Land between the lakes TN/KY trip
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Spankomatik, Nov 14, 2023.
  1. Nov 14, 2023 at 5:03 PM
    Spankomatik
    Spankomatik [OP] Well-Known Member
    JD
    IL
    2021 celestial silver metallic AC SR SX 4x4 2.4L
    Fog lights, switch panel, cab storage platform
    I've been camping and checking out the land between the lakes the last couple of days. I've only seen one taco the last 3 days I've been here (a red 2nd gen that got behind me for a couple of miles) Most of the roads are super easy, but some of the 300s are a little scary. So far 374 is the only one that managed to make me turn around, right around a deep runoff-carved ditch near a cemetery going south bound towards the trace) Most the 300s star out deceivingly easy (some should've been a 200 road) and get iffy, then hairy, then you start wondering if you should turn around before you get stuck with no cell reception, or radio chatter 5 miles into the woods.
    My question is: I've driven through as many roads as I can on the Tennessee side. Are there any roads in the Kentucky side that I should avoid if I don't want to waste any time having to turn around? I got a stock AC SR5.
    Thanks for and info you can supply.
  2. Nov 14, 2023 at 5:46 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    You may get more info from those in the know, by using the Regional sub forums
    GL
    Spankomatik[OP] likes this.
  3. Nov 14, 2023 at 5:57 PM
    Spankomatik
    JD
    IL
    Thanks, man. I'll do that.
    Chew[QUOTED] likes this.
