la0d0g's rig
Discussion in '2nd Gen. Builds (2005-2015)' started by la0d0g, Jul 12, 2012.
  1. Dec 17, 2014 at 9:44 AM
    #821
    la0d0g
    la0d0g [OP] Its 4 o’clock somewhere
    running for the hills
    For crawling not hauling
    Sorry man, not understanding the Q. Are you asking where to look for them or something else?
  2. Dec 17, 2014 at 9:48 AM
    #822
    Manwithoutaplan
    ID
    where to look. How much did you get yours for?
  3. Dec 17, 2014 at 9:50 AM
    #823
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    TRDPARTS4U 420ish they gave me a discount
  4. Dec 17, 2014 at 9:55 AM
    #824
    la0d0g
    I got mine from expeditioneers:
    http://store.expeditioneers.com/tacoma1.html
    $460/shipped. That was 18 months ago and looking at the site they are still the same price.
    If TRDParts can get them for $420 then that seems like a good deal.
  5. Dec 17, 2014 at 9:57 AM
    #825
    la0d0g
    And to be honest I didn't mind paying that much for piece of mind regarding hydrolocking.
    After I chopped my fenders I had a completely exposed intake and that didn't make me feel comfortable so I needed to make a move.
  6. Dec 17, 2014 at 9:58 AM
    #826
    Manwithoutaplan
    ID
    ic. How long did it take you install it?
  7. Dec 17, 2014 at 9:59 AM
    #827
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
  8. Dec 17, 2014 at 10:01 AM
    #828
    la0d0g
    2-3 hours or so with beer. Its super easy but measuring to cut the hole needs to be accurate so I verified like 10 times prior to going for it :p And it wasn't because I was tentative about drilling into it, I just wanted to make sure all the holes were aligned because if not it would suck!
  9. Dec 17, 2014 at 10:14 AM
    #829
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Probably about the same. I didnt recheck my marks though, just went for it after you get it drilled out though i suggest removing the fender with antenna attached (since its damn near impossible to get the bezel out) then you can reach to put all the nuts on without issue.
    Also, the bolts supplied for the a pillar mount didn't work for me, so used some that i had laying around which i think ill switch out to self-tapping screws probably (the mount is somewhat loose now) plus im gonna shove some silicone in the holes to seal it from water.
  10. Dec 17, 2014 at 10:19 AM
    #830
    la0d0g
    And one last thing. I did loctite all the thread rods into the snorkel females about three days out in preparation so they had plenty of time to dry.
  11. Dec 17, 2014 at 10:23 AM
    #831
    la0d0g
    I had an issue with the mount too. The bracket didn't fit quite right so the screws worked their way out so now I'm not running one at all. Eric was kind enough to fab up a new, longer and more bent style bracket that will work great but I've yet to install it. I'm just running around with holes in my pillar for now :anonymous:
  12. Dec 17, 2014 at 10:25 AM
    #832
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    Loctite, yes but I didn't put the a pillar mount on it doesn't vibrate enough to make me shit my pants
  13. Dec 17, 2014 at 10:30 AM
    #833
    la0d0g
    Agreed, if I could do it over again I would have listened to Spoon and never installed it at all. Now I feel like I need to do something with the holes.
  14. Dec 17, 2014 at 10:31 AM
    #834
    Manwithoutaplan
    ID
    so the pillar bracket doesn't really work from what i gathering??
  15. Dec 17, 2014 at 10:33 AM
    #835
    la0d0g
    It can work I've just found its not necessary and it gets f'n windy where I live.
  16. Dec 17, 2014 at 10:36 AM
    #836
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Guess i could do that as well. Holes plus a scratch through the paint from it wiggling isnt too bad.
  17. Dec 17, 2014 at 10:36 AM
    #837
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    I don't have the pillar bracket and when I made the trip to Santa Fe then to Colorado up Pikes Peak it never seemed unstable
  18. Feb 17, 2015 at 10:14 AM
    #838
    la0d0g
    I've let the love go for too long and I need to do some things to the ride. Making a list is always fun
    • Wash exterior and clean interior (its literally been 4 months since any cleaning has happened to any extent)
    • Install flyzeye :anonymous: I've sat on this great piece of equipment for almost 14 months which is lame
    • Remove rust and repaint sliders
    • Install vinyl flooring, oh hell yeah! :D
    • Change oil
    • Rotate tires
    • Spark plugs
    • Grease driveshaft
    • Get an alignment
    • Diagnose and try to fix dash rattle
    • Glue rear window rubber molding back in place
    Crom likes this.
  19. Feb 17, 2015 at 2:08 PM
    #839
    Fonzi25
    Fonzi25 Well-Known Member
    Jaime
    Sparks, NV
    2011 Tacoma TRD
    Yup that was the one! :D
    really do like the truck man can't wait to get out of the Marines and head back home so i have a little more focus time on my 'build'
  20. Feb 17, 2015 at 2:24 PM
    #840
    la0d0g
    Thank you sir! I need to focus on getting everything tightened back up. For only having 40k miles it needs some work. I feel bad :p
