Ktjo tailgate lock kit failure
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 92se-r, Feb 12, 2025.
  1. Feb 12, 2025 at 5:44 PM
    92se-r
    92se-r [OP] Well-Known Member
    Anyone have the ktjo tailgate lock fail on them? Seems like solenoid went bad on mine. 75% of time it's a faint clunk and won't unlock my tailgate and I need to use the key. Sometimes it works.
  2. Feb 12, 2025 at 5:47 PM
    MGMDesertTaco
    I bought oem, still works.
  3. Feb 12, 2025 at 5:54 PM
    92se-r
    How much was that kit?;;I bought this like 4 yrs ago
  4. Feb 12, 2025 at 5:58 PM
    MGMDesertTaco
    BraveRifles3, 92se-r[OP] and t0p_d0g like this.
  5. Feb 12, 2025 at 6:09 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    I sure hope mine doesn’t fail it was installed by Southeast Toyota Distributors and I hear they sometimes install the Pop and Lock which is inferior to the OEM per the internet.
  6. Feb 12, 2025 at 6:26 PM
    Willy Lump Lump
    Willy Lump Lump Well-Known Member
    21’ dcsbmt
    This and that
    Ktjo?! A failure?! :popcorn:
    Dryvah, Malvolio and 92se-r[OP] like this.
  7. Feb 12, 2025 at 7:00 PM
    92se-r
    Lol do they have issues with their parts?
    2010HDFatboy likes this.
  8. Feb 12, 2025 at 7:20 PM
    Willy Lump Lump
    21’ dcsbmt
    This and that
  9. Feb 12, 2025 at 7:27 PM
    kent50
    kent50 Well-Known Member
    Kent
    Gold River California
    2017 Tacoma Sport DCSB MGM
    3" Lift XD Wheels 33" K02s Predator Steps TRD Oil Cap Backflip Bed Cover Factory All Weather Mats WeatherTech Bed Mat TRD Pro Shift Knob Vinyl Air Bag Decal Covers Vinyl TRD and Tacoma Inserts Factory Mud Flaps Factory Remote Start Factory Door Sill Protectors Console Organizer and Tray Pro Fogs Grill Mounted LED Light Bar TRD Faux Grill DeBadged TRD Sport Door Emblems Factory Bed Lights Pop Lock Tailgate Lock Rear USB Ports DIY Power Panel
    It might not be the solenoid. If it's actually trying to lock/unlock then the solenoid might be fine. You might check and see if the linkage is binding or maybe just needs some lube.
    Jaragon and 92se-r[OP] like this.
  10. Feb 12, 2025 at 7:28 PM
    kent50
    Kent
    BTW KTJO seems to have a bad rep here but I have/had many of their 3rd Gen parts and never had an issue.
    09 Redneck likes this.
  11. Feb 13, 2025 at 12:42 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    There’s more than one that believe they’re the same, but I can’t prove. Either way, my PnL has been going 6 years, so I wouldn’t say it’s inferior.
    musicisevil and t0p_d0g[QUOTED] like this.
  12. Feb 13, 2025 at 4:30 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    Bad choice of an adjective, it was some crap I read somewhere I’m sure the pop and lock is just as good as OEM.
    BraveRifles3 and Chew[QUOTED] like this.
  13. Feb 13, 2025 at 5:21 PM
    92se-r
    Absolutely true. It's one thing I'm going to look at this weekend
    BraveRifles3 likes this.
  14. Feb 13, 2025 at 6:44 PM
    LFOD
    LFOD Well-Known Member
    2021 SR5 DCSB
    I had a pop n’ lock on my 05 worked great for about 6 years then it started to do exactly what you are describing. Pulled the tailgate panel, cleaned the linear actuator shaft, a few drops of tri-flow, moved the actuator manually a few times and it worked perfectly until I sold it in 2017.
  15. Feb 13, 2025 at 9:17 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    My pop n lock was sounding weak after like 4 years. I lubed it up and it was good as new.
    BraveRifles3, Jaragon and 92se-r[OP] like this.
  16. Feb 15, 2025 at 3:13 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    My Son's factory tailgate lock just failed a few days ago. We had to force entry through the factory cover damaging it but I had another cover on hand. So, we accessed the tailgate lock and had to remove the actuator and go back to stock for now. I don't think he is going to replace it and keep it stock for now. My OEM unit has been flawless, keep in mind both ours are 2018 and the units have been in for like 4 years. He has driven his 100k miles and I have 30k miles garaged everyday so maybe that has something to do with it.
  17. Feb 15, 2025 at 6:49 AM
    92se-r
    Why would you have to force entry? Why not just use key?
    Chew and t0p_d0g like this.
  18. Feb 15, 2025 at 8:33 AM
    TC_Mic
    TC_Mic Well-Known Member
    State of confusion, aka Flori-duh
    2017 Silver Sky 2x4 Limited
    AMP Powerstep, UC Flex, bed lights, Opt7 Tailgate bar, black tailgate lettering Pending: re-configure tail light,s custom storage pocket bags, pinch weld painting, blackout badges, ......
    My Taco is a 17 and the tailgate opener is OEM. Kent50 is correct.
    I had similar issue with it trying to lock and unlock but failing to do the job. I opened up the tailgate and noticed it had a LOT of grease, which was dry and caking up, where the linkage and actuator interface. I cleaned off the old grease with a rag and solvent. Testing it with no grease the lock/unlock function worked flawlessly. I applied some red grease that I had handy and retested. Perfect function. The next near freeze we had here in FL, it was sluggish. Worked after multiple attempts but was clearly working. With temps back up to the normal or slightly higher for my area it has not missed a beat.
    Moral of the story is after 7-8 years the grease may be thickened with dirt and age. Clean it off and replace it with one appropriate for your area temps and you will likely be fine for a few more years.
    92se-r[OP] likes this.
  19. Feb 15, 2025 at 8:46 AM
    92se-r
    Great idea guys. Will be checking today now that it stopped raining.
  20. Feb 15, 2025 at 10:23 AM
    Koolbreeze7
    Koolbreeze7 GRILL MAN
    Jon
    Jersey
    2017 TRD Sport 4x4 DCLB Black, Trail Limo. RIP- 2009, 2000, 91,89,87 trucks
    Rigid pod fogs, SpartanX stealth grill and hood LED's, 17" SEMA's on 275/70/17 Falken Wildpeak AT3W's, Fox 2.0 on all corners , TRD CAI, LEER 100XQ Blacked out, w/ Thule racks, and Cargo slider Flow master American Thunder "dual" exhaust, remote start, tint, TRD Pro grill and TRD shadow graphics, Alcan custom 8 leaf Spring Pack
    I bought the Amazon chinesium one for the LB, must be binding, because it sounds but does not unlock. I'm living with it until the Spring
