KPT's Earth thread
Discussion in 'Jobs & Careers' started by PreRunner03, Mar 15, 2012.
  1. Mar 17, 2012 at 8:41 AM
    #221
    scocar
    scocar hypotenoper
    lol. It's mostly to make sure that there's no known or potentially existing fossily stuff of some value (like, for Ben's amusement) in the area before they start excavating, drilling, mayhemming.
  2. Mar 17, 2012 at 8:47 AM
    #222
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Little River Band or Hall & Oates would be my guess.
  3. Mar 17, 2012 at 8:51 AM
    #223
    scocar
    scocar hypotenoper
    :rofl:
  4. Mar 17, 2012 at 9:36 AM
    #224
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    Well played ... very well played!:laughing:
  5. Mar 17, 2012 at 9:51 AM
    #225
    MTgirl
    Weesa
    Bob's secret mod lair
    Somebody tell me what these rocks are called
    up close
    and there is a large grouping of them. nothing else like them in the area
    In the sunlight they have a black-blue shimmer to them - sort of looks like graphite if you scribble on a page with a pencil really heavily. Indoors under artificial light you can't see the blue. The rocks all seems to be some type of sandstone and the black is just a thin layer on the outside. The area was volcanic at some point and there is a volcanic cone nearby if that matters at all.
    I have a small chunk of the rock, if it gets sunny enough later I can gets pics of it.
  6. Mar 17, 2012 at 9:57 AM
    #226
    acdronin
    acdronin Well-Known Member
    ^ IDK, volcanic basalt?
  7. Mar 17, 2012 at 10:18 AM
    #227
    jjew18
    Alliance Airport
    05 PreRunner SR5
    Asteroid/meteor?
  8. Mar 17, 2012 at 10:19 AM
    #228
    acdronin
    If that was the case, those would be worth a fortune
  9. Mar 17, 2012 at 10:21 AM
    #229
    jjew18
    Alliance Airport
    05 PreRunner SR5
    Dibs
  10. Mar 17, 2012 at 10:22 AM
    #230
    MTgirl
    Weesa
    :woot: and only I know where they are!!!!
  11. Mar 17, 2012 at 10:37 AM
    #231
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    Rocks are fun, I'll spend some time in here.
  12. Mar 17, 2012 at 10:50 AM
    #232
    jjew18
    Alliance Airport
    05 PreRunner SR5
    Not good, you should be quarantined, those are usually highly radio active! Has that 3rd ear grown yet or do you have any abnormal strengths that you would not usually have?
  13. Mar 17, 2012 at 12:44 PM
    #233
    BenWA
    BenWA Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
    What KPT said. Looks like "desert varnish" AKA rock varnish, which is essentially a weathering phenomenon on the outer surface of rocks that contain clay minerals that weather into manganese oxide -- something you might commonly see on sandstone in a relatively dry arid place.
  14. Mar 17, 2012 at 12:58 PM
    #234
    tacomalex
    tacomalex Well-Known Member
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    Why even try to do look more like?
  15. Mar 17, 2012 at 1:46 PM
    #235
    MTgirl
    Weesa
    That makes sense that it could be an effect of weathering. If you notice the rocks higher up have more color, those lower to the ground (and below snowpack most of the year) and in the water have less color to them. Is this very common? I can't say I've even seen it before. And its weird that the sunlight has an effect on the coloring as well...
    English?
  16. Mar 17, 2012 at 2:05 PM
    #236
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    What kind of rock did the aliens make the Sphinx out of ?
  17. Mar 17, 2012 at 2:15 PM
    #237
    scocar
    scocar hypotenoper
    It's a hunk of magma covered in a thin layer of fecal matter.
  18. Mar 17, 2012 at 2:17 PM
    #238
    MTgirl
    Weesa
    Well that explains New Jersey....what about the rest of the planet?
  19. Mar 17, 2012 at 2:25 PM
    #239
    98tacoma27
    Ben
    Not Beech Creek
    No...........but my tweed coat is at the cleaners
    No
    I see a lot of it in Moab. It has a weird shimmer when viewed through a polarize lens.
  20. Mar 17, 2012 at 2:26 PM
    #240
    jjew18
    Alliance Airport
    05 PreRunner SR5
    Time to put down the Guiness.
