Ladies size spare
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MikeDeason, May 12, 2025.
  1. May 12, 2025 at 6:34 AM
    MikeDeason
    MikeDeason [OP] Well-Known Member
    My daughter will be taking over my Tacoma and I want her to have a small manageable spare that she can limp home on. Smallest and lightest combo possible. She’ll always be within 50km of home.
    truck has 33’s
  2. May 12, 2025 at 6:38 AM
    1 Limited Toyota
    1 Limited Toyota ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    Would be an issue putting an itty bitty on with 33's
    hayjohn, Torspd, SomeGuy_GRM and 2 others like this.
  3. May 12, 2025 at 6:40 AM
    MikeDeason
    Yea. Not on all 4. Just big enough to safely drive home. No highway and within 50km
  4. May 12, 2025 at 6:46 AM
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    You really only have to lift a spare tire about an inch (2.5cm) off the ground, but if it was me I would get a skinny 32" it should be about 15lbs lighter than a 33"
    Is she just going to leave the old tire laying on the side of the road, because the flat tire is the hard one to lift
    Steve_P, Jacob99, POOLGUY and 8 others like this.
  5. May 12, 2025 at 6:46 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If you're worried about her being able to handle a 33 inch tire, she's still going to have to get it off the axle and put it in the back of the truck.. is she going to leave it beside the road because it's too big to handle?
  6. May 12, 2025 at 6:47 AM
    Peter603Taco
    Peter603Taco Well-Known Member
    Peter
    New Hampshire
    2013 TRD Sport DCLB
    Is the 31" OEM spare under the bed not an option? I suppose you could get something smaller to put under there but I would think if you're physically able to get the lug nuts broken off and the old tire off and into or under the bed then you'd also be able to get the new one on (especially if a bit smaller). Practicing in the driveway to get an efficient technique down could be more helpful.
    POOLGUY likes this.
  7. May 12, 2025 at 6:56 AM
    MikeDeason
    She did my winter take off. Issue was getting tire onto the lugs. Off was easier. I don’t want her fighting the lug line up side of the road.
    the donut spare would go in the bed. Stock spare under truck, I will deal with when she gets home.
    No safe donuts ?
  8. May 12, 2025 at 6:59 AM
    Jonah
    Jonah Well-Known Member
    Joe
    Charleston, SC
    2014 TRD O/R 4x4
    It's probably best to get some sort of roadside assistance plan thru your insurance. Changing a tire on the shoulder of a busy highway takes courage these days with all the distracted drivers on the roads.
  9. May 12, 2025 at 6:59 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    Do you know the trick where you lay a big prybar on the ground and use that to get the wheel and tire on? Makes it super easy.
  10. May 12, 2025 at 7:02 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Practice in the driveway. Roll the wheel up onto a block of wood to get it even with the hub. There's little tricks you can do to save your back..
    POOLGUY and Gunshot-6A like this.
  11. May 12, 2025 at 7:03 AM
    MikeDeason
    Failing that what is smallest I can go ?
  12. May 12, 2025 at 7:07 AM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    Get a AAA membership, can of fix a flat, & call it done deal....
  13. May 12, 2025 at 7:12 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Danner488 likes this.
  14. May 12, 2025 at 7:13 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    You can go small as you want, but the truck is going to drive weird with 3 big tires and one small one. It'll steer funny, the drivetrain probably won't like it..
    GilbertOz and SR-71A like this.
  15. May 12, 2025 at 7:14 AM
    Peter603Taco
    Peter
    New Hampshire
    2013 TRD Sport DCLB
    I don't think anyone can give you a definitive smallest size without damage, the drivetrain is designed for them to match. Your rolling tire outer dia would be what should match, so the skinniest width tire on skinniest wheel (lighter) you could find closest to the 33" OD sounds easiest in your case but I think you're making more issues than solving. Not jacking it up higher than needed, rolling tire onto small wood scrap, etc. are all possibilities. Technique and practice to learn how to do something right would be better than a tiny spare, you don't have to bench press the thing.
    SomeGuy_GRM likes this.
  16. May 12, 2025 at 7:19 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  17. May 12, 2025 at 7:32 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    16” forged wheels for sure.
  18. May 12, 2025 at 7:34 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Roadside changes are a no-go for me. Never turn your back on traffic. I would rather destroy a wheel limping it into the nearest parking lot than attempt a roadside repair.
    Last time I flatted on freeway it was on stock tires - the nearest DT happened to be two miles away. I took the loss, chose to ruin the tire, and limped it there. But also, there are far fewer inattentive drivers going 85 miles per hour through the DT parking lot.
    Once you are in a lot, you should be able to call for help or change it at your leisure. If 33s are too much to lift, I'd consider putting SL loads back on the truck. But for this to be a consideration, I have to echo the recommendation for tire change lessons. Start with step one: If you are roadside, never unbuckle your seatbelt, never exit your vehicle, and never-ever-EVER attempt repair. If the weather or conditions are too extreme to stay with the vehicle, wait for traffic to clear and flee the road entirely. Do not stand outside the car for any reason.
    Waasheem and OldSchlPunk like this.
  19. May 12, 2025 at 7:35 AM
    MikeDeason
    Skinny makes sense. Did not think of that. Skinny 30 should be easy to manage and safe for a short ride
  20. May 12, 2025 at 7:47 AM
    Mach
    Mach Well-Known Member
    2022 Lunar Rock DCLB TRD Off-Road
    Mismatched tires may result in the traction control freaking out. Make sure she knows how to turn it off. It is also going to put some wear on your diff.
