Landcruiser guy trying to outfit wife's tacoma
Discussion in '3rd Gen. Builds (2016-2023)' started by clueless200, Dec 9, 2024.
  1. Dec 9, 2024 at 10:17 AM
    clueless200
    clueless200 [OP] Active Member
    200 series LC
    Greetings all! This is a build thread about my wife's 21' access cab Tacoma that we'll slowly be building into our overlander.
    Goal of the build : Capable offroader with a decent living space in the bed
    Current mods as of 12/9/24 :
    39,xxx miles
    Ironman 4x4 lift
    16" 0 offset methods
    285/75/16 E load mickey thompson baja boss A/T
    JSC Oil catch can
    Follow for details on the build : @pearl.the.200 on IG
    Dfpftw and banditcamp like this.
  2. Dec 9, 2024 at 10:33 AM
    clueless200
    200 series LC
    First mod musings and install report :
    Wrap the truck in paint protection film, noise insulate the interior. For the life of me, I could not stand how loud the inside of the cab was. Coming from a land cruiser, it's incredible how terrible the NVH is in the Tacoma. We had previously wrapped our 200 series landcruiser in 3M scotchgard paint protection film and are still impressed with it's durability to hold up to pin striping. We set about researching the material cost for doing the same on the tacoma. We then stumbled upon graphic PPF by flexishield : https://www.flexishieldusa.com/products/color-paint-protection-film-ppf/
    We then requested some samples to see how it would look on the truck and to see how the material reacts under heat and pressure. Once we narrowed down our color, we decided to pull the trigger and buy a giant roll of 72" wide x 60 ft long material. When shopping around for professional installation, we were flabbergasted by the costs...4k up to 10k! Time to roll up our sleeves..
    We started out by washing the truck numerous times to make sure the paint surfaces were immaculate
    When wrapping the bedsides, we removed the top caps to waterproof the bed with isobutyl strips when it was off
    Since we wanted the wrap to look as clean and complete as possible, we decided to strip the entire interior and noise insulate the cab. I dropped the headliner as well to get a clean wrap under the shark fin antenna :
    As you can see, the "moonbeam" PPF from flexishield looks incredible under specific lighting conditions!
    I drilled the fuel filler door rivets to remove the door and wrap it for a clean look around the edges :
    80 mil isobutyle sheets went on the floor and back wall of the cab. 40 mil sheets went on the doors and roof. I am now kicking myself for not upgrading the piss poor factory speakers when I had the door panels off. We are by no means experts at wrapping a vehicle, so now I can fully understand the labor costs for doing a job like this.
  3. Dec 9, 2024 at 10:38 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Solid effort to start things off!
    Subbed to see how it progresses.
    clueless200[OP] likes this.
  4. Dec 9, 2024 at 10:49 AM
    clueless200
    200 series LC
    We took advantage of RCI's black friday sale and picked up a set of their sliders and skid plates. I wanted to go with the raw sliders and put 2k clear over them, but the main boss decided against it so here we are. RCI's quality does not blow me away, but it will do the job since this will not be a dedicated rock crawler. They didn't pack the hardware for the top plates so they rushed out a set.
    I cleaned off the current layer of wool wax and coated the frame and slider with cosmoline instead. I put medium-strength loctite on all fasteners and coated each fastener with cosmoline. The look of raw aluminum was great, so I'm going to try to prevent pitting by regularly wiping on collinite 850 metal wax. Time will tell how it holds up!
    With the wrap completed, we applied edge tape to all areas to make sure it stays put. It's a bit overkill, but that will be the main theme of this build overall. Overkill. We could not be happier with the way it turned out. Under specific lighting conditions, the wrap is so subtle that you could not even tell. However, once under the sun, the color changes really stands out!!!
    Poser rock . Can't even tell it's wrapped
    Overhead shot. That color change is insane
    Side shot. The rainbow hue changes depending on the angle at which you're viewing it at
  5. Dec 9, 2024 at 10:56 AM
    clueless200
    200 series LC
    In no particular order, this is what we have ordered coming in for the truck as of 12/9/24
    Alucab modcap with family camper
    Long range America tank
    Dobinson billet UCA
    Full archive garage rear with XD springs
    Locked offroad 2.5 coilovers with 700lb springs
    Locked offroad 12x2.5 rear shocks
    Composite floor from vecel USA
    What we have yet to install :
    Wolfbox G900
    JD Fab upper control arm double shear kit
    6x stedi ditch lights
    Warn VR Evo winch
    factor 55 ultra hook (still deciding on this or just a plain loop)
    Yet to order :
    Backwoods adventure front bumper with connector plate, and front bumper reinforcement brackets
    If I have the whole front end apart, I also plan to install a CSF Radiator, hayden 679 trans cooler w/ electric fan for future proofing a boosted application
    Stay tuned, there's a ton of stuff going on and I have no clue what the heck is going to get installed first!
    Dfpftw and Gunshot-6A like this.
  6. Dec 9, 2024 at 11:11 AM
    N64_Wallmaster
    N64_Wallmaster Carolina Cajun
    Raleigh, NC
    2017 LTD 4WD
    - Bilstein 5100 Shocks - Icon AAL - Old Man Emu 2885 Springs - 16" TRD Bead lock style alloys - bronze - Falken Wildpeak AT3W 285/75 r16 - IFS Skid Plate; Bare Aluminum - Body Armor 4x4 Revo Rock Sliders - Diode Dynamics SS3 Fog Lights w/ Amber Accent Lights - Tacoma Lifestyle Side View Mirror Sequential Turn Signals - Cali Raised LED Bed Channel Supports; added self-adhesive rubber edge trim - AFE Magnum Pro Dry S Filter - LEER 100R Camper Top - Weathertech Window Deflectors - Bulletpoint Mounting Solutions Dash Mount - TRD Pro Grille with Raptor Lights - Headlight H11 to H9 DIY bulb conversion - Diode Dynamics interior and license plate LED bulbs - FBC license plate light DIR - Replaced chrome LTD mirror covers with oe black - Replaced chrome LTD fog light bezel with oe black trim - Meso Customs map and dome lights - Hot Shot Offroad All Lights On - Metal replacement Toyota oil filter housing - VIOFO A119 Mini 2 dash cam
    She's a beaut
  7. Dec 9, 2024 at 11:15 AM
    PondScum
    PondScum OG 303
    Colorado
    2023 Trail Edition
    6112/5160, Deaver J66, Wildpeaks, OTT, Sliders, Armor
    Looks like a fun project. Helps when cost is no object (apparently). Looking forward to seeing what's next.
  8. Dec 9, 2024 at 11:28 AM
    clueless200
    200 series LC
    Thanks, its financially beneficial to spend more money on parts and 0 on the labor. Hence all the DIY
  9. Dec 9, 2024 at 11:31 AM
    king.cong.1119
    king.cong.1119 Well-Known Member
    oh hey there~
  10. Dec 10, 2024 at 7:14 PM
    SGalvanNerd
    SGalvanNerd Well-Known Member
    Awesome wrap
  11. Dec 25, 2024 at 9:33 PM
    clueless200
    200 series LC
    We ordered an Alu-Cab modcap and family tent with all sorts of accessories. We decided to do the installation ourselves, despite knowing that alu-cab's instructions are convoluted and confusing at best. We first installed a subfloor out of 3/4" marine grade plywood and lined it with heavy-duty vinyl coin flooring. So far so good - we're patiently waiting for the enormous amounts of sika flex used to seal the modcap to the bed to completely dry before we water test the modcap. The family tent should be coming in at the end of January. We're currently planning out the interior for plumbing water, electrical system layout, and diesel heater arrangements.
    A long range America tank, locked offroad shocks, and archive garage parts will soon arrive. Stay tuned for install updates as January / February are going to be crazy!
  12. Dec 25, 2024 at 9:42 PM
    picturethis
    picturethis Well-Known Member
    Billy
    Issaquah, Wa
    2001 and 2016 Silver Tacoma DCLB TRD Sport
    BAMF Grille CBI Sliders Victory4x4 roof rack Cali Raised fog lights FNFX wheels Falken Wildpeaks tires
    Looks great so far! I just got a Alu Cab contour, love it so far!!!
  13. Dec 25, 2024 at 9:53 PM
    clueless200
    200 series LC
    Sweet, how did you wire your 3rd brake light for the contour?
  14. Dec 25, 2024 at 10:01 PM
    picturethis
    Billy
    Issaquah, Wa
    YouTube vids, lol...
    Google also:
    The 3D brake light on an Alu Cab Contour is typically wired directly to the vehicle's existing brake light circuit, meaning the positive wire from the brake light is connected to the positive wire on the 3D brake light, and the negative wire is connected to the vehicle's ground, allowing the light to illuminate only when the brakes are applied; you'll need to access the wiring harness near the taillight assembly to splice into the appropriate brake light wires
  15. Dec 25, 2024 at 10:08 PM
    MGMDesertTaco
  16. Dec 31, 2024 at 7:17 AM
    king.cong.1119
    is the modcap camper top coming soon?
  17. Dec 31, 2024 at 7:19 AM
    clueless200
    200 series LC
    greetings, were currently waiting for the family tent to come in to attach to the modcap
  18. Dec 31, 2024 at 7:29 AM
    MonkeyChief
    MonkeyChief Detachable member
    ACORLR
    WTB Topper Lunar Rock 6’ Leer
    Sud’d for a badass AC build starting out right!
  19. Dec 31, 2024 at 8:07 AM
    clueless200
    200 series LC
    Currently installing a backwoods adventure bumper with a Warn Evo VR winch.
    The wife did an excellent job wrapping the R4T Bumper caps with the same graphic PPF that we used to wrap the entire truck.
    Additional OCD steps during installation :
    - Disassembled winch to inspect grease and apply some anti corrosion sealant on electrical terminals
    - Made new +/- cables for the winch with 2 gauge wire and better terminals, then sheathed each wire
    - Sprayed the steel winch cradle with cosmoline to prevent corrosion
    - Wrapped the last few turns of winch line on the drum with high visibility sheathing
    - wrapped the first bit of winch line with a sleeve
    Remaining to do list :
    - The wife likes the current grill, so I plan to use plastic gutter guard behind it to prevent any damage to coolers behind it
    - install cube lights and driving lights
    - Drive the truck until empty - well be installing a long range tank this weekend after painting it in raptor coat
    AK Dudeman, picturethis and Dfpftw like this.
  20. Dec 31, 2024 at 8:12 AM
    MonkeyChief
    ACORLR
    I’ve currently got that grill, I’ve seen it painted black and it looks good.
    You can also get emblem covers for the grill that don’t mess with TSS
