L Track Tie-Down System
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2BeersPlease, Feb 9, 2017.
  1. Feb 9, 2017 at 7:17 PM
    2BeersPlease
    2BeersPlease [OP] Well-Known Member
    Received some goodies in the mail today. Four anchors for the corners of the bed and two 6' rails I have to cut down to size.
    Anyone have any experience mounting these on the side of the bed rail? Install is pretty straight forward. Just wondering if there are any Tacoma-specific issues I should be aware of before I start poking holes in the bed.
  2. Feb 9, 2017 at 8:18 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    be aware that you shouldn't tighten down the straps to tight, as it will bend in the bed sides lol
    i have these on mine and love it for being able to tie down everything
  3. Feb 9, 2017 at 8:53 PM
    2BeersPlease
    Ya. The sheet metal isn't too thick there. I'm thinking that having the channel anchored every five inches the full length of the bed rail will help distribute the load on any particular stud fitting.
  4. Feb 9, 2017 at 8:55 PM
    paranoid56
    San Diego
    14 double cab taco
    if you have those full length, you dont need it. mine will pull the whole bed side in.
  5. Feb 9, 2017 at 11:39 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    How are you mounting it to the bed rails? Just drilling holes and using bolts, or are you tapping it?
  6. Feb 10, 2017 at 6:11 AM
    2BeersPlease
    Holes and bolts. I'm wondering if there's a way to reinforce it on the backside, or is the fact that it's bolted every five inches enough.
  7. Feb 10, 2017 at 6:43 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    There would be room for say a reinforcement plate behind the bed rail lip if you needed. Seems like itd be unnecessary but maybe not...
  8. Feb 10, 2017 at 8:18 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    I put the same L-tracks in my bed. I just clamped the track to the inside of the truck bed rail where I wanted it and drilled holes. I can see it flex the bed rail a little when I really crank down a ratchet strap, but it always goes back. I did the front of the bed as well (which is more reinforced), but it was such a pain to get the nuts between the cab and bed without dropping. In the future I plan to get some steel angle that matches the bed rail to reinforce it.
    2BeersPlease[OP] likes this.
  9. Feb 10, 2017 at 9:17 AM
    2BeersPlease
    Good to know. Thanks. I plan to use them for more than taming cargo. I want to make things that attach to the rails, such as a hi-lift jack mount, load bars, or whatever comes to mind.
    These should do the trick.
    [​IMG] [​IMG]
    cruiserguy likes this.
  10. Feb 10, 2017 at 9:21 AM
    nzbrock
    Noah
    San Marcos, TX
    I haven't permanently mounting anything to mine. I did get some of the studs for future use but haven't used them yet. The quick release rings that I have started to rust after about a year. You may want to look into getting the stainless versions if they still have them.
  11. Feb 10, 2017 at 11:09 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Where did you get the rail? How much was it?
  12. Feb 10, 2017 at 11:51 AM
    2BeersPlease
    brywebb11 likes this.
  13. Feb 10, 2017 at 12:50 PM
    ShortHL
    ShortHL a little fun @ work helps it all out
    JohnW
    PNW
    2004 gold Tacoma 4x4
    bed:Rhino coat-blck, gold match Tonneau, dark tint side wndws, tires: Cooper Adventurer HT, washable sheep covers, fog lamps, el cheapo drive lights. & other cheap stuff that works !
    Why don't some of you fancy trucksters have a photo or two of those fancy machines you be putting back there!!!! I bet I could fit a quad but some might prefer a trailor.
  14. Feb 10, 2017 at 1:03 PM
    2BeersPlease
    I don't have any "fancy machines." Nothing about me is fancy. The tie-down system can be used to secure things other than ATVs. For example, I had to bring home two 12' 6x6 posts. There is no way to secure them to the floor; the factory tie-downs are too high. At best, they can only keep the posts from tipping up. That's why I bought the tie-down kit. I plan to use the tracks for things other than securing cargo.
  15. Feb 10, 2017 at 1:15 PM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
  16. Feb 10, 2017 at 1:17 PM
    ShortHL
    JohnW
    PNW
    No prob. same here. Nothing from a silver platter ( afluent parents ).
  17. Feb 10, 2017 at 1:31 PM
    2BeersPlease
    otis24[QUOTED] likes this.
  18. Feb 10, 2017 at 1:42 PM
    ShortHL
    JohnW
    PNW
    Sounds great, some things I can / could do " on top " of Tonneau cover too. It makes one to begin thinking of more possibilities like . . .
  19. Feb 10, 2017 at 2:06 PM
    otis24
    Mark
    California
    I'm on my 3rd sleeping platform. I build one, use it for a year or two, it gets beat up and I decide what I like and don't like about it and build another. I'm about halfway through building this one. I swear it's the last one.
  20. Feb 10, 2017 at 2:48 PM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    ^^ what he said. Too tight and the tailgate will not open as well.
