Larger tires / much alignment effect?
Discussion in 'Wheels & Tires' started by TacoBow, Feb 24, 2011.
  1. Feb 24, 2011 at 6:18 PM
    TacoBow
    TacoBow [OP] Intentionally cosmetically correct.
    Central PA
    2015 Tacoma TRD Sport 4x4 Quad LB
    Pondering the effect larger tires may have on alignment... say for the sake of going up one size vs. going up two or more tires sizes above the OEM rubber.
    What can a person expect to see the most variance in?
    Significant changes in caster or camber or both?
    I'm guessing toe will be least influenced?
    Your thoughts...
  2. Feb 24, 2011 at 6:20 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
  3. Feb 24, 2011 at 6:20 PM
    NicksRig
    NicksRig Well-Known Member
    Kenora, Ontario
    07 Tacoma DC TRD Sport
    Blacked out Skid plate, block heater, bug deflector, blacked out headlights, tinted fronts, OME 3" lift, Toytec AAL, Revenge-Fab Sliders, K&N Air Filter
    Shouldnt have any alignment issues.... Until you install your lift.;)
  4. Feb 24, 2011 at 6:37 PM
    TacoBow
    Central PA
    LOL. :D
    I'm thinking the larger diameter tire will have some effect on caster, just wondering if anyone else found it notable.
  5. Feb 24, 2011 at 6:39 PM
    jandrews
    '09 FourDubDee TRD OR
    It will still drive fine, but your old alignment probably won't be good for handling AND tire wear. Larger tires deform differently, usually with more rollover at the edges. Running a higher PSI can help this, but even then you'll see some scrubbing of the shoulders of the tread blocks.
    Once you go to a larger tire size, it's best to dial in your new preferred alignment by trial and error.
  6. Feb 25, 2011 at 9:54 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Larger tires wont affect the alignment.
  7. Feb 25, 2011 at 10:02 AM
    jandrews
    They won't throw it out, but they may wear differently/poorly, and for best wear he may want to re-adjust his alignment.
  8. Feb 25, 2011 at 10:16 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Tire changes dont effect alignment. Only changing the height of the suspension(lift kit) for the tires
  9. Feb 25, 2011 at 2:03 PM
    TacoBow
    Central PA
    And for those of us old enough to remember him...
    Now we know, "The rest of the story."
    :D
