Lack of power...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CycleMan, Jul 15, 2018.
  1. Jul 15, 2018 at 8:15 PM
    CycleMan
    CycleMan [OP] Member
    2012 White access cab TRD Off Road
    TRD Pro wheels
    Yes. I had two of them. I would have got a third one but they don't make them any longer unless you get four wheel drive. That's why I now have the TRD Sport so I could get the two wheel drive.
  2. Jul 15, 2018 at 8:21 PM
    Snatch Me
    Snatch Me Yeehaw
    PBC FL
    Cement TRD OR 4x4 DCSB
    Put your foot into it and it will quit ‘gear hunting’.
  3. Jul 15, 2018 at 8:27 PM
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    Yes. That is a thing.
  4. Jul 15, 2018 at 11:56 PM
    RyanL
    RyanL Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
    inb4 ect, OVtine
    Help me understand why you recommend it for the manual when you have an auto?
  5. Jul 15, 2018 at 11:58 PM
    Audert
    Audert Well-Known Member
    2017 Tacoma Sport
    3rd gen tacoma basically has a car engine in it.... and there really isn't anything wrong with changing to a higher gear when climbing a hill....
  6. Jul 16, 2018 at 12:15 AM
    FrayAdjacent
    FrayAdjacent Well-Known Member
    Matthew
    Austin, TX
    2017 Tacoma SR5 4x4
    It's not a lack of power, it's a lack of putting your damn foot down. People seem to think it's horrible if an vehicle downshifts and revs above 3000RPM. If it does that, it must not have any power.
    TacoCon likes this.
  7. Jul 16, 2018 at 4:08 AM
    sdsurfer
    Dirk
    San Diego
    DCSB TRD 4X4
    They still make them. See them on the road all the time.
  8. Jul 16, 2018 at 4:27 AM
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    Easy, trade that is and get the MT :burnrubber:. You get to shift when you want to & 4.30 rear-end:benchpress:
    MOC221_ and shakerhood like this.
  9. Jul 16, 2018 at 5:22 AM
    necrodiety
    necrodiety Well-Known Member
    Orlando
    2018 Silver TRD Sport
    OV Tune, Bakflip F1, Redline hood struts, faux pro headlights and tails, Meso: bucket, map and dome lights, fuse cover.
    The OV Tune kit works with the 18. Flashed mine, no DTC's.
    MOC221_ and Scott W[QUOTED] like this.
  10. Jul 16, 2018 at 5:24 AM
    Pine State
    Pine State Well-Known Member
    Maine
    2018 Tacoma DCSB SR5 4x4
    You dont have less power, you have a different transmission. If you dislike the gearing then put it in S5 or S4 and it will be a lot better.
    DoorDing likes this.
  11. Jul 16, 2018 at 5:26 AM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    We took the Taco from the flat sea levels of Louisiana to Denver (5280ft above sea level) and surrounding areas (Golden Gate Canyon ~9800ft, Mount Evans 14,256ft) a couple of weeks ago. Going up and down the steepest of grades, we pretty much stayed in 1st and 2nd gear. Of course, the speeds were slow, but this truck just likes the rpms better.
    Maybe one of the tuning packages can help you, but the truck did do just fine by keeping it geared where it wanted to be.
  12. Jul 16, 2018 at 5:40 AM
    Robb_D
    Robb_D Well-Known Member
    Robb
    FoCo
    2016 BBP Tacoma DCSB TRDOR
    285/70 17 BFG AT KO2
    5th and 6th are both overdrive gears. When climbing a long grade I bump the shift lever to S mode and use S4, and if it starts going back and fourth between 3rd and 4th I will bump over to 3rd.
    I am curious and would be interested to see how some of you actually drive.
  13. Jul 16, 2018 at 5:42 AM
    Pine State
    Maine
    From the sounds of it everyone thinks they have a diesel and cant rev past 3k RPM
  14. Jul 16, 2018 at 6:02 AM
    rickm
    rickm Well-Known Member
    Rick
    MA
    2018 BLK Tacoma TRD Pro
    I towed my Polaris Ranger the other day. Put the ECT on, S mode 4 the highest gear. Hit a steep grade, gearing dropped to 3rd and had no problem maintaining speed at around 3500 rpms. The truck works for me!:D
  15. Jul 16, 2018 at 7:08 AM
    #35
    skiploder
    skiploder Well-Known Member
    Somewhere NE of Kanab
    FZJ80/XJ LS swap
    Quoted for truth.
  16. Jul 16, 2018 at 11:40 AM
    #36
    fortis44
    fortis44 Well-Known Member
    Colorado Springs, CO
    2016 TRDOR DCSB Black
    OME Nitros, 888s, HD Dakars, 285s
    How long have you been driving it? The transmission might still be in a learn phase and trying to figure out how to adjust to your driving habits. You also might be adjusting to a new truck. I came over from a stick shift mustang, and the automatic drove me nuts on the Tacoma for a bit. I've adjusted and have zero issues now.
  17. Jul 16, 2018 at 12:51 PM
    #37
    GTS Bruce
    GTS Bruce Well-Known Member
    W
    Your right foot will hopefully learn to modulate better. No need for a pedal this,etc,tune or anything else if you can adapt
  18. Jul 17, 2018 at 7:03 AM
    #38
    Scott W
    Scott W Well-Known Member
    Scott
    Saranac Lake, NY
    2018 Tacoma TRD PRO. Calvary Blue.
    TRD Performance Air Intake. TRD Shift Knob. KTJO 4X4 Red TRD Push Button Start/Stop. Calvary Blue FOBIK by AJT Design. 12volt Solutions Remote Start with CAR:LINK Smartphone Remote Start and GPS app. Sprint Booster V3 Throttle Response Enhancer. AFE Silver Bullet Throttle Body Spacer 46-38010. 2" Supreme Suspension Lift Kit. TOYO 265/75R16 Open Country A/T2. EGR Matte Black In-Channel Vent Visors. REK GEN Offroad Mud Guards. AMP RESEARCH Power Steps. JDMastar 10000lumes LED Low Beam Lighting T1. JD Mastar Raptor LED Lighting. TRUXEDO Tonneau Cover.
    As an auto tech I work on and drive manuels. I don't like how the ect and pcm control the throttle in put. It is set up for gov emissions and mpg. The is no quick throttle reponce like a trad cable. I am kinda old school when it comes to that.
