la0d0g's rig
Discussion in '2nd Gen. Builds (2005-2015)' started by la0d0g, Jul 12, 2012.
  1. Jul 12, 2012 at 4:38 PM
    la0d0g
    la0d0g [OP] Its 4 o’clock somewhere
    running for the hills
    For crawling not hauling
    Like others, I wanted to create a thread to track the modifications/changes to my truck and share them with the greater TW community. I’m also going to use this thread to document the trips and adventures I have in my truck.
    2010 Tacoma - Double cab - MGM - TRD Off-road - Manual 4x4
    Truck as of 7/1/15 with 45k on the odo:
    courtesy of skidooman
    Mechanical Upgrades (or whatever you want to call it):
    - 4.56 gears
    - Airflow snorkel
    - URD short throw shifter
    - Magnaflow exhaust, dumped
    Suspension/Wheels/Tires:
    - 315/75 r16 MTRs
    - ProComp 7089
    Front
    - OME 886s
    - OME 9000 Nitrochargers
    - 5mm trim packer
    - TC UCAs
    - Phucka swaybar mod
    - Superbumps
    Rear
    - Dakars
    - Relentless u-bolt flip kit
    - Hacked bump stops
    - 5100 with shock extenders
    Armor:
    - Bud Built skids - IFS and mid
    - Relentless Fabrication t-case skid
    - Relentless Fabrication hybrid sliders
    - Relentless Fabrication HC rear bumper
    - Relentless Fabrication front bumper w/summit hoop
    - BAMF LCA skids
    Extraction Gear:
    - Hi-Lift 60”
    - Hi-Lift off road kit, base, and fix it kit
    - Bow saw
    - Smittybilt mud boards
    - Full length shovel
    - VIAir 300p air compressor
    - Shackles
    - Warn 3”x30’21,600lbs recovery strap
    - Warn M8000 with synthetic line
    - ARB snatch block
    - ARB 3" x 16' tree strap
    - Tire repair kit
    - Warn Premium Winch Hook (read: it has a built in bottle opener)
    External Mods and Stuff:
    - 12” shorty antennae
    - Debadged including TRD stickers
    - OEM non-LED taillights
    - Rear differential breather relocate
    - Satoshi Grille with FJ emblem
    - Bed mat
    - PIAA 510 Super Whites
    - Removed mud flaps
    - Hi-Lift bedrail mounts
    - Quick Fists clamps mounted to bed rails for shovel
    - Bedside bottle opener
    - Relentless bed corner tie down brackets
    - 3" extended steel braided brake lines
    - Chopped fenders and fender flares
    - Bed tube bars and basket for spare tire
    - Extra d-rings in the bed
    - Bed mounted fire extinguisher
    - Relentless CB hood hinge mount
    - 4' Firestik
    - BAMF behind grille light bar
    - 20" double row combo light bar (spot and flood)
    - BHLM
    - DieHard Platinum 31M wrapped in Pelfreybilt battery cage
    - Cubby hole d-ring mod to hold scepter cans
    Internal Mods and Stuff:
    - Tint
    - Seatbelt chime disable
    - Alarm chirp disable
    - First aid kit and duct tape
    - Driver’s seat Maglite holder
    - WeatherTech all-weather floor mats
    - Ultra Gauge
    - Red LED map lights
    - Ultra white LED dome light
    - Cobra 75
    - Wet Okole (black and charcoal)
    - Vinyl flooring
    - Group 31 battery with Pelfrybilt cage
    Future Mods/Gear/Etc
    - Silicone windshield molding
    - Redline hood struts (in possession but not installed)
    - OBA
    - Duel battery and some snazzy fuse setup
    Stuff I Need to Work On/Repair
    - Change spark plugs
    - Form and install pillar brace for snorkel
    - Repair front grille or satoshi OEM grille and replace
    - Redline hood strut install
    Shortly after pickup:
    After debadging:
    ATO Hi-Lift mounts:
    Differential breather mod:
    884s, 5100s, wheels, and tires:
    Budbuilt front and mid skids:
    Getting sliders welded on:
    New Rear bumper:
    Old Rear bumper:
    Bottle opener:
    Starting the work on dremeling out my FJ emblem:
    Attaching the screws to the emblem:
    Satoshi Grille and FJ emblem ready to go:
    Satoshi & front bumper:
    A few pictures from being out and about (from older to newer):
    Stock flexin at Boca
    First time getting stuck in the snow on Peavine
    Peavine
    Knott Creek Reservoir
    The Cold Springs trenches
    In the trenches
    Bud's Canyon
    Milton Reservoir
    Blue Lakes
    Hunter Creek Trail
    Dawn on Peavine
    Thanks for looking and thanks to all that have helped me out.
    Shout out to Relentless Fabrication for making bulletproof goodies!
    I'll be posting more content as I make changes to the truck.
  2. Jul 12, 2012 at 4:41 PM
    brandonn
    brandonn pretend this is a clever saying
    Brandon
    Houston, TX
    Nice truck! Stealin' the bottle opener idea :)
  3. Jul 12, 2012 at 4:48 PM
    la0d0g
    Thanks man, could be one of my favorite mods :cheers:
  4. Jul 12, 2012 at 4:53 PM
    cgs2k2
    cgs2k2 old man
    you inspired me! i just bought a bottle opener to mount in my bed! haha
    also, 884s for the win.
  5. Jul 12, 2012 at 5:00 PM
    Oowen
    Oowen Well-Known Member
    Owen
    Reno, NV
    '22 Cummins
    Are you in northern nevada? If so there is the 775 bs thread to check out
    Nice build!
  6. Jul 13, 2012 at 7:53 AM
    la0d0g
    Thanks, I just subscribed.
  7. Jul 13, 2012 at 8:25 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
  8. Jul 13, 2012 at 10:59 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    As always, looks great matt!
    :thumbsup:
  9. Jul 14, 2012 at 11:26 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    Looks good Matt.
    You should talk to Josh about the 886s they were too stiff with all the stuff he had on his Taco.
    More CS Trenches pics
    Crom likes this.
  10. Jul 14, 2012 at 11:35 AM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    Good looking truck man!
  11. Jul 16, 2012 at 2:31 PM
    la0d0g
    I chatted with Josh about 886s when we were working on my suspension. He told me about them being stiff but I was thinking the 886s would be a good fit with the bumper, winch, and having the sway bar off. Plus I figure the stiffness would match the Dakar's stiffness :D
    Anyone else have any input? 885s or 886s?
    And thanks for posting the pics Randy!
  12. Jul 16, 2012 at 5:02 PM
    4Wheelin4Banger
    Randy
    Josh had bumpers, winch, skids & sliders with & without sway bar, but he only had an AC not a DC so who knows?
  13. Jul 16, 2012 at 6:51 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Josh changed his set up like 3 or 4 times. Nothing seemed to please him.
    I have 886s. Just recently I added 1/2 top plates. I like em just fine.
  14. Jul 17, 2012 at 7:41 AM
    la0d0g
    Yeah, I forgot about the additional weight from the skids. I'll make my final decision next month when I order them but I think I'll be sticking with the 886s.
  15. Aug 18, 2012 at 10:29 AM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    Subbing. Good looking truck.
  16. Aug 20, 2012 at 5:40 PM
    la0d0g
    Relocated my hi-lift from the back of the bed to the passenger side and switched to a shorter handled shovel to accommodate my new corner tie down brackets thingys. They worked great this weekend securing the kayak on our way to the lake.
    These will definitely help with securing my pontoon boat over the action packers on fishing trips.
    Also made sure the Hi-lift was lubed and ready to go while I had it off. Check.
    Festus likes this.
  17. Aug 21, 2012 at 12:59 AM
    krob32
    krob32 Well-Known Member
    Kelly
    Sierra Vista, AZ / Asheville, NC
    2012 MGM TRD Sport DCLB
    WeatherTec Digi Liners, AVS Bugflector II, TRD FJ SE Anthracite Rims, BF Goodrich AT KO2 265/75/16, AVS In-Channel Wind Deflectors, Extang Solid Fold, Pop & Lock, Color Match Grill Emblem (Anthracite), Plasti Dip Emblems, Tacoma Bed Mat, Tacoma Door Sill Protectors, ToyTec Ultimate Lift Kit, ICON UCAs, Wheeler's Progressive AAL, Wet Okoles, Sockmonkey 3rd Brake Light Cover, LED Hood/Bed Lighting w/ OTRATTW Switches, Famous Fabrication Sliders, Sockmonkey TRD Bed Decal, Proven Design 4x4 Mudflaps, BenWA's Rear Power Sliding Window, Jasper Off Road 6" Reverse LED Pod, ImMrYo Rear View Mirror Bracket, GrillCraft w/ Black Mesh and color matched Land Cruiser Emblem, LED Tail Lights, Badge Removal and Vinyl TRD/Tacoma Stickers, Bullaculla Trailer Harness Relocation.
    Nice build. Really like the Satoshi.
  18. Aug 21, 2012 at 7:55 AM
    la0d0g
    Thanks for the compliment. Homer makes a great product!
  19. Sep 24, 2012 at 9:09 AM
    la0d0g
    Dumped my exhaust after the axle this weekend.
    I cleaned up the cut with a file after taking the picture.
    gabbo2112 likes this.
  20. Oct 15, 2012 at 10:36 AM
    la0d0g
    Finished installing my Warn 8000 a couple weeks ago. I lengthened the control box cables to be able to stash it under my hood instead of on top of the winch.
    Used it twice this weekend at Slickrock and it worked perfectly.
