Krull...... the Louisiana Coullion Build
Discussion in '2nd Gen. Builds (2005-2015)' started by ragincajun35, Jan 23, 2014.
  1. Apr 21, 2015 at 3:25 AM
    #381
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    Is that a dent on your tire hump in your bed? I don't know what they are called?!
  2. Apr 21, 2015 at 6:30 AM
    #382
    ragincajun35
    ragincajun35 [OP] Well-Known Member
    Spencer
    Louisiana
    2015 DCSB MG TRD Offroad
    See Builds....
    On the inside? No that is just the lighting.
  3. Apr 21, 2015 at 8:54 AM
    #383
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Yeah ok haha.
  4. Apr 25, 2015 at 6:53 AM
    #384
    kdouget
    kdouget Member
    karl
    louisiana
    05 tacoma prerunner
    flowmaster, nerf bars, lift kit.
    I bet you neighbors LOVE you !!! lol all that night grinding !!
  5. Apr 25, 2015 at 6:56 AM
    #385
    ragincajun35
    Spencer
    Louisiana
    See Builds....
    I usually try and be quick when i have to do it at night. Or close the garage. Grinder is my weapon of choice most times though :anonymous:
  6. Apr 25, 2015 at 8:51 AM
    #386
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Same here haha...
  7. Apr 25, 2015 at 9:51 AM
    #387
    RogueTRD
    RogueTRD Learn to swim...
    Cade
    So. Oregon
    Supercharged '14 Pyrite Mica DCSB 4x4 TRD OR
    Stacked spacer lift, 22x12 wheels with stretched 33's, tow mirrors, bull nuts.
    Yep... Wait a couple weeks and meet me in Moab! haha
  8. Apr 29, 2015 at 2:21 AM
    #388
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    I saw in someone else build that you said you was going to 35's soon are you going to keep your OME lift or change to a different suspension setup?
  9. Apr 29, 2015 at 2:52 AM
    #389
    DrFunker
    DrFunker Well-Known Member
    On your CX cap, why did you go with the double t-handles on the back door?
    Thinking you will say - for added security, but thought I'd ask.
    (I just ordered the same cap yesterday)
  10. Apr 29, 2015 at 7:16 AM
    #390
    ragincajun35
    Spencer
    Louisiana
    See Builds....
    I wish dude!!! I dont know if my rig is quite ready for moab..... but soon!
    There are a couple things that need to take place before i got to 35's......
    1) Regear... 4.88 most likely
    2) ARB air lockers with on board air system
    3) Cab chop
    4) Fender trim
    5) Upper control arms
    But i do not plan on changing out the OME. I have been very happy with it and it is practically maintenance free. I do want to change out the rear shocks though. The rear OME shocks are 13-34 if i remember correctly and i wold like to go with a longer travel shock to take advantage of having flipped my shackles. To do this I will prob go with the BAMF shock relocate and some longer shocks. But the OME dakars and front coils are here to stay.
    I did the double T handle on the rear just for a simpler system. The single has cables and latches. The guy at the camper place recommended that if i dont mind having to open two that i should go that route because if the cable malfunctions then i wont be able to open the rear. However i do plan on mounting a single t handle in the middle just to have a central place to pull from when i have things in my hands. I have found some mock T handles that can be mounted to the center so I can open/close the rear with just one hand.
  11. Apr 29, 2015 at 8:19 AM
    #391
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    My new Leer 100R comes standard with the double T handles. Having had both types locking mechanisms previously on other shells I prefer it that way. Yes it takes a bit more time to open but is much more functional in the long run. Kind of like OME suspension as mentioned above. It may not be flashy and have all the gadgets but it is certainly less maintenance.
  12. Apr 29, 2015 at 12:36 PM
    #392
    ragincajun35
    Spencer
    Louisiana
    See Builds....
    Needed to build a set of hi lift jack mounts for the bed....... Turned out pretty good.
    Harbor Freight welder does alright....... nothing a grinder cant fix.
    I may end up shorting them up so i can put my carpeted platform back in. It is super solid though. Made out of 1/4" plate steel and six 1/2" bolts. Its not going anywhere.
  13. Apr 29, 2015 at 12:46 PM
    #393
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
    Nice work on those hi lift mounts!! I need to make myself a set too. I was thinking either those or weld some bolts onto my bed rack and hang it from there. Nevertheless, yours look good. Sweet truck by the way!!!
  14. Apr 29, 2015 at 1:12 PM
    #394
    ragincajun35
    Spencer
    Louisiana
    See Builds....
    Thanks dude!
  15. Apr 29, 2015 at 1:34 PM
    #395
    ragincajun35
    Spencer
    Louisiana
    See Builds....
    AWWWWWWW YEEAAAAAAAAA!
  16. Apr 29, 2015 at 2:20 PM
    #396
    Base Camp
    Base Camp Instagram: @willismtc
    Willis
    Roanoke, VA
    '14 Base Model 4x4
    Those mounts are built like a brick shit house!
    Oh btw. Congrats on the tent!!
  17. Apr 29, 2015 at 4:48 PM
    #397
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Tent city!
  18. Apr 30, 2015 at 7:00 AM
    #398
    Cmurder
    Cmurder 2011 TX TRD Offroad
    B.C.
    Kansas City
    2011 TX TRD Offroad
    nothing cool
    Awesome build thread man. You've really done a lot to it.
  19. Apr 30, 2015 at 7:18 AM
    #399
    ragincajun35
    Spencer
    Louisiana
    See Builds....
    Thanks dude!
    Cmurder[QUOTED] likes this.
  20. Apr 30, 2015 at 7:20 AM
    #400
    ragincajun35
    Spencer
    Louisiana
    See Builds....
    Got the tent and awning mounted up. Pictures from our trip to come soon.
    karmapolice and cjacob like this.
