Large, Fine Thread Metric Tap and Die Set Recommendations?
Discussion in 'Garage / Workshop' started by DesertRatliff, Dec 1, 2019.
  1. Dec 1, 2019 at 7:42 PM
    DesertRatliff
    DesertRatliff [OP] Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    I've got the really nice 41 piece Irwin metric-only tap and die set pictured above that has worked for well for years. Every now and then, though, it leaves me hanging, and usually with the larger fine thread bolts that Toyota uses (head bolts on a 3RZ were the last ones; I think M12 1.25). I could piece together the tap and dies I needed ala carte but would rather give Santa an idea to put under the tree in one big box.
    Any recommendations?
  2. Dec 1, 2019 at 11:31 PM
    TK-422
    TK-422 Toyota! Oh what a feeling.
    So Cal - SCV
    2015 4Runner TEP
    Toytech 2.5 lift BFG KO2 275-70-17
  3. Dec 1, 2019 at 11:43 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    I suggest staying away from cheap taps unless it's just for chasing threads. But in that case rethreading/chaser taps are the way to go, they won't remove material which for the most part your standard tap will.
    Wyoming09 likes this.
  4. Dec 2, 2019 at 2:36 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    For years now I just buy the sizes I need why spend money on sizes you will never use !!
    Then I buy the correct size drill bits .
    Unless your building parts from scratch your better off with a thread chaser set for restoring and cleaning threads
    If your buying a set go with the thread chaser you can get them for internal and external thread
    nagorb and Bigdaddy4760 like this.
  5. Dec 2, 2019 at 4:49 AM
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    I do a little of both. But when I'm fabbing stuff I try to stay away from odd sized hardware anyway.
    If thread restorers/chasers are the way to go, can you guys recommend a set? I've always liked Matco tools but their chasers are little out of my price range here.
  6. Dec 2, 2019 at 10:52 AM
    nagorb
    Alabama
    2001 dbl cab 4x4
    I've had good luck with ARP, they're not cheap, but for truck stuff you only need a few.
  7. Dec 2, 2019 at 1:33 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I have had good Luck Buying from McMaster- Carr never received anything poor quality.
    I am lucky I have a warehouse close order before 1700 most times it is here next day
    I have a Matco kit floating around some place
    Hardscrabble and nagorb like this.
  8. Dec 2, 2019 at 1:41 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Gearwrench makes a nice set
  9. Dec 2, 2019 at 3:18 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    Yep. McMaster for most everything.
    Hardscrabble likes this.
  10. Dec 2, 2019 at 6:31 PM
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    Thx for the tips guys. Didn't even think about McMaster Carr.
