l.e.d. interior light, I already did but?
Discussion in 'Audio & Video' started by Blacktacoma1, Feb 16, 2020.
  1. Feb 16, 2020 at 10:37 AM
    Blacktacoma1
    Blacktacoma1 [OP] Well-Known Member
    Jay
    2018 access cab utility pkg 2.7
    This is for a work van sorry to post here but i was hoping for a quick response. I did some research online but couldent find an awnser to this specific question. I bought a 12v led light off Amazon(like 2.4w/180 little leds) and just tapped it into the harness that plugs into the dome light. its working fine right now but is this gonna be ok? should i put somekind of fuse? should i wire it somewhere else? i was hoping to keep it like this i want it to work with the dome lights when the door opens...
  2. Feb 16, 2020 at 10:44 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    I'm no electrical guy but I think your ok IF the light is working properly and after being on for 10 minutes or so the wires are not getting warm.Not the ones you spliced into nor the light wires.
    I think in a cargo van all the wires are exposed to the hand/eye, correct?
  3. Feb 16, 2020 at 11:22 AM
    Not a golfer
    Not a golfer Well-Known Member
    Calgary, Alberta
    2012 TRD Sport Double Cab Barcelona Red
    You'll be fine if you tapped after the fuse on that circuit. It's only 2.4 watts so you're adding only about 1.5 amps of load and most circuits are designed to exceed by a small amount from the factory (they never design and load a circuit to its max).
  4. Feb 16, 2020 at 12:14 PM
    Blacktacoma1
    Jay
    yah theyre all exposed along the top corners, and i left them on a few minutes to see if anything happens. looks good and theyre definitely after the fuse.
  5. Feb 16, 2020 at 12:19 PM
    Blacktacoma1
    Jay
    as far as i know 12v lighting is pretty simple or i wouldent have messed with it but i had to put something there is only these 2 little halogen dome lights that dont light up more than 1ft around the light lol.
  6. Feb 17, 2020 at 10:08 AM
    Not a golfer
    Calgary, Alberta
    I hear you on the poor lighting in many vehicles. Changed all my interior light to LED in my Truck so I could see.
    Someone had the nerve to turn the dimmer switch down when I turned 50 and now I wear reading glasses.
