Landing Pad 24 Mounting points
Discussion in '2nd Gen. Tacomas (2005-2015)' started by splash07s, Feb 19, 2022.
  1. Feb 19, 2022 at 1:24 PM
    splash07s
    splash07s [OP] Well-Known Member
    Lauton
    Charleston, South Carolina
    2014 TRD Sport 4X4 DCSB White
    Yakima specifies the mounting holes for landing pad 24. There are five holes in each ditch, and they specified to use hole number two and four as counted from the front to the back. However the holes they specified to use are further apart than what I need for the rack I’m going to use. Would using the center mounting hole instead cause problems? Referring to the mounting holes in the roof ditch.
