Kobalt toolbox install w/ grip rites
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dmb, Mar 7, 2010.
  1. Mar 7, 2010 at 2:59 PM
    dmb
    dmb [OP] Well-Known Member
    Boise, ID
    So I bought the Kobalt "low profile" at Lowes yesterday, $148, can't beat that! Installed it today using the 'Grip Rite' system, which can be found in the same vicinity of the toolboxes. I used two of my tie down cleats to hold the 'Grip Rites' tight against the bed rail. I originally used the existing T bolt that was with the cleat, but had a hard time keeping it lined up. So instead I used a regular hex bolt & 3/8 washer. Took a couple hours total for everything.
    You'll want to take a few measurements from the front of the bed to figure out where you'll mount the grips. Mine ended up being about 7 inches from the front. Onto the pics....
    This is how everything is put together: Hex bolt, washer, nut, Grip Rite, cleat.
    Side view
    Take your bolt, washer, nut and slide behind the rail. Then slide the Grite Rite on and tighten the cleat enough so everything stays upright.
    Now, in order to get everything super tight you need to have something holding the bolt as you turn the cleat. Took a while for me to figure this part out. Use an appropriate sized wrench and insert into the bed rail from the back of the truck. Slide it up to the front and work it into place. It might take a few tries to get it in the right spot but once it's in your good. Finish tightening the cleat and repeat on the other side.
    Ready for the toolbox
    Measure twice, drill once. I used the bolts & washers that came with the 'Grip Rite' system PLUS a rubber washer on bottom and an extra nut on top. Without the extra nut on top I wasn't able to get everything tighten down all the way.
    Few more pics after everything was done...
    This is a great setup, easy to remove if you ever need to. I'm thinking about having it powder-coated black....we'll see. Anyway, if your scared about using J hooks or drilling into the rail, DONT! This way might take a little longer but it ain't coming loose.
  2. Mar 7, 2010 at 3:02 PM
    ilovetacos
    ilovetacos Well-Known Member
    Gavin
    Sacramento/Woodland
    2006 TRD Sport 4x4 DC
    Sold!
    That's a nice box! Does it come in black?
  3. Mar 7, 2010 at 3:08 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    I did mine in a similar way.... just used a normal bolt and ground down washer to hold the plastic piece to rail....
  4. Mar 7, 2010 at 3:08 PM
    Dark_Taco
    Dark_Taco Well-Known Member
    2023 TRD Pro
    Stock
    all for about $150 thats not bad. Nice
  5. Mar 7, 2010 at 3:13 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    HP60/14 bolt, Atlas 5.0.
    how much were the "grip rites"?
  6. Mar 7, 2010 at 3:16 PM
    TacoNut
    Adam
    Denver, Co
    If I recall they were around $30.... Not positive though.
  7. Mar 7, 2010 at 3:19 PM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    looks good.that is the box i want.how deep is it?looks like 12" or so?
  8. Mar 7, 2010 at 3:29 PM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    the grip rites are 30 dollars, i have the same box and used them also, just in a different way.
  9. Mar 7, 2010 at 4:13 PM
    dmb
    Boise, ID
    No black. Bummer.
    It's at least a foot deep. I don't have that much crap to haul around so it's the perfect size for me.
  10. Mar 7, 2010 at 4:22 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    Cool, thanks.
  11. Mar 7, 2010 at 4:25 PM
    ILove2Drive
    ILove2Drive Well-Known Member
    Casey
    WV
    07 Tacoma 4X4 5 Speed Manual
    Halo headlights, Black tail light covers, dual exhaust, 5100s front and rear, eibach coils, wheelers 1.5 AAL, window tint, bow arrow antenna, bull bar, painted grille emblem, debadged, raceline rims, a few decals, CB radio, alpine HU, husky floor liners, tool box, mesh grill...and more to come eventually
    I used the grip rites with mine as well, have a regular kobalt tool box on mine (not low-profile) but have had it on there almost 2 years and havent had a single problem out of them :D
  12. Mar 7, 2010 at 4:30 PM
    dmb
    Boise, ID
    Awesome. When I first saw them at Lowes I said to myself "30 bucks for this!" But they were worth it.
  13. Mar 7, 2010 at 5:07 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Looks great , nice tool box , awesome price ,
    OZ
  14. Mar 7, 2010 at 5:12 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
  15. Mar 7, 2010 at 5:25 PM
    JKD
    JKD Well-Known Member
    That looks like a good solution for me too.
  16. Mar 7, 2010 at 7:56 PM
    ILove2Drive
    Casey
    WV
    Yes definitely! I did NOT want to drill any holes in the truck if I didn't have to, and like I said they've lasted a long time, well spent money, nice toolbox as well :)
  17. Mar 7, 2010 at 8:05 PM
    Anthony
    Anthony San Antonio Detailer :)
    Houston - Spring/Tomball area
    06 prerunner access cab 2.7L M5
    Nfabs Afe Pro Dry UWS linex'd toolbox
    great tips for installing a box... but, damn that box looks small compared to the "normal" sizes. whatre the measurements of it?
  18. Mar 8, 2010 at 10:57 AM
    DIVERMAN
    DIVERMAN Well-Known Member
    Cullen
    Louisiana
    2012 Pyrite Mica 4x4 TRD O/R SWB
    Tailgate theft prevention, Locking rear window, Blind spot mirrors, Fogs on anytime, Rear diff breather relocated, Bed storage locks, LEDs in/out, Relocated trailer plug(custom!), OEM bed mat, OEM running boards, OEM bed divider, Bed lights, Rev lights, Raptor lights, WeatherTech floor mats and window vents, Extra D-rings, ImMrYo Bracket, UWS low pro black toolbox, Carhartt seat covers,
    awesome! thanks.
  19. Mar 8, 2010 at 4:54 PM
    SampleFool
    SampleFool Three Percenter
    Ga
    Silver
    08 off-road
    Just an Idea for the wrench in the bed rail, if you take a screwdriver and push it bed hind the bolt head and pull out it holds it place tight and looks a little easier. Nice write up man, I REALLY need one of these and I will use your idea.
  20. Mar 8, 2010 at 5:24 PM
    dmb
    Boise, ID
    Ahh, that would probably be a lot easier than dragging a damn wrench up and down lol.
