Kragen LED/OEM Fog switch
Discussion in 'Lighting' started by Krazie Sj, Jun 8, 2012.
  1. Jun 8, 2012 at 9:13 AM
    Krazie Sj
    Krazie Sj [OP] Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    So I should be getting my Kragen 7" LEDs in the mail soonish. The amp draw on them is 3.5amps per light. I was wondering if anyone knew what whether it was possible to reuse the stock fog switch?
    From what I gather the stock fogs use roughly 7.5amps with a max limit of 10amps on that switch.
    I'm thinking I can either splice it into the wiring, or try to find a harness that will mate with the OEM harness and go that route.
    Any ideas or am I going to burn my truck to the ground?
  2. Jun 8, 2012 at 10:34 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    This would be a safe route but I believe you'll be fine using the stock switch. I've got a stock switch wired to a pair of PIAA 520's and I believe they draw more than your Kragens will.
  3. Jun 8, 2012 at 11:00 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Interesting. I might try just splicing it then and see what comes of that.
