KO2s or Toyo Open Country AT3s?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AMGTRDPRO, Aug 8, 2021.
  1. Aug 13, 2021 at 9:24 PM
    #41
    homegrown_xt
    homegrown_xt Well-Known Member
    Sonoma County
    1996 Tacoma Xcab 4x4 V6 MTM
    Rancho Quick lift. Wheelers Off Road Progressive AAL with Rancho RS9000's, braided brake lines & clutch line. BFG 32x11.50 15 All Terrain Tires Deck Plate Mod. Flowmaster 60 series muffler and Marlin Crawler Short Throw Shifter.
    Thank you sir! ;-)
  2. Aug 14, 2021 at 10:31 AM
    #42
    RebleAZ
    RebleAZ Well-Known Member
    Troy
    AZ
    2020 Cement TRD Off Road
    Fox Performance Elite, RRW -25 RR7H, 295/70/17 Yokohama Geo MT. Alcan Leafs. Much more...
    Did you cut the steps off the Predators and essentially turn them into a form of slider?
    Vatostacos likes this.
  3. Aug 14, 2021 at 10:32 AM
    #43
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    That is exactly what I did. Just took an angle grinder with a cutting wheel and then sprayed them flat black
  4. Aug 14, 2021 at 2:37 PM
    #44
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Sexy beasts X2
    Junkhead and Nymbus[QUOTED] like this.
  5. Aug 14, 2021 at 2:39 PM
    #45
    RushT
    North Texas
    My AT3 experience has been great with the 265/75/16. Keep in mind that I’m 98% on road. Good at 85mph, good in the rain, and pretty darn quiet for the tread pattern.
  6. Aug 14, 2021 at 3:16 PM
    #46
    ImSoFreaknWhite
    ImSoFreaknWhite Member
    Jordan
    San Diego, Ca
    2018 SW DCSB TRDOF
    I have the K02’s on my truck. Recently put them on from the OEM tires and the ride quality on the roads is none, on the highways you maybe get a little rougher and louder but it is very minimal. I was looking for the same things as you in my new tires and am very happy with my purchase.
    Junkhead likes this.
  7. Aug 16, 2021 at 4:24 PM
    #47
    AMGTRDPRO
    AMGTRDPRO [OP] Well-Known Member
    2021 Lunar Rock TRD PRO
    Do you feel all the extra weight from the Ko2s ? I think they are 54 pounds per tire compared to the factory which I believe are 37-38 pounds. I like the side wall looks better on the K02s but I've read they aren't great in the rain and they bog down the truck and make it feel sluggish.
  8. Aug 16, 2021 at 4:25 PM
    #48
    AMGTRDPRO
    looks good have a side shot so I can see the tire wall ?
  9. Aug 16, 2021 at 4:50 PM
    #49
    ImSoFreaknWhite
    Jordan
    San Diego, Ca
    2018 SW DCSB TRDOF
    If there is a difference I have not noticed it, so I would say it is very minimal. I would not say any more sluggish than the truck already was. Personally I have not experienced the tires in the rain yet, doesn't rain much here in San Diego. They are very good looking tires, I very much enjoy the look of them!
  10. Aug 16, 2021 at 5:32 PM
    #50
    skeletron
    Clark
    Sakerlina
    2020 TRD Broh
    I've got the 285s which are about 60lbs each. I don't feel it on the acceleration but for sure braking is more difficult and makes me more cautious
  11. Aug 16, 2021 at 6:42 PM
    #51
    RushT
    North Texas
    I’ll check, but I don’t think I have a good one. Can get you one tomorrow.
  12. Aug 18, 2021 at 3:57 PM
    #52
    RushT
    North Texas
    Here you go, hope this helps. A bit of a dirty pig at the moment.
    698EE34E-0A69-4E5A-A0D1-4236A726FF2A.jpg F9F94EB5-1282-4930-B04E-D7670F8C5915.jpg
  13. Aug 18, 2021 at 5:07 PM
    #53
    Raijin822
    Raijin822 Well-Known Member
    Canada
    2021 TRD OR
    Damn tis looks good. THanks for the pics, exact set up I will be running once my tires come in
  14. Dec 2, 2021 at 9:45 PM
    #54
    quantumechanic
    quantumechanic Well-Known Member
    2022 Tacoma SR5 DCSB 4x4
    Just ran across this post tonight (had this exact idea about removing the steps off of the Predators and searched on it).
    A couple of questions if you don’t mind…
    - Do you use the remaining step surface as a step? In other words, is there enough surface there to step on to aid in getting into the truck? I’ve been looking at steps and running boards but want to find something that is tighter to the truck and doesn’t protrude out much. Everything I’ve seen sticks out further than what I think I want.
    BTW, I think they look good like that.
    Thanks in advance.
  15. Dec 3, 2021 at 6:48 AM
    #55
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Looks great I'm wanting to step up from 285/75/16 to 295/75/16 . I've witnessed for my self how long ko2's last and how good they do in the snow and I don't go mudding very often or at all . I'm pushing 2 1/2 years on my km3's as of now
  16. Dec 3, 2021 at 9:28 AM
    #56
    Rush4th
    Rush4th Well-Known Member
    The predator steps are garbage if you plan on actually using them as sliders. Caliraised sliders are a million times better and worth every penny.
    As far as tires, the k02's ride is stiffer than the toyo's, even if you opt in for the e rated toyo's, but as far as traction the k02's are better. I kept the OC3's on my baja bug cuz it softened the ride when I jump the piss out of it, but my taco will only ever have k02's, which are finally getting on the truck on Monday, it's a new truck..
    I swear that the k02's out preformed every other tire that I have tried, pro comp's, grabbers, falken's, toyo's, nitto's, and super swampers. The only other tire that I'd ever consider are the Mikey Thompson's. But for the price and warranty, I'd still go with the k02's or the km3's, but they don't have a mile warranty.
  17. Dec 3, 2021 at 10:44 AM
    #57
    skeletron
    Clark
    Sakerlina
    2020 TRD Broh
    Nah there's not a lot left to step on once the actual steps get cut off. Hasn't bothered me much but my grandma has a tough time so I bring a step stool with me when I pick her up for dinner
  18. Dec 3, 2021 at 10:48 AM
    #58
    SpyGoat
    SpyGoat I miss you Hobbs
    Tom
    Long Island, NY
    2021 TRD Off Road MGM DCSB, 2025 Land Cruiser
    A bunch..and no build thread!
    I'm running KO2's on stock 16's, but I got them for free so I didn't really shop them. Good riding tire, for sure!
    shotgunbilly420 likes this.
  19. Dec 3, 2021 at 12:12 PM
    #59
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Your mileage and opinion may vary but I’ve had toyo at3 tires for almost over a year now and I have no complaints. Rotated every 5k miles and no abnormal wear. There’s a bit of noise from the tires but my truck makes more noise because of all the mods I’ve done.
    AMGTRDPRO[OP] likes this.
  20. Dec 20, 2022 at 5:28 PM
    #60
    acgreen01
    acgreen01 Well-Known Member
    Andrew
    2012 silver 4wd regular cab
    I just had a set of the toyo open country at3s installed. I notice between 60 and 65 I get a rumble type noise with a slight vibration. It goes away if im going down hill or let off the gas. I didn't have it before having the tires installed. It doesn't change when I turn or anything. It's stays the same and only between 60 and 65. The tire store did have issues balancing the tires. Anyone else experienced this with these tires?
