Larger Tires and Gear Ratio
Discussion in 'Wheels & Tires' started by thehtizzle@gmail.com, Sep 4, 2008.
  1. Sep 4, 2008 at 8:13 AM
    thehtizzle@gmail.com [OP] Well-Known Member
    Houston, TX
    06 Tacoma 4cyl Access Cab
    3" Redy Lift, radio upgrade, sub + amp, window visors
    I have a 2006 4 cyl Tacoma and am going to lift it, take the stock 15" steelies off, and put on either 18's or 19's with a ~32" tire. Does anyone know if I will need to change the gear ratio of this 2.7L truck?? I dont want to put the engine under too much strain.
  2. Sep 4, 2008 at 11:35 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    What are your factory tire size and gear ration?
    Is you truck 4x4?
  3. Sep 4, 2008 at 11:47 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I am not familiar with the 15" rims on these trucks but the 16s are 265/70/16 which is 30.6" tall, and if your gears are 3.73 then putting a 32" tall tire on will give you a rear ratio of 3.56 gear.
  4. Sep 4, 2008 at 12:31 PM
    Houston, TX
    The 2.7L 4cyl 2wd has a final gear ratio of 3.31. So what you are saying is that I don't have to change the gear ratios?
  5. Sep 4, 2008 at 12:51 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Ok well let me recalculate this one. example. Take your factory gear ratio and multiply it times your factory tire height and you divide that by your new tire height and you will get your new gear ratio. 3.31x30.6/32=3.16 your new final drive ratio. that will be in drive not including overdrive which will reduce that even more. What are you planing to do with your truck? If all you want to do is drive it every day then you won't need to change anything. I'm not doubting you but I would have thought that the 2wd trucks would have had a lower gear ratio. Changing the gears will be a little pricy just to ride around.
