Koditten random project/boat build thread/Tacoma frame swap..
Discussion in 'Garage / Workshop' started by koditten, May 22, 2024.
  1. Aug 10, 2025 at 11:30 AM
    #521
    koditten
    koditten [OP] Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    One of the axle assemblies waiting for some clean up.
  2. Aug 10, 2025 at 11:33 AM
    #522
    koditten
    Kirk
    Central Michigan
    Control arm bushing sleeves are froze into the bushings. I was pretty sure they would be locked up in there.
    I've had good luck just cutting them out with a thin disk.
    That a tomorrow job.
    MarX, Delta09, soundman98 and 2 others like this.
  3. Aug 10, 2025 at 11:34 AM
    #523
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    An air hammer is the easiest way I've found for getting the axles out of the hubs.
  4. Aug 10, 2025 at 11:37 AM
    #524
    koditten
    Kirk
    Central Michigan
    True, but to gain access to the axle nut, the 4 x 4 manual locking hub assembly needs to be taken apart.
    That 24 nuts I don't want deal with.
    On an auto hub, all there is, is a cover and big axle nut.
  5. Aug 10, 2025 at 11:43 AM
    #525
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    Oops, I missed the manual part.
  6. Aug 11, 2025 at 11:00 AM
    #526
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    Take videos also. I have found that no matter how many pictures I take the part that I need to see is always just not quite visible in the picture I took. With a video you lessen the chance that there is something that you need to see but the picture does not quite show it.
    koditten[QUOTED][OP] likes this.
  7. Aug 11, 2025 at 11:53 AM
    #527
    koditten
    Kirk
    Central Michigan
    Control arms were not salvageable. Found rust perforation when I was cutting out the 1st one. Figured might as well save some hassle and just get new ones coming. $200 each. Ouch!
    MarX, RustyGreen and Delta09 like this.
  8. Aug 11, 2025 at 11:54 AM
    #528
    SACTOWN
    SACTOWN Well-Known Member
    Greg
    :eek:
  9. Aug 11, 2025 at 11:54 AM
    #529
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Well, that's one way to get new balls joints :notsure:
  10. Aug 11, 2025 at 1:24 PM
    #530
    Kilo Charlie
    Kilo Charlie One flat foot on the Devil's wing
    Iowa
    2017 Inferno Off Road
    And peace of mind
  11. Aug 11, 2025 at 1:37 PM
    #531
    koditten
    Kirk
    Central Michigan
    The sad part is these were replaced with OEM ball joints 100 miles ago...which was 5 years ago.
    MarX, Toyko Joe and Delta09 like this.
  12. Aug 11, 2025 at 1:38 PM
    #532
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Salt never rest o_O
  13. Aug 11, 2025 at 1:45 PM
    #533
    Kilo Charlie
    Iowa
  14. Aug 11, 2025 at 2:01 PM
    #534
    koditten
    Kirk
    Central Michigan
    Slick.
    I got the exact same hoist I used to pull the engine and transmission.
    When the engine gets dropped back in the new chassis, it going up for sale. Its used so seldom, I just get pissed tripping over the thing. See, ya!
  15. Aug 11, 2025 at 3:37 PM
    #535
    koditten
    Kirk
    Central Michigan
    Tomorrows project.
    Wife said she would paint if I cleaned up the parts and prepped them.
    Deal!
  16. Aug 15, 2025 at 6:44 PM
    #536
    koditten
    Kirk
    Central Michigan
    My wife painted up the major parts for the next step.
    Now for the parts to dry and I can start hanging parts.
    Kilo Charlie, Delta09, MarX and 2 others like this.
  17. Aug 15, 2025 at 7:08 PM
    #537
    koditten
    Kirk
    Central Michigan
    Hung the front diffy.
  18. Aug 15, 2025 at 7:13 PM
    #538
    koditten
    Kirk
    Central Michigan
    Installed upper control arms in preparation to installing spindle/drive shaft assemblies.
    Note: even though you marked which side the upper control arm resides, you need to make sure you have not installed the upper control arm upside down.
    The spindle upper ball joint just won't socket in far enough to hold the weight of the assembly.
    Guess who got to pull out the heavy ass assembly, flip the control arm and then bolt in the top spindle bolt?
  19. Aug 15, 2025 at 7:13 PM
    #539
    koditten
    Kirk
    Central Michigan
  20. Aug 15, 2025 at 7:17 PM
    #540
    koditten
    Kirk
    Central Michigan
    Tomorrows goal:
    Install sway bar, coil overs, attach lower ball joints, tie rod ends and touch up any paint scratches.
    MarX, soundman98 and RustyGreen like this.
