la0d0g's rig
Discussion in '2nd Gen. Builds (2005-2015)' started by la0d0g, Jul 12, 2012.
  1. Nov 28, 2013 at 3:46 PM
    #541
    la0d0g
    la0d0g [OP] Its 4 o’clock somewhere
    running for the hills
    For crawling not hauling
    Yes
    Correct
    Correct
    Happy T-day everyone!
  2. Nov 28, 2013 at 8:19 PM
    #542
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    No spacers right? I'm trying to get everything in order to run 35's but not sure to get the 4.5 or 3.5
  3. Nov 28, 2013 at 9:50 PM
    #543
    la0d0g
    No spacers. I'm running 4.5 but might get some Wheelers steelies @ 4 bs so I don't rub my UCAs. Then I'll rub my frame and cnc more. 315 people problems
  4. Dec 2, 2013 at 12:55 PM
    #544
    la0d0g
    Over the holiday weekend I relocated my horns (only moved one and removed the other) relocated the temp sensor, installed BAMF light holder, finished and installed my OEM headlights with BHLM completed, and installed light bar. I like the output of the light bar, even behind the grille its super bright. I had to do some extra chopping to get it to work with the satoshi.
  5. Dec 2, 2013 at 12:56 PM
    #545
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    Looks slick as hell!
    I'm hoping if I do my satoshi thin-lip the Hellas I have will fit in nicely.
  6. Dec 2, 2013 at 12:59 PM
    #546
    la0d0g
    Thanks! I have an extra grille in my garage that I'm going to do a thin lip version on too. My current one is jacked ever since I pushed a downed tree out of the way and a stray branch stuck into it. Plus the thin lip will free up some more room.
  7. Dec 4, 2013 at 9:26 AM
    #547
    LoadedTaco
    LoadedTaco Kick A$$ Member
    Peter
    Burr Ridge Il
    2012 Red Baja
    Nice job on the lights! Looks great!
    Hey how long did your snorkel installation take?
  8. Dec 4, 2013 at 9:38 AM
    #548
    la0d0g
    Thanks! There is some prep Loctiting the bolts onto the unit but the snorkel install itself took an afternoon. You end up spending most of your time lining up the template, don't want to F that up. After you cut the hole its just a matter of bolting it up which goes pretty fast. The one PITA is getting the nut threaded on the top bolt; you need to be a contortionists to do it.
  9. Dec 4, 2013 at 11:17 AM
    #549
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
    Okay thanks for the heads up. My brother and I are going to do it and we are not big people. Yeah I assumed lining up the template is only kind of an important part. :p
    What did you seal up your cuts with? I am going to hit them with a little paint and silicone the shit out of them.
  10. Dec 4, 2013 at 11:59 AM
    #550
    la0d0g
    I painted the cut and drill holes with MGM touch up paint and then ran some door edge trim around the big hole.
  11. Dec 7, 2013 at 9:15 AM
    #551
    ATLien
    ATLien Well-Known Member
    Portland
    2013 DCSB SR5
    Money Pit
    How do you like your suspension setup? I'm thinking of mimicking your front w/ OME on my 2013 DCSB and going AllPro leafs on the rear.
  12. Dec 7, 2013 at 12:28 PM
    #552
    la0d0g
    I like it. Pretty stiff but that's to be expected. I probably would have gone with LR UCAs if I did not get such a good deal on the Total Chaos ones.
  13. Dec 8, 2013 at 6:14 AM
    #553
    ATLien
    Portland
    2013 DCSB SR5
    Money Pit
    Thanks, I'm hoping to stiffen the rear end cause currently it'll bottom out over speed humps and it doesn't want hold much weight. Would you recommend the 885's over the 886's for the front on a lighter weight truck? I don't have an aftermarket bumper on the front and will go with a Relentless aluminum front when I do.
  14. Dec 8, 2013 at 9:17 AM
    #554
    Traction120
    Traction120 "Not all those who wander are lost"
    Nathan
    Reno, NV
    2013 DCSB BLK
    SEE BUILD.
    I wish I went with 886s.. My two pennies.
  15. Dec 8, 2013 at 5:29 PM
    #555
    la0d0g
    With the aluminum bumper and a winch I think my 886s ride just right.
    But now you're going LT so it doesn't matter :p
  16. Dec 8, 2013 at 5:51 PM
    #556
    Traction120
    Nathan
    Reno, NV
    2013 DCSB BLK
    SEE BUILD.
    True, but I have a steel plate bumper being built, and the 886s would have suited me better in the mean time.
  17. Dec 8, 2013 at 6:03 PM
    #557
    ATLien
    Portland
    2013 DCSB SR5
    Money Pit
    Why do you wish you had them? - Nvm, I see you've got a steel bumper in the post above.
  18. Dec 8, 2013 at 7:22 PM
    #558
    Traction120
    Nathan
    Reno, NV
    2013 DCSB BLK
    SEE BUILD.
    885s are the way to go if you don't plan on adding any front weight. And if they settle too much, you can always add top plate spacers.
  19. Dec 9, 2013 at 6:09 PM
    #559
    gunmetalghost
    gunmetalghost Well-Known Member
    Lamar
    Memphis
    '09 MGM V6 TRD-Offroad
    Nerf-Bars, 3.5" Lift, Linex'ed truck box, Dipped Emblems, Color Matched Eyelids, Satoshi Grill TO COME Satoshi Letters Retrofitted Lights SR8 Wheels Toyo Open Country R/T Tires
    Love this truck!! It is too bad ass! definitely sub'd to watch
  20. Dec 9, 2013 at 6:39 PM
    #560
    la0d0g
    Thanks man! Hopefully I have some worthwhile stuff to post in the future. Need to get my duels hooked up... Thanks for subbin
