Large cracks in transmission crossmember
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MonkeyProof, Dec 7, 2011.
  1. Dec 7, 2011 at 8:17 PM
    MonkeyProof
    MonkeyProof [OP] Power Top
    SoCal- SGV
    HBMurphy had mentioned his transmission crossmember being cracked so I went ahead and inspected mine.
    I found 3 large cracks and one small crack in the crossmember, I think it's time to replace before the cracks lead to a catastrophic failure.
    Driverside front of crossmember:
    Driverside back of crossmember:
    Passenger side front of crossmember:
    The bottom of my support brackets for the crossmember and the crossmember itself were pretty beat up from previous rockcrawling adventures. Looking at the condition, I felt some remorse and love all at the same time, knowing what we have been through. Poor thing lol.
    Passenger side:
    Driverside:
    There was some excess material that had to be removed from the crossmember support bracket that was trying to wrap itself around the cross member. Without removing that excess there would have be no way to remove the crossmember. I used a mini sander and a mini cutoff wheel; air tools FTW!
    It's obvious that Toyota has changed the design a bit. Here's a comparison between the old and new crossmembers. The new version is fully boxed from end to end. Also, there is a continuous bead of weld from end to end on the front side which was not present on the old style.
    Mully, T.Barn, robssol and 5 others like this.
  2. Dec 7, 2011 at 8:43 PM
    SiRMarlon
    SiRMarlon The Photo Ninja!
    Marlon
    Los Angeles
    Canon 5D MarkIII
    Damm that is crazy Tom...but when you think about it. You have beat the shit out of that truck! :D
    winkel and BalutTaco like this.
  3. Dec 7, 2011 at 8:44 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    damn! By the looks of it, toyota realized theres a flaw in the original desing. im curious to soo what my 2010's looks like
    :popcorn:
  4. Dec 7, 2011 at 8:45 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Thats Crazy! what causes this to happen? Hard wheeling?
    Or is it just a defective part?
    Pics with it installed? :)
  5. Dec 7, 2011 at 8:47 PM
    jandrews
    '09 FourDubDee TRD OR
    FWIW, the crossmember design changed in 2009. It caused a little hell and we had to do a little crossmember modifying with a plasma cutter to get my skid plates to install.
    On the plus side, it looks like I've dodged the crack bullet.
    Continued shitty Dana frame designs, followed by revisions after durability QA.
  6. Dec 7, 2011 at 8:47 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    ugh, now i have to go check mine tomorrow. and it's coverd by a skid plate which is gonna be a pita.
    do you have any idea what year they changed the crossmember design? i know mine's the old style, jsut curious what year truck to look for to yank one off of.
    Edit: question answered before it was asked. appreciate sir andrews.
  7. Dec 7, 2011 at 8:57 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Nice Job Tom!!! I still need to do something about mine. :)
  8. Dec 7, 2011 at 9:01 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    drill weld plate ?
  9. Dec 7, 2011 at 9:02 PM
    HBMurphy
    Paul
    So California Coast
    None
    I think the new cross member looks better! :) lol :D
  10. Dec 7, 2011 at 9:04 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    All current Toyota ladder frames (2nd Gen. Taco, 4Runner, Tundra...) are designed by Hino, which makes commercial trucks but has little off-road experience.
    At least Toyota is making the revisions. Other companies (except for maybe Jeep) would probably relegate this to "off-pavement abuse" and never bother with it.
  11. Dec 7, 2011 at 9:04 PM
    HBMurphy
    Paul
    So California Coast
    None
    I've felt that!!! :)
  12. Dec 7, 2011 at 9:06 PM
    HBMurphy
    Paul
    So California Coast
    None
    Too bad the bottoms of our trucks don't look like the 2012 baja race truck...
  13. Dec 7, 2011 at 9:33 PM
    MonkeyProof
    SoCal- SGV
    i think the main reason is a poor design. but my wheeling habits played a role into the cracks as well.
    on the old cross member you can see the cracks started at the beginning of each weld bead. i think that created a stress riser. plus, the cross member was not fully boxed from end to end.
  14. Dec 7, 2011 at 9:37 PM
    MonkeyProof
    SoCal- SGV
    after seeing it i didn't even bother to think about adding gussets like i had planned
  15. Dec 8, 2011 at 3:33 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    So how much does a new crossmember cost?
  16. Dec 8, 2011 at 3:55 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I'd have to go 50/50 on this one. Looks like underengineered part failure due to a bit too much fun. How many of these are failing without aggressive offroading, rock crawling and sky king air sessions? Betting it's more of a 6cyl thing vs 4 cyl thing too like the engine mount brackets caving in on the frames when actually doing things like on the commercials they use to sell the things to begin with. Still, depending on price I might be interested in one anyway, even though my 4 cyl isn't doing much if any stuff to have problem.
  17. Dec 8, 2011 at 4:15 AM
    84Hilux
    84Hilux Well-Known Member
    Gary
    Vancouver, Canada
    09 SR5 Access Cab V6 4X4
    Stock Fog Lights, Camera Mirror, Arrow Canopy, Lighted 4x4switch, Weathertech Mats (Black), Wet Okoles- Black/Charcoal, Alpine CDA117 Headunit/ Alpine PDX4150 Amp/Alpine PDX M6 Amp/ Hybrid Legatia SE Components/ JL 10W6V2 Subwoofer/ Prototype MR Marv Sub Enclosure
    Nice job! I will check my truck tomorrow. It looks like you use your truck for more than getting groceries!
  18. Dec 8, 2011 at 4:28 AM
    jandrews
    From what I understand, they're Dana built. Toyota design and Dana built? In that case, shitty Toyota designs followed by revisions after...etc. etc.
  19. Dec 8, 2011 at 7:20 AM
    Wildhorse1966
    Wildhorse1966 Active Member
    this woudnt have happened if you had ATRAC
  20. Dec 8, 2011 at 7:53 AM
    Brandon H
    Brandon H Well-Known Member
    Newhall, CA
    07 DC Offroad
    2017 4Runner TRD Offroad Premium. Icon stage 7, RCI skids, SCS SR8 wheels, budbuilt sliders, 285/70/17 BFG Ko2s (Old rig) 07 Taco TRD Offroad FUlly Locked, Icon Extended Travel CO's w/ remote resis., Alcan AAL's,Icon Remote Resi Rear Shocks, All Pro Front bumper w/ warn 9.5xp,winchline synthetic winch cable,All Pro IFS Skid plate, OME Shims, OME Carrier Bearing drop, Trail Gear Sliders, Yakima Load Warrior Basket, OEM Roof Rack, Hi Lift Extreme, Cobra model 19, Wilson Lil Wil Antenna, Yaesu ft-7800
    I agree. A-Trac would have kept your old crossmember looking like brand new!!
