Kragen 7" HID off road lights, need relay help
Discussion in 'Lighting' started by Marsey13, Oct 21, 2011.
  1. Oct 21, 2011 at 2:48 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    the link in my signature i meant... lol
  2. Oct 21, 2011 at 2:50 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    That adds up to 245 watts (5 x 35), over 20 amps (watts/volts)... yes, use a relay and a switch rated for 30 amps (with a fuse to match)... or two switches.
  3. Oct 21, 2011 at 2:50 PM
    Marsey13
    Marsey13 [OP] Well-Known Member
    Roseville, Ca
    06' Tacoma TRD, 3" leveling kit
    RevTec 3" Leveling kit Bully Bars HID Fog lights 7" HID O-R lights- grill
    Thanks for the heads up. I just became a member on here yesterday.......I should of waited to purchase until I consulted with you guys. Thanks again and I will see if I can return them.
  4. Oct 21, 2011 at 2:51 PM
    97yota4wd
    Eric
    Mesa, AZ
    just let me know dude, no worries if not!
  5. Oct 21, 2011 at 2:53 PM
    ironman_jon
    ironman_jon Well-Known Member
    Jonathan
    Prerunner Sport
    URD TCAI Wicked Flow 18" 2 10in alpine type r 1500 watt amp MB 72 matte black Custom Bumper Debadged Glassworks fenders McNeil bedsides Helix TB Spacer Intake Manifold Spacer Custom Roof Rack 5x 55w HID SK2 projectors 55w DDM 5k Bulbs Camburg Long Travel Fox Coilovers
    I run mine with out a relay work just fine. Like other have said ditch the relay and get you money back. Ive got 4 more of these light for my roof rack, just have to make it.
  6. Oct 21, 2011 at 2:56 PM
    Marsey13
    Roseville, Ca
    Thanks!
  7. Oct 21, 2011 at 3:44 PM
    Marsey13
    Roseville, Ca
    Thanks, I will use this method when I install them. Thanks again.
  8. Dec 21, 2011 at 11:57 AM
    freezb
    freezb Active Member
    montreal
    tacoma trd 2011
    roof rack toyota side step toyota
    what is the amp of a kragen HID?
  9. Dec 21, 2011 at 4:47 PM
    David K
    They are 35 watts, and you are a 12 volt system... so 35/12= 2.9 amps (but I am not an electrician, so I will stand corrected if I am wrong).
  10. Dec 21, 2011 at 4:48 PM
    David K
    Correct, if you are only installing two per switch (70 watts), no relay needed.
  11. Jan 2, 2012 at 3:12 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    So this is an install related question- Where the eff did ya'll put the wire thru from the cab to the engine compartment?? The one bundle that is right there at the driver left foot just doesn't seem like there is any space there.
    This is the first time I've run wire thru front he cab to the engine like this...so I have no clue what is easiest/best.
    Thanks!!!
  12. Jan 2, 2012 at 3:33 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    You found the spot; it's where that bundle goe through the firewall.
    But the bundle itself is full.
    So poke a new hole through the fat gasket that surrounds the bundle.
    I like to go from inside the cab out , because whatever you are poking through can end up poking into a LOT of tiny wires under the dash if you go from the engine side.
  13. Jan 2, 2012 at 3:35 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Efff...Will a wire coat hanger work or is there a better trick? And does the hole need to be sealed with something after I'm done poking??
  14. Jan 2, 2012 at 3:41 PM
    97yota4wd
    Eric
    Mesa, AZ
    i used a phillips screw driver to put a hole in that boot that your looking at. hasnt failed yet!
  15. Jan 12, 2015 at 8:41 PM
    #35
    bruth
    bruth Well-Known Member
    Brian
    Alamo ca
    2000 access cab 4x4 Tacoma
    Total chaos is currently shipping
    How do you guys recommend me running four of these lights to one switch? Power to fuse to relay then to the load and switch?
