Konig Countersteer 16x8 with p265/75r16 hankook dynapro ATM
Discussion in 'Wheels & Tires' started by YDCtaco, Mar 6, 2017.
  1. Mar 6, 2017 at 7:05 PM
    YDCtaco
    YDCtaco [OP] Well-Known Member
    Alexandria, VA
    2016 DCSB TRD OR 4x4-Auto
    Hey Everyone,
    I'm looking to this setup (p265/75r16 Hankook Dynapro ATM on Konig Countersteer 16x8 wheels) as I want to have the least weight in the wheel/tire combo but also have a more aggressive tire than the stock trd off-road Goodyear adventure tires. The wheels are around 18lbs and the tires are around 39lbs (from what I have read). My only concern is the back spacing. It says the have 4.5 inches with 0 offset. Will this stick out from the flares at all or cause any rubbing? Also, if any of you have a better combo to get as light as possible but still have some aggressive nature to it, please share! Thanks everyone.
  2. Mar 6, 2017 at 7:13 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    My 2nd gen has the exact wheel/tire combo. Wheel is 16 lb according to my bathroom scale. :) The sidewall sticks past the fender flares but the tread doesn't. The setup may rub the mudflaps at full steering lock. On my 2nd gen, I got Huskyliner flaps with more clearance.
    YDCtaco[OP] likes this.
  3. Mar 6, 2017 at 7:22 PM
    YDCtaco
    Alexandria, VA
    Thanks
  4. Mar 8, 2017 at 4:30 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    I have Cooper AT3's mounted on mine 265/75R16 P metric with Billstein 5100 stock springs at the 1.75 setting (closer to 1.5") no rub with the stock mud flaps. The AT3's do have a round sidewall and I do get more spray past mud flap but no where as bad as without mud flap. If the Kankook or is it Hankook tires are what you want go for it. I think the AT3's are about the same weight wise and for the PNW weather I have been happy with them once I found the right person to balance them. I question some shops equipment and wether there techs trully understand or care enough about a properly balanced wheel/tire combo.
  5. Mar 8, 2017 at 5:19 PM
    YDCtaco
    Alexandria, VA
    Thanks! Haha yeah I misspelled hankook ahh! Um, but I'll definitely look into the cooper at3s. I don't know what I really want, I just want a light setup overall.
  6. Mar 9, 2017 at 8:31 PM
    01 dhrracer
    Still Shopping
    Took a look at my set up today. The tread does stick out past the stock mud flaps but not much, less than an inch. Just an eye ball measurment.
