KOK grill lights (toyota lettering specifically) not shutting off.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacoma1675, Feb 1, 2024.
  1. Feb 2, 2024 at 10:34 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    15 amp is in front of headlights relay. Do lights stay on if you plug to 10amp H-LP RH LO with lights turned off.
  2. Feb 2, 2024 at 6:21 PM
    joesmaro
    joesmaro New Member
    Joe
    2009 Silver Tacoma TRD Off Road
  3. Feb 3, 2024 at 11:09 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Again, I would temporarily hook this thing up to a known good 12V power source (aka the battery) and see if the damn thing works, before anything. I am skeptical in a lot of this niche' market no name product, especially electronics.
    The worst that happens is you waste 2 minutes, but if it’s bad, you saved hours of D’n re wiring jobs.
    just my two pennies
    GL
    soundman98 and RIX TUX like this.
  4. Feb 3, 2024 at 1:34 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    the problem is what you wired it too
  5. Feb 4, 2024 at 9:26 AM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    fyi, i've been running into a lot of 12v gear for the past few years, black is +12v, and red is wired to ground... i'm not saying that's the case here, only that assuming that red=+12v, and black=ground is no longer a correct assumption anymore.
  6. Feb 4, 2024 at 10:44 AM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    Must have guys with an AC background designing these
  7. Feb 5, 2024 at 8:06 AM
    Tacoma1675
    Tacoma1675 [OP] Member
    Tacoma, WA
    Tacoma Limited 2016
    3" lift kit.
    I wanted to give a quick update here. I double checked all of the connections to the wiring, and after fiddling with it, I got the lights to actually work correctly. My original wiring job was correct. I ended up using the 10amp fuse that connects the 10amp H-LP RH LO. Once plugged in, and making sure all of the wires were correctly in place, and that the add a fuse was seated properly, the thing works. I did ask my boss for advice about this since he has his degree in Electrical Engineering. I wanted to make sure that I got good info from a reliable source. For all of the people who were genuinely helpful on here, thank you. I appreciate all of the time and input you gave. See attached pic for reference.
  8. Feb 5, 2024 at 8:15 AM
    Koolbreeze7
    Koolbreeze7 GRILL MAN
    Jon
    Jersey
    2017 TRD Sport 4x4 DCLB Black, Trail Limo. RIP- 2009, 2000, 91,89,87 trucks
    Rigid pod fogs, SpartanX stealth grill and hood LED's, 17" SEMA's on 275/70/17 Falken Wildpeak AT3W's, Fox 2.0 on all corners , TRD CAI, LEER 100XQ Blacked out, w/ Thule racks, and Cargo slider Flow master American Thunder "dual" exhaust, remote start, tint, TRD Pro grill and TRD shadow graphics, Alcan custom 8 leaf Spring Pack
  9. Feb 5, 2024 at 8:36 AM
    Veet-88
    How are red lights on the front of the truck even legal? Besides I'm assuming they are not in anyway.
  10. Feb 5, 2024 at 8:49 AM
    Vlady
    Issy, WA
    Get electrical diagrams. Some of the circuits are activated by control units and there is a rick to burn them.
  11. Feb 5, 2024 at 9:17 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    Most likely not legal, there are boatloads of overseas products flooding in that doesn't meet spec for their intended market, and loads of people buying them, that doesn't care, so it continues.
  12. Feb 5, 2024 at 9:47 AM
    Dorf510
    Dorf510 Well-Known Member
    Tyler
    Vista, CA
    18 TRD 4x4
    Dayton wires, flux-capacitor, port-a-potty
    OP- What was the fix? The original post stated it was hooked up “correctly” but not functioning as intended?
    P.S.- Electrical engineers are smart(Family of engineers), but TW has plenty of people fixing issues without the degree(bc they actually utilize the FSM or heed warning from other members).
    Remember this is a Forum, people will help you out IF you listen to advice and don’t get BH.
    P.P.S.- electrical additions to this platform can cause many issues, as the ECM monitors signal strength to each sensor…any deviation in that signal strength(high or low) will throw a code…think halogen light to LED upgrade(rapid blink), diff elect pull required for each bulb(10-12v VS 2v), can throw codes in the system if not correctly diode’d. The “cheap” grill LEDs are notorious for issues(not correctly wired for load/vibration), thus throwing a code for an electrical system issue. Any deviation from the factory(splice kits/fuse add-ones) are a crap shoot, i would recommend a controller for all electrical accessories.
    soundman98, ricco333 and Chew like this.
