KTJO 4x4 one touch window up and down
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by Broadrunner, Feb 17, 2022.
  1. Feb 17, 2022 at 1:29 PM
    Broadrunner
    Broadrunner [OP] Well-Known Member
    KTJO 4x4 one touch window up and down. Condition is used. Location is Houston Texas.
    Sold as of Thursday February 17, 2022
  2. Feb 17, 2022 at 1:38 PM
    Shaggy1215
    Shaggy1215 Well-Known Member
    2021 mean green taco
    So if I want the window part of the way down how does that work and do these install on the driver door or in the doors I want this feature on
  3. Feb 17, 2022 at 1:41 PM
    bretts
    bretts Well-Known Member
    Pasadena, TX
    98 Tacoma Regular Cab 2WD
    works on whatever door(s) you install them on and basically if you touch the window switch it'll auto roll it down/up. If you want to roll the window down half way you'd... roll the window down half way, the same way you do it right now.
  4. Feb 17, 2022 at 1:42 PM
    Broadrunner
    You can override the one touch up and down by using the window power button to control where you want the window at. I don't know about any other trim lever but if you have the TRD Sport, TRD Off Road, Limited, and TRD Pro trim then the driver side door already have the automatic one touch up and down on your truck.
  5. Feb 17, 2022 at 1:46 PM
    Shaggy1215
    I have the sport it has them for the front windows but not the rear so if I hooked them to the master switch i could one touch up or down the rears as the driver but if I hooked them to the rear switches then the master switch would function as normal but the rear passengers could one up and down from their seat is that correct
  6. Feb 17, 2022 at 1:49 PM
    Broadrunner
    You would just hook each module to the 2 back window. From there, the passenger in the back seat will have the one touch up and down when they operate the back windows. Even with the modules hooked up to the back windows, the driver side master switch will also have the one touch up and down for the rear windows as well.
  7. Feb 17, 2022 at 1:50 PM
    Shaggy1215
    OK I'll take them if you will ship them to me 48849
  8. Feb 17, 2022 at 2:28 PM
    Broadrunner
