Konig Countersteer Thread
Discussion in 'Wheels & Tires' started by satmanski, Apr 4, 2011.
  1. Sep 29, 2015 at 7:56 AM
    #101
    TacomaPrime
    TacomaPrime Cybertronian Tacoma
    Gregory
    Illinois
    14 TRD sport 4x4 Barcelona Red
    Weathertech front floor liners, window vent visors. Custom bedside decals. OEM bed mat, tonneau covrew. Added D rings to bed.
    I got a set of dark matte bronze ones for my indigo ink pearl taco. Just gotta decide on tires. Was thinking about michelin ltx ms/2's since I do 0 offroading, but the AT/2's seem to offer basically the same performance but look more aggressive.
  2. Sep 29, 2015 at 8:31 AM
    #102
    scocar
    scocar hypotenoper
    If I had a black truck I 'd get the bronze Countersteers.
    Biscuits likes this.
  3. Sep 29, 2015 at 8:44 AM
    #103
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    So I know this is a pretty old request. Lol but here's a couple of my BSP with gunmetal Countersteers.
    TACOVRD likes this.
  4. Oct 13, 2015 at 10:38 AM
    #104
    diverdale
    diverdale #sosconceptscrew
    Dale
    Raleigh, NC
    2015 TRD OR DCSB
    Fox 2.5 Coilovers, Fox 2.0 Rear Resi, Icon 3 Leaf AAL
    Did you get these wheel? I have a SSM 15 dbl cab as well and wonder how the GG Countersteers would look.
  5. Oct 15, 2015 at 1:01 PM
    #105
    braidangler
    braidangler New Member
    2012 Pyrite Mica Tacoma PreRunner SR5
    Here's a set of the matte bronze Countersteers (from FN Wheels) on a pyrite mica 2012.
    TACOVRD likes this.
  6. Oct 15, 2015 at 1:07 PM
    #106
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    The matte bronze looks awesome on the pyrite.
    What are the countersteer folks here running for hub spacers? Plastic included caps/spacers or aluminum spacers?
  7. Oct 15, 2015 at 2:52 PM
    #107
    scocar
    scocar hypotenoper
    I'm curious too. I saw the plastic Gorilla ones, but the idea of plastic in this application is less than thrilling.
    Do they provide spacers? Or do you need to buy your own elsewhere?
    I would vastly prefer aluminum.
  8. Oct 15, 2015 at 4:33 PM
    #108
    braidangler
    No spacers used, beefier appearance due to the Konigs being an inch wider (8" vs 7") than the stock rims and tires now 265s rather than 245s.
  9. Oct 15, 2015 at 4:36 PM
    #109
    millertime89
    millertime89 Flatlander
    Erik
    Saskatchewan
    06 TRD Sport DCLB 4x4
    Yes sir
  10. Oct 15, 2015 at 4:38 PM
    #110
    scocar
    scocar hypotenoper
    Actually, I, and I believe Ryan above (can0nfan2379), are referring to the difference between the hub bore on the Konigs and the hub of the Tacoma (108mm vs 106.1mm, IIRC), and the need to use adapter rings for the hubcentric design.
    I'm not sure I have all the facts yet, so trying to figure out if this is really an issue. Some input from guys who have already had them installed would be very helpful
  11. Oct 15, 2015 at 4:39 PM
    #111
    scocar
    scocar hypotenoper
    Not Konigs, GTFO
  12. Oct 15, 2015 at 4:39 PM
    #112
    millertime89
    Erik
    Saskatchewan
    Yes sir
    Thought this was a mickey thompson thread... :confused:
  13. Oct 15, 2015 at 6:09 PM
    #113
    TACOVRD
    TW Addict
    AZ/WA
    Workin' on it....
    Yes referring to bore diameter for the hub. From what I've read most aftermarket wheels are lug centric (Konigs included) not hub centric (stock Toyota wheels + Stealth Custom...there may be others) and in order to minimize vibrations, a hub spacer should be used to take up any slack between the 106mm hub vs the wheel (Countersteers are 108mm) in addition to tapered lug nuts to centre the wheel on the studs.
    Just curious if anyone running aluminum spacers has ended up with any problems?
  14. Oct 15, 2015 at 6:13 PM
    #114
    scocar
    scocar hypotenoper
    I just contacted FN to ask then directly about this, and if is it direct bolt on w/o any adapters.
  15. Oct 15, 2015 at 6:41 PM
    #115
    TACOVRD
    TW Addict
    AZ/WA
    Workin' on it....
    :popcorn::cheers:
  16. Oct 15, 2015 at 8:28 PM
    #116
    scocar
    scocar hypotenoper
    From FN, and Dustin, more specifically.
    Thank you for your interest in our wheels, and thank you for contacting us. The 16x8" Konig Countersteer Offroad wheels are a direct fit on your 2015 Tacoma 6-lug (PreRunner / 4x4). We have been selling this wheel for the Tacoma for many years, and the wheels have never required an adapter.You might have read that the wheels come with push-thru center caps which center the wheels on Tacoma hubs, and also included with the wheels (when ordered from us) are hub centric rings, which take the place of the center caps and work to center the wheels on the Tacoma's hubs. These are not adapters though. The wheels also require a different style of lug nut (which we also include at no charge). The wheels just bolt right up to your hubs and fit perfectly when installed using the supplied hardware. We have installed them on hundreds of Tacomas and shipped thousands of sets to Tacoma owners all over the world.If you have any other questions at all please just let us know, and we'll be happy to help you.Thanks again,
    Dustin
    FN Wheels
    (855)WHEEL-00 (943-3500) - Toll Free in the U.S. and Canada
    (951)735-1100 - Office (Local/International)
    (714)390-9387 - Cell (Call or text anytime)
    braidangler likes this.
  17. Oct 21, 2015 at 9:28 PM
    #117
    mosquitoTaco
    mosquitoTaco Has an attractive member
    Anthony
    SouthTennessee
    14' DCSB offroadsport-sold =2005 T4R V8
    Bilstien 5100@ 0, OME 885(+10 mm drivers side spacer for taco lean, 5mm passenger), b110 rears w/ allpro standard leaf pack, wheelers ubolt flip, superbump bump stops, extended brake lines steal braided(front and rear), Dick Cepek extreme country 305/65/17 tires on FN six shooters=17x8, street tires are 285/75/16 duratrac w/FN countersteer type X= 16x8, a healthy cab mount chop, SPC LR UCA's, TC cam tab gussets, Wet okole seat covers, husky x-act fit floor liners, SOS aluminum front skid, SOS mid skid, SOS sliders (bolt on), ECGS bushing for needle bearing, uniden PRO520XL cb. BAMF tailgate antenna mount, 4' firestick, A.R.E. Z series camper top, Factory roof rack, Pioneer avh-5800x head unit. Front and rear anytime cameras, Rear diff. Breather relocate. 42" highlift. Tow straps/All-PRO snatch strap, tow hitch w/D-ring, traction pads, Tacoma bed mat, Rago Fab ditch light brackets with jap special light pods
    Can some people post up more straight down the side shots like page 1. I'm torn between these and the type x due to offsets
  18. Oct 21, 2015 at 9:50 PM
    #118
    3milecreek
    3milecreek MtnGoat
    Stephen
    Barnwell SC
    Heavily Modified 94 Yota
    Never the same
    20150922_192511.jpg 20150902_160901.jpg here is my Countersteers! Love them and get alot of comments about them. More importantly they have held up well wheeling.
    Corneeeeelius likes this.
  19. Dec 25, 2015 at 10:31 AM
    #119
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    After years of waiting, and $1600 later, I can finally contribute to this thread! Here are my Graphite Gunmetal Konig Countersteer Offroads with Hankook Dynapro ATM 114t P265/75R16 tires on my 06 Super White Access Cab with OEM Suspension and Rally Armor Mud Flaps.
    The top of the wheel well pretty much covers the stickout of the wheels, but where it curves in at the bottom, the wheels are exposed a little bit. But the Rally Armor Mud Flaps complement the extended offset of the Konigs nicely, and protect the paint on both the rear and the front.
    Here's a shot of the front and rear of the front tires turned. Just barely enough clearance.
    The whole rim/tire combo is 1" over stock, and weighs 58.3lbs. The OEM 17" rims with OEM highway tread tires weigh 61lbs.
    I'm really loving the look of these wheels! Now I need to BHLM my headlights to match better.
  20. Mar 1, 2016 at 4:24 PM
    #120
    NordidiroN
    NordidiroN Well-Known Member
    Ron
    Georgia
    '15 DCSB SR5 4x4
    Retrax MX Pro bedcover, Avid bumper gaurd, Predator step rails, Aux D rings, Door sill protectors
    Anyone running type X in 16x8?
    :pray:
    Pics plz
    maronesjsk8 likes this.
