lamin-x fog light issues? Anybody help?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hypeitup, Mar 9, 2010.
  1. Mar 9, 2010 at 10:13 PM
    hypeitup
    hypeitup [OP] Well-Known Member
    Jackson Hole Wy
    2005 TRD Sport Indigo
    Ome 3" full suspension lift with added toytec topplate spacer
    Hey all.
    I recently bought yellow lamin-x fog light covers. I installed them as the directions indicate. After I finished I brought my truck to the wash and hand washed it pretty good. The covers peeled from this and were pretty much unstuck except for the middle. I turned on my fogs to help dry everything out and re stuck them after about an hour. they look alright but not quite as good as before. Is this normal?? should I avoid washing them? Or did I just not let them set long enough? Let me know what you think. :confused:
  2. Mar 10, 2010 at 5:03 AM
    Simon2150
    Simon2150 Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
    when you installed them, did you wet the back of it so you could position the film on the foglight? If so, you probably washed it too soon and you could take a blow dryer on medium heat to help the drying process.
  3. Mar 10, 2010 at 7:21 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    your suppost to wait 48 hours after install for the water on the back side to evaporate through.
  4. Mar 10, 2010 at 10:32 AM
    hypeitup
    Jackson Hole Wy
    gotcha... I guess I will just wait and see how they shape up. Thanks
  5. Mar 10, 2010 at 10:35 AM
    YoterHead
    YoterHead Well-Known Member
    I didn't use water on mine and ended up with a couple of creases on the edges. I'm gonna have to remove them or order new ones I think.:mad:
  6. Mar 11, 2010 at 5:14 AM
    hypeitup
    Jackson Hole Wy
    yeah, to be honest with you I didn't use water either. I just lined them up and stuck em on. They are a bit tricky you have to start at the center and slowly and evenly work your way out. If you are super meticulous you should end up without bumps. Mine are applied clean, but Im hoping they actually stay on this time.... todays mod(hella 500 mounted behind grillcraft):D Ahhhh yeah.
