Kobalt toolbox install w/ grip rites
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dmb, Mar 7, 2010.
  1. Dec 26, 2010 at 12:14 PM
    #41
    go8soccer
    go8soccer Memba
    Grovetown, GA
    '08 Super White DC LB Prerunner Sport
    Leaf TSB, front Billie 5100's (1.75"), 265x70x17 BFG Rugged Terrain
    I just got this exact same box too! I got mine on Black Friday for $98.. figured I couldn't go wrong! :)
    Like everyone else, I don't want to drill down into my rails like the directions for the box suggest. The J-Bolts are a great idea, and cheap. I'm not really wanting to use my cleats because they've proven useful on more than one occasion for me.
    I'm thinking about getting some Toyota mounts from the toolbox manufacturer that i found here, but I'm having a hard time justifying paying more for the shipping (almost $12) than the actual parts(less than $10).
    So if you're wanting to spend some money, these are still cheaper than the mounts that you can get at lowe's for $30 (including shipping)..
    The real reason for this post:
    What do you guys think.. will the mounts in the link provided be worth the money, or will 2 J bolts and some locking nuts be just as good?
  2. Jan 6, 2011 at 11:12 AM
    #42
    Rufus
    Rufus Well-Known Member
    SoCal
    2010 TRD PreRunner Sport
    OEM Truck Bed Extender, Window Tint, Tailgate Security Mod, OEM Spare Tire Lock, Cam Locks (storage compartments), OEM Bed Mat, OEM Skid Plate, Stant 11504 Locking Gas Cap, TW Edrin55 OEM Running Boards, Pop & Lock w/Back-Up Cam, Black WeatherTechs, Red Line Quick Lift Plus Hood Struts, Wet Okole Front Seat Covers-black/charcoal with red & white TRD graphic & back seat pockets, DIY Satoshi Grillcraft & Old School Toyota Badge, TW ZonKs Black UWS Low Pro Truck Box, Rear Suspension TSB, 3M Scotch Guard Paint & Headlight Protection Film 8mm Urethane, Flyzeye V2 Wired Amber/White/Amber Interior LED Lights w/Silver Case, Sleek Looking Black LED Tail Lights from K2 Motors (Identical to OEM, but black).
    I just bought a black low-pro UWS from ZonKs. J-hooks work just fine @ .90 cents each x 4. I don't know what you guys are talking about drilling into the rail :confused:. Drilling is unnecessary. The rails have open slots at the bottom that the J-hooks go in & hook onto. Just run your fingers along the bottom edge of the rail to locate & feel them up :p. They line up perfectly with your truck box. Just put your box where you want it, measure location where the J-hooks will fasten, measure & mark that location on the box, then drill slightly larger holes on the box for some final adjustments, if necessary. Remember to measure twice & drill once. If you have a black box like mine, paint the hooks, nuts & washers black for a cleaner look. Try not to over tighten the J-hooks. It puts undo stress to the rails. That simple & secure. This way you can keep your cleats for other uses.
    Along the exterior back of the box, where it comes into contact with the back rail, I put some black self adhesive foam/rubber strip ($4 @ Lowe's) to prevent paint damage & scuff marks. Also provides some cush. Overkill maybe, but I like.
    Those Toyota fasteners are sweet for $10, but shipping cost doubles the price. The J-hooks are just as effective and can be easily removed if needed. Now with the money you saved, buy yourself a 6-pack :cheers:and enjoy:drunk:.
  3. Jan 24, 2011 at 10:49 AM
    #43
    VooDoo
    VooDoo More Cowbell!
    Carter Ivey
    Baton Rouge, LA/ Starkville, MS
    '06 DC LB PreRunner
    SUB'D!
  4. Jan 24, 2011 at 12:42 PM
    #44
    Al2006
    Al2006 Member
    VA
    06 Tacoma 4x4
    none
  5. Feb 11, 2011 at 9:47 AM
    #45
    clink
    clink New Member
    Nashville
    2010 Sport SR5 4X4
    4" ProComp full suspension lift, ProMaxx Bully Bar, ProMaxx Nerf Bar side rails, Kobalt Low Profile tool box
    Great post. I went out and got the same tool box and mounted it using the method you described, except I used the screwdriver vs wrench method for tightening the inside bolt. Also I used stainless steel bolts, nuts, etc. It took me a few trips to Ace, but I determined the best length hex bolt is 1 inch.
    Thanks again for the great post!!!
  6. Feb 11, 2011 at 12:38 PM
    #46
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    That looks really good!
  7. Apr 6, 2011 at 9:13 PM
    #47
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    damn I wish I would have seen this thread sooner. I drilled mine. It's been holding up fine for the last few months but those mounts are sweet.
  8. Apr 12, 2011 at 6:01 PM
    #48
    jking3002
    jking3002 Well-Known Member
    Jonathan
    Kentucky
    Scion tC
    Ricer muffler, window tent, trd shift knob.
    For all who have this toolbox, is it waterproof?
    (I know this thread is old, but its already been revived recently, so screw it.)
  9. Apr 12, 2011 at 6:08 PM
    #49
    especk
    Erik
    Redding, CA
    Yes. Just dont take it under water.
  10. Apr 12, 2011 at 6:11 PM
    #50
    El Tano
    El Tano i am the one who knocks
    Pasadena. CA
    10 Tacoma TRD sport
    Corvette homelink FRONT: 5100 Blinstein set at 0 Procomp 3" leveling kit Allpro UCA’s. REAR: Icon Multi Rate RXT Leaf Pack 5100 Blinstein. 17x9 kMC wheels 0 BS 285/70 17 Wildpeak A/T4W C range Amp research steps. and a bunch of TSB's
    OP, Did you put something in between the tool box and the plastic ?????it will mark the plastic if you don't put anything..
    Nice set up, thanks for sharing.
  11. Apr 12, 2011 at 6:27 PM
    #51
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Anyone know what would work to mount this on a first gen? Our bed rails fold over and aren't very strong. Suggestions? Would the grip rites work? I like to stay away from j-hooks they just don't look like they would be very secure
  12. Apr 12, 2011 at 6:31 PM
    #52
    malander
    max
    01 limited trd 4x4
    My issue is that they wouldnt really make contact with the bed rails since they aren't curved underneath. Is there something I'm missing here?
  13. Apr 12, 2011 at 6:47 PM
    #53
    malander
    max
    01 limited trd 4x4
    I could drill but it's not my first option. Our rails are plain and simple, imagine an F except take the lower horizontal line away and put in a vertical line at the right point going about an inch down
  14. Apr 12, 2011 at 6:52 PM
    #54
    mlbdriver
    mlbdriver Well-Known Member
    Ben
    Santa Rosa
    2020 TRD Off-Road
    Go Fast Camper ARB Dual Air-Compressor Pro-Comp 7089 17x8 BFG AT KO2 265x70x17
    Did the same to mine. i used the krylon black. Looks good man
  15. Apr 12, 2011 at 7:09 PM
    #55
    malander
    max
    01 limited trd 4x4
    That might be a better option there are some pre drilled holes in the side rails but I'm sure I'd have to drill at least one more set.
  16. Sep 1, 2012 at 1:43 PM
    #56
    OneMentalCase
    OneMentalCase Well-Known Member
    South Florida
    10 Pyrite LB
  17. Sep 1, 2012 at 2:49 PM
    #57
    tacoman00
    tacoman00 Your Average Joe
    Rockville, MD
    2021 TRD Off-Road DCSB
    Toytec BOSS 2.0 lift, 18x9 Fuel Rebels, 32” BFG AT K02.
    I have this same box. Hope you like your better than i like mine. I wouldnt take this box again if i could get it for $10. Not enough space, cheap handles that get to where they dont get to open, just a few things i dont care for. But then again, you get what u pay for.
  18. Nov 12, 2012 at 8:27 AM
    #58
    Longo118
    Longo118 Well-Known Member
    New York
    2006 4x4
    -OME Lift w/ Dakar leafs -Wheels + Tires -All Pro IFS skid -4xInnovations Sliders -Tool box, hi-lift, shovel mount and a few others
    Do you know what the Cubic feet of your tool box is? I found a few different ones that are not the low profile box and I wanted to make sure their size would fit the tacoma. It says they will fit but they are 12+ cubic feet, thats a lot for a tacoma bed, no? Thanks!
  19. Dec 27, 2012 at 10:34 AM
    #59
    g8rzguy78
    g8rzguy78 Well-Known Member
    J.C.
    WNC
    Thanks so much for this write up. Im behind a little I know, but I got a slim line Kobalt box during Christmas for my '05 Tacoma. I was wondering, w/o going out and looking at it, how that would work out. Great idea, great forum. Ill be around a bit...
  20. Dec 27, 2012 at 10:47 AM
    #60
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    Anyone had a problem with these toolboxes and the lock mechanism? I read that the system is not great before I bought it, but I have a real hard time putting the damn key in the mechanism. The key doesn't seem to want to go in and I have to jiggle is around for like 30 seconds everytime I try to unlock / lock.
