L Track Tie-Down System
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2BeersPlease, Feb 9, 2017.
  1. Feb 10, 2017 at 3:04 PM
    Thumbelina
    Thumbelina Well-Known Member
    Colorado
    2017 Quicksand TRD OR DCSB M/T "PocketSand"
    I've been planning to use these as well and I'm surprised more people don't use them! Would something like the Total Chaos Bed Channel Stiffeners help out with the flexing?
  2. Feb 10, 2017 at 7:34 PM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    I have had the 48" rails on my to do list for 2 years. Going to mount 2 to the bed floor and 2 to the bed rails. The rails I was going to reinforce with thick aluminum strips a few inches long, sandwiching the bed in between the rail and the strips. My only concern was with the mounting on the floor of the bed. I may end up doing the same with either strips or one long 48" strip if I can find them. I already bought some camlock straps from USCargoControl with s hooks to secure stuff in the bed. I'm getting close to doing this because I want to line the bed with LineX first.
    I like the mounts you got too, but I would like more flexibility with mounting locations. :)
  3. Feb 10, 2017 at 7:43 PM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    Could you unbolt the bed and pull it forward 3 or 4 inches without too much trouble? I want to put a rail up there too and thought of nutzerts but that may be too complicated. Also for mounting to the bed floor, I thought of unbolting the bed and lifting it a few inches so I can get access to the underside.
  4. Feb 10, 2017 at 7:56 PM
    Thumbelina
    Colorado
    I can't find the thread I'm thinking about but someone posted pics of how they set up an l-track in the bed and the underside has all kinds of support struts (if you've got the composite bed) that would make a solid aluminum strip impossible. This guy has a pretty neat set up as well https://www.tacomaworld.com/threads/the-getaway-croms-build-and-adventures.362772/
    If I can find the thread I'm thinking about I'll post it up.
  5. Feb 10, 2017 at 7:57 PM
    Thumbelina
    Colorado
    How are you guys getting the to the back of the bedsides to attach the rails without rivnuts?
  6. Feb 11, 2017 at 7:12 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    Haha that's exactly what I ended up doing. You still need to disconnect the fuel filler as well as the tail lights to get enough room. At that point you might as well pull it all the way off.
  7. Feb 11, 2017 at 10:14 AM
    Xjman1
    Xjman1 Well-Known Member
    JB
    2004 Tacoma TRD 4X4 X-CAB
    King coil overs, Rear shackle lift
    I have two sets at home of the rectangular ones. Going to mount them to bed floor, between ribs to help tie down dirt bikes.
    Post pics of install once done.
  8. Feb 11, 2017 at 10:16 AM
    Xjman1
    JB
    Wrap finger in tape, sticky side out, and place nut on there to get behind bed wall.
  9. Feb 11, 2017 at 12:09 PM
    Thumbelina
    Colorado
    I've seen the video that uses that technique for the front of the bed, but what about the sides?
  10. Feb 12, 2017 at 6:39 AM
    nzbrock
    Noah
    San Marcos, TX
    I put the nut in a box wrench and carefully held it on the backside of the bed with my finger on the back. Then I would thread the bolt in from the front.
  11. Feb 16, 2017 at 1:17 PM
    ShortHL
    ShortHL a little fun @ work helps it all out
    JohnW
    PNW
    2004 gold Tacoma 4x4
    bed:Rhino coat-blck, gold match Tonneau, dark tint side wndws, tires: Cooper Adventurer HT, washable sheep covers, fog lamps, el cheapo drive lights. & other cheap stuff that works !
    B good, what if I don't need any of these customs systems yet. Besides garage hasn't had makeover yet. I'm kind of a fair weather + night off + helper type scenario to all that. Unless its 75* @ 07:00 that might help a bit too.
  12. Apr 17, 2017 at 10:03 PM
    Xjman1
    JB
    Finally tested and got pictures. Worked awesome and did some hungry valley off-roading with bikes and no issues at all. IMG_0675.jpgIMG_0674.jpg
    2BeersPlease[OP] likes this.
  13. May 25, 2017 at 5:36 PM
    BDMcGuire
    BDMcGuire Well-Known Member
    Brent
    Peoria, AZ
    06 Tacoma OR SBDC
    What tie downs are those? I was looking at Mac's Tie Downs but they are a little too wide to fit in the bed channels for the 2nd gen I think.
    Edit: I explored the original website more and found these single ones. Crisis averted
  14. May 25, 2017 at 7:44 PM
    Xjman1
    JB
    Uscargocontrol.com
  15. May 25, 2017 at 7:49 PM
    #35
    Phoosa
    Phoosa I never saw nothing.
    Truck
    Amazon has this as well.
    Comes in longer sections but is cheaper woth free shipping that way
  16. Jun 5, 2020 at 12:11 AM
    #36
    amp3d
    amp3d Well-Known Member
    Mark
    Toronto
    2002 Double Cab TRD Offroad, 2012 Access Cab
    Sorry to bring an old post back to life, but I'm thinking of doing this to my gen1. Little concerned about the strength of the sheet metal though.
    Did you re-enforce the underside of the truck bed or just use normal washers? I ask because mine will be used almost specifically for dirtbikes (and a few sport bikes)
  17. Jun 5, 2020 at 5:11 AM
    #37
    Xjman1
    JB
    It comes with mounting plates for underneath. I have had zero issues with using for dirt bikes and that is on some whooped up desert river bottoms.
