Larger Tires on 4 Cyl - Performance Question
Discussion in 'Wheels & Tires' started by Hove2, Nov 11, 2012.
  1. Nov 11, 2012 at 5:00 PM
    Hove2
    Hove2 [OP] New Member
    Maine
    4 cyl SR5
    New owner of a 2013 four cylinder - first Toyota after years of Jeep Wranglers.
    I want to increase size/tread - has stock 245/75/16s on it. I see the threads on rubbing/tire size but I want to know about performance. If I put a 265/75/16 on it, what can I expect for performance?
    Don't really care about speedo inaccuracy or mileage. 4 cyl is small enough...how sluggish will it be with a larger tire with more aggressive tread?
  2. Nov 11, 2012 at 5:22 PM
    hillbilly taco
    hillbilly taco Well-Known Member
    tommy
    WEST VIRGINA
    09 standard cab 4x4
    3 INCH LIFT 285/75/16 TIRES CUSTOM GRAPHICS ROLL BAR
    You will notice a little difference in power not much.And your speedo may actually be closer than it is now.Check it now with a gps most ive seen are 1-2miles fast factory.But if your worried about power and handling just do it.Youll have no problem there.
    c
  3. Nov 11, 2012 at 5:25 PM
    Kirk1589
    Kirk1589 Well-Known Member
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Pasti-Dip Grille, K&N drop-in, Magnaflow 14", Custom tail light mod, Fog light mod, diff vent mod, Alpine Components, Sequoia JBL radio
    if you want more powwwa with bigger tires you'll want gears, no bolt on will help
  4. Nov 11, 2012 at 5:34 PM
    hillbilly taco
    tommy
    WEST VIRGINA
    09 standard cab 4x4
    I am going to regear mine to 488s next week.But thats just because Im running 285s.If I was still running 265s I would not regear.I really didnt have a power issue with 265s
  5. Nov 12, 2012 at 9:57 PM
    Kirk1589
    Dave
    Sticks-RI
    03 SR5 Off-Road
    265 is the stock size anyways you shouldn't have an issue.
