KYB Shocks/Coil Assembly.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gabericks1, Aug 27, 2024.
  1. Aug 27, 2024 at 3:33 PM
    Gabericks1
    Gabericks1 [OP] Member
    Gabe
    2006 Tacoma Offroad
    None
    Hey, I just received my KYB SR4464 &3 replacements. Thief replacements have a 3/4-in silver cap at the top that current shocks do not have. I just shot kyb a message but does anybody know what that extra plate is? I just want to make sure I have the right replacement before I take these off.
    Thanks
  2. Aug 29, 2024 at 12:18 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    Welcome to Tacoma World. Got any pictures to show what you are looking at?
  3. Aug 29, 2024 at 12:51 PM
    Gabericks1
    Gabe
    2006 Tacoma Offroad
    None
    I sure do and I figured it out. The "K" and the product number means that it is a leveling shock/coil. I got these at such a good price from Rock Auto, I'm going to keep them and level my 2nd gen Tacoma a bit. I looked them over and they seem to be legit genuine KYB parts. From what I understand, I can just pull and replace these and not replace the other equipment. I recently replaced my upper and lower control arms as well as sway bar links. My tie rod ends are in great shape. Does anybody recommend disconnecting control arms sway bar links? If anybody can tell me something I'm missing in this job it would be appreciated.
  4. Aug 29, 2024 at 12:54 PM
    545 Well-Known Member
    2015 Access Cab
    That’s a spacer
  5. Aug 29, 2024 at 2:04 PM
    Knudsen
    Knudsen Well-Known Member
    Jon
    2008 Access Door TuRD
    To bet installed: bling grill, headlights, fog lights.
    Welcome aboard @Gabericks1 :cheers:
    I’m looking for rear shocks and forgot to check rock. Nothing fancy, just want to get the rear leafs dampened. Feels like it hops around a bit when both rear tires hit a bump.o_O
  6. Aug 29, 2024 at 2:24 PM
    Gabericks1
    Gabe
    2006 Tacoma Offroad
    None
    yeah, they call it a striker plate, but its pretty much a spacer. Thanks so much everybody.
    Knudsen likes this.
  7. Aug 30, 2024 at 7:31 AM
    isdjww
    isdjww Well-Known Member
    Pinewood Springs, CO
    2014 AC, 4.0L, 4X4, 6MT
    Not sure, but might be worth mentioning...
    Lift/jack both sides of the truck, not just the side you are working on.
  8. Aug 30, 2024 at 7:39 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    You will need to disconnect the sway bar and get it out of the way to get the coilovers in. You will likely have to pry down on the lower control arm to get the bottom into the bucket, and having someone help to get the bolt in may be necessary. Alternatively, you can loosen the LCA bolts and let it drop -- you will need an alignment anyway. Or disconnect the spindle from the UCA ball joint.
