise was minimal, as for slow uphill... the auto transmission is a pile of poops however you look at it with stock programming. For me, the overall power with the 33.5's was perfectly acceptable.
    Now that I have defected to a Diesel ZR2 I run 255/80r17 E rated AT3W's, mpg's, power and ride are all fantastic! That said a PRO with a manual transmission could be next on my list of ever changing rides.
  19. Aug 13, 2021 at 4:26 AM
    #39
    RedTaco68
    RedTaco68 Well-Known Member
    Pete
    WOOtown County, MA
    2013 Barcelona Red SR5 4x4 DCSB V6 6spd MT
    Millennial Anti-Theft Device (stick shift)
    I’ve got a set of 4 BFG KO2 for sale in size 265/75/16. E rated. Listed in the for sale section and located in MA. I loved the look of them but I’m 100% highway.
  20. Aug 13, 2021 at 5:41 AM
    #40
    MissoulaGriz
    MissoulaGriz Well-Known Member
    Missoula
    ‘19 SR5 DCSB Super White
    I’ve really enjoyed the ride I’ve gotten with these Toyo’s. They’re quiet at highway speeds and they’ve been great in the snow, rain, etc. No complaints.
    DAS Taco, VaToy, DanishTaco and 2 others like this.
