Larger tires for 2" lift which also will fit into the spare wheel well
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taudelta, Aug 26, 2024.
  1. Aug 26, 2024 at 8:21 PM
    Taudelta
    Taudelta [OP] Well-Known Member
    Iurii
    South Florida
    2023 Tacoma Trd OR
    Steelcraft Fortis front bumper, BodyArmor 4x4 rear bumper, LIft: Bilstein 5100+2885 OME coils, Icon RXT 3 stage. 255/85/16 wildpeak at4w
    Hey guys, i lifted my truck and thinking to put a larger tires something like 285/75/16, but im wondering will it also fit into the spare wheel well. any suggestions?
  2. Aug 26, 2024 at 8:24 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    CMC to open the wheel wells?
  3. Aug 26, 2024 at 8:26 PM
    Taudelta
    Iurii
    South Florida
    2023 Tacoma Trd OR
    CMC? I'm a little bit new, so need assistance
  4. Aug 26, 2024 at 8:30 PM
    RichochetRabbit
    Cut the front/rear lower sections of the wheel wells at an angle. Gives the "wider" tire more maneuvering room during turns. But you also need to re-seal the truck-structure to prevent water instrusion through the new gaps. More like major surgery, so be sure you really want to "cut the frame", even a little bit.
  5. Aug 26, 2024 at 8:30 PM
    Taudelta
    Iurii
    South Florida
    2023 Tacoma Trd OR
    Googled. - Cab Mount chop - no. didn't, but front part of well was bended to prevent inner well to bend in because of airflow. no cmc at the rear part of the well
  6. Aug 26, 2024 at 8:32 PM
    RichochetRabbit
    Just a thought ... get a big enough tire you cannot avoid. Google "viper cut" just for giggles.
  7. Aug 26, 2024 at 8:34 PM
    Taudelta
    Iurii
    South Florida
    2023 Tacoma Trd OR
    ive viper bend, cause i didn't cut it but bend because my front bumper lower line is much height than stock
  8. Aug 26, 2024 at 8:39 PM
    RichochetRabbit
    You may need to relocate the spare tire hoist (toward the cab or away ... cannot recall). Several have done this, I think more annoyance than structural. And you may need to cut the end of your tailpipe a few inches to give the spare clearance. Cannot say I have done it, but I have been reading about the crazy exploits of TW in the "What have you done to your 3rd gen today" thread.
  9. Aug 26, 2024 at 8:43 PM
    Taudelta
    Iurii
    South Florida
    2023 Tacoma Trd OR
    i see. will talk with my mechanic thank you
  10. Aug 26, 2024 at 8:48 PM
    RichochetRabbit
    Wait for a while ... the experts should chime in and give you usable facts, not idiotic babbling ... :bananadance::dancingbacon::broccoli:
  11. Aug 26, 2024 at 11:13 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    up to 35" tire can fit under the bed when the hoist is relocated back
    PTSDTherapy likes this.
  12. Aug 27, 2024 at 12:00 AM
    Taudelta
    Iurii
    South Florida
    2023 Tacoma Trd OR
    also is it possible to fit on stock rims R16 (16x7) something like 275/70/r16 (stock offset +25 mm)?
    or i need different rim with negative offset?
  13. Aug 27, 2024 at 5:27 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Just get 33" pizza cutters and move on for the better...
    71tattooguy likes this.
  14. Aug 27, 2024 at 8:02 PM
    Taudelta
    Iurii
    South Florida
    2023 Tacoma Trd OR
    what rims are you using?
  15. Aug 27, 2024 at 9:25 PM
    blacktaco77
    blacktaco77 Well-Known Member
    Noah
    21 TRD off road black 4x4
    I fit a 285 in the stock spare location by just hammering the sections where it doesn’t fit back. You probably wouldn’t rub the cab mount bumping up to a 285 but you would rub the uca with that offset. If you add a wheel spacer then you can clear the control arm but will be rubbing the cab mount. Can mount chop is pretty cheap to do and doesn’t really negatively impact anything imo just depends if your down to cut your truck a little bit or not. You would probably have to trim a little bit of plastic depending on your setup as well. I have found 0 offset works best for rubbing. A 1.25 inch spacer pushes a +25 wheel to about a -7 offset which is pretty damn close to 0.
  16. Aug 27, 2024 at 10:34 PM
    devinzz1
    devin
    2023 aclb trd or mt
    there are more sizes than 1.25 spacers. stock wheels with a bora 3/4" spacer will clear uca and still clear the cab mount with a 285
    blacktaco77[QUOTED] likes this.
  17. Aug 27, 2024 at 10:46 PM
    Taudelta
    Iurii
    South Florida
    2023 Tacoma Trd OR
    is such spacer good? or it is better to buy different rims?
    as far as i know wheel spacers are increasing stress on suspension
  18. Aug 27, 2024 at 11:06 PM
    devinzz1
    devin
    2023 aclb trd or mt
    offset increases stress on suspension not spacers themselves. an oem wheel plus a spacer totalling the same amount of negative offset will be exactly the same as an aftermarket wheel measuring that same offset. a known quality spacer like bora is absolutely exceptable.
  19. Aug 28, 2024 at 1:14 AM
    Sig Taco
    Sig Taco Well-Known Member
    2021 Taco DCSB
    Icon Rebounds 17x8.5 Toyo 35/12.5/17 JBA UCA, Bilstein 6112/5160, KDMax
    Get ready for 13-15mpg.
    RIX TUX likes this.
  20. Aug 28, 2024 at 9:04 AM
    Taudelta
    Iurii
    South Florida
    2023 Tacoma Trd OR
    found thread on pizza cutters, is it possible to fit em on r16 OR?
