KPT's Earth thread
Discussion in 'Jobs & Careers' started by PreRunner03, Mar 15, 2012.
  1. Apr 13, 2012 at 7:02 AM
    #661
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Well you see Ben... When your at the bar and you've lathered yourself in bait..
    ... I'm not the biggest fan of fried anything :puke:
  2. Apr 13, 2012 at 7:05 AM
    #662
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    You're definitely not american :oldglory:
  3. Apr 13, 2012 at 7:07 AM
    #663
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    4 minutes aint bad for this early in the morning :D
    lol nope, definitely not
  4. Apr 13, 2012 at 7:07 AM
    #664
    xJuice
    Josh
    N. Texas
    19 Tundra MGM
    Yours was more detailed and informative :)
    No hard feelings, Beth :p
  5. Apr 13, 2012 at 7:09 AM
    #665
    bethes
    bethes Señorita Member
    Beth
    Tulsa/Sand Springs, OK
    2011 V6 TRD Off Road
    Ha! I was about to say, "it's cool Keith, your answer was more complete."
    Man. Now I want a fried pie.
  6. Apr 13, 2012 at 7:10 AM
    #666
    98tacoma27
    Ben
    Not Beech Creek
    What's the most commonly fished item? Broken bit?
    :turtleride:
  7. Apr 13, 2012 at 7:17 AM
    #667
    bethes
    Beth
    Probably the cones off a tricone bit. If they try to use the bit too long, push it until it's as dull as it can possibly be, it falls apart, and they have to retrieve the parts from the wellbore.
    3 times through I've seen fishing trips for the entire bottom hole assembly- that's the bit, motors, steering tools, MWD tools (measurement while drilling, used to tell you where the drill is), etc. Pricey there.
  8. Apr 13, 2012 at 7:18 AM
    #668
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    How long would it take to fish out all of that stuff?? :eek:
  9. Apr 13, 2012 at 7:26 AM
    #669
    bethes
    Beth
    I've seen them fish for 10 days and not recover the equipment. All that bottom hole assembly stuff is supposed to be screwed together in 1 piece, the hard part is grabbing it and keeping hold of it until you get it 2 or 3 miles back to the surface.
    If they can't recover it they can sidetrack the well, which means they find a point in the original wellbore where they can start drilling in a different direction and go around the equipment. But leaving all that equipment in the well is expensive, so they try not to do that.
    Edit: this time Keith was faster!
  10. Apr 13, 2012 at 7:32 AM
    #670
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    What's +'s and -'s between the tri-cone and PDC's?
  11. Apr 13, 2012 at 7:57 AM
    #671
    xJuice
    Josh
    N. Texas
    19 Tundra MGM
    I like the tri-cone :cool:
    The PDC looks like a big vicious version of some of our glass drilling bits here at work.
  12. Apr 13, 2012 at 7:58 AM
    #672
    bethes
    Beth
    I'm not really sure what is more common, I've seen both used. I'd guess tricones are more common though, especially in the lateral, which is either moderately consolidated sand or sandy dolomite. We even used a button bit once.
    Here's a button bit, for comparison:
    When I was in Oklahoma it was tricone through the vertical as much as possible (there are a couple limestone formations they often had to switch to a PDC though) and then PDC for the lateral.
  13. Apr 13, 2012 at 8:04 AM
    #673
    xJuice
    Josh
    N. Texas
    19 Tundra MGM
    So, I'm assuming the tri-cone, pdc and button bits are used for getting through actual rock only, correct? Do you use just a big auger bit initially until you get to the rock?
  14. Apr 13, 2012 at 8:05 AM
    #674
    bethes
    Beth
    They are built to handle different types of rock. I'm far from an expert but tricones are for softer rocks like unconsolidated sandstones or soft limestones and shales. Harder rocks like a hard limestone or hard shale require a PDC.
    They just use whatever bit the top bedrock layer will require to get through the soil, I think? I've only once been on site at the very start of the well, onsite geology isn't usually needed until later.
  15. Apr 13, 2012 at 8:23 AM
    #675
    98tacoma27
    Ben
    Not Beech Creek
    How does the drilled material return to the surface? I'm assuming the "mud" pushes it back up?
  16. Apr 13, 2012 at 8:29 AM
    #676
    bethes
    Beth
    Exactly! The drilling fluid, or mud, is pumped back up to the surface, carrying the drill cuttings with it. That's where I come in. I take samples of the drill cuttings, clean the drilling mud off of it, and analyze the rocks That's about half of the substance of my job, and about 75% of my time.
  17. Apr 13, 2012 at 8:29 AM
    #677
    98tacoma27
    Ben
    Not Beech Creek
    How is the mud captured at the top?
  18. Apr 13, 2012 at 8:29 AM
    #678
    98tacoma27
    Ben
    Not Beech Creek
    :turtleride:
    Edit: I could handle that. It would go something like this:
    Me looking at cuttings: *...bites one with teeth...* "Yep, we got some rocks down there"
    Drill dude: *..hands on hips shaking head...* "Ok genius, what kind of rock?"
    Me with confused look: "Bloody hard ones.........and they don't taste very good.......got any salt? pepper?"
  19. Apr 13, 2012 at 9:13 AM
    #679
    bethes
    Beth
    That's about all I know. I don't get anywhere near the top of the wellbore. It's underneath the rig and there's a lot of equipment and moving parts there; I'd probably just hurt myself :D Also it has nothing to do with my job, so best to stay out of the way. I collect cuttings after they go across the shakers, maybe go talk to the driller occasionally, and otherwise I stay off the rig.
  20. Apr 13, 2012 at 9:54 AM
    #680
    swissrallyman
    swissrallyman Well-Known Member
    2017 Tacoma TRD Sport
    Fellow consulting geologist here! Cool thread, but I'm a hardrock kind of a guy... and preferably underground!
