larger tires, slower speed!
Discussion in 'Wheels & Tires' started by jczelusniak, Apr 5, 2010.
  1. Apr 5, 2010 at 2:40 PM
    jczelusniak
    jczelusniak [OP] Member
    Columbus, OH
    09 Access Cab 2WD SR5
    Redi-lift lift kit
    I put larger tires on my Tacoma, and as a result my speed is different then actual.
    How can the speedometer be adjusted for the new size tire?
  2. Apr 5, 2010 at 2:48 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    can't... need scanguageII... I have same dilemma
  3. Apr 5, 2010 at 2:50 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Same thing for me. I just use my GPS but I dont really care anyways as long as im in the general MPH's I want to be in.:cool:
  4. Apr 5, 2010 at 2:58 PM
    JDMcompliant
    JDMcompliant Professional Amateur
    Joe
    San Diego
    2010 Tacoma 4x4 4.0L V6
    there is one way (albeit a very sketchy way).
    In my old '98 4Runner, I pulled out my gauges to do some work on the gauge face. To do that, you first need to pull off the needle. When pulling off the needle, you need to mark at what point the needle drops to (there should be a needle "rest" at 0 mph...if you remove it, the needle will drop a past the rest and stop.) You have to remember to put the needle back on at this exact point when putting your gauges back together.
    The last time I did this, I forgot to mark where the needle stopped. I guesstimated, and after I put everything back together, my speedometer was under by 5 mph. You can technically do this to compensate for the larger tires, but it requires alot of tedious work and trail-and-error.
  5. Apr 5, 2010 at 3:22 PM
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    ^ pretty sure that will not work with newer technology... when i did my dash mod i didnt mark any of the needles, all my gauges read right on except for the spedo. (lift, tires, ect ) gauge reading 70 - gps reads 75. just know your vehicle or use a gps/scangauge to show your true mph.
    im about 90% sure the only way to fix the reading would be to somehow re-cal the cpu.
  6. Apr 5, 2010 at 3:29 PM
    JDMcompliant
    Joe
    San Diego
    yeah, that's one thing i forgot to mention -- i don't have any experience with the new gauges. i see OP has an 09 as well.
  7. Apr 5, 2010 at 7:08 PM
    tuckr2
    tuckr2 Well-Known Member
    Western Washington State
    2010 Silver dbl cab LB 4x4 It's Purdy too!
    LT265/70/17 BFG A/T's, Disabled Seat Belt Buzzer, Black and Gray Covercraft Seat Covers front and rear, Matching SnugTop Supersport Canopy, undercoat, bed mat, window vent shades. Black Weathertech Liners. Trans TSB, Rear Spring TSB Installed.
    Not positive about adjusting the speedo. Best bet would be contact a Speedo shop and see if they can assist. Many have purchased Scan guages. Also, GPS systems will help you with speedo readings as they are pretty accurate.
  8. Apr 5, 2010 at 7:11 PM
    Chad
    Chad Well-Known Member
    Chad
    Cary, NC
    09 V6 Access Cab TRD Sport
    Kenwood DMX-7704S Headunit -- Blackvue DR-470 Dashcam -- Pioneer TS-A1685R Speakers in Front -- Suntek CXP 40 Front Tint -- Access Vanish Roll-up Tonneau -- Wet Okole Seat Covers -- Fog Lights on Anytime -- PnL Powered Tailgate Lock -- DTRL "Stealth Mode" -- LED Footwell and Cup Holder Lights -- Map Lights ON with Dome Light -- Shorty Antenna -- AC Line Extension Mod -- Access Cab Rear Headrest Removal
    You could always buy a hypertech calibrator.
  9. Apr 5, 2010 at 7:16 PM
    desertdude59
    desertdude59 CRAZY 4WHEELER
    From the Mojave desert now in Wild and Wonderful W
    1991 toyota 4x4 sr5-lost but not forgotten
    4" lift after market front bumper bed mount lightbar/roll bar (4)6" kc's on the roll bar (2) kc flat back bumper mounts f/r gears for the 33's
    computer time
  10. Apr 5, 2010 at 7:18 PM
    SurfInferno
    SurfInferno Dont be stupid, its not smart.
    Dylan
    Littleton, CO
    2001 DC
    when i changed my speedo to blue with the LEDs i changed the speedometer because it was off by 5mph. Now it is correct
  11. Apr 5, 2010 at 7:35 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    What about the odometer? There's got to be a way a dealer could change the calibration.
  12. Apr 5, 2010 at 7:40 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    ^they dont want to deal with it haha
  13. Apr 5, 2010 at 7:56 PM
    tuckr2
  14. Apr 5, 2010 at 8:05 PM
    kilgoja
    kilgoja Well-Known Member
    Alabama
    2009 regular cab 4x4 2.7L (silver)
    :mudding:
    it's not a big deal...i mean how big are your tires?...it's prolly only off like 2 or 3 mph....not gonna get a ticket for that
  15. Apr 6, 2010 at 12:53 AM
    MY50cal
    Mojo
    Camden County, NC
    Yep.
    hmmm, we would like an explanation... :rolleyes:
    ... cause i say bullshit.
  16. Apr 6, 2010 at 2:05 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Keep in mind from the factory it is wrong, usually going slightly larger puts it closer to actual real readings...
  17. Apr 6, 2010 at 2:45 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    ^^^agreed
  18. Apr 6, 2010 at 3:13 AM
    MiikeyD
    MiikeyD The Green Machine
    Upland, CA
    Green Prerunner DC 2.7L
    Suspension / Wheels / Tires 3.5" Fabtech lift w/ AAL 265/75/16 BFG A/T American Racing Baja Audio Alpine HU CDA-9886 Kicker DS650 Z-Edition 1000W Memphis M3 US Amps 4000W 2.5Farad Cap Lighting 6000K HID 2 Hella 500FF 2 Aux Bed Lights 2 Aux Driving Lights Performance Volant CAI Flomaster Super 44 Doug Thorley Long Tube headers (coming soon) NGK Iridium Sparkplugs Accessories Scanguage II Cobra LTD27-NW with 3' Firestik Radio Shack Triple Trunking Scanner Harbor Freight Hi-Lift Cosmetics Flat Black Bumper Trim Flat Black Grill Surrounding with Satoshi Clear Corners Future Modifications (not specific) Longtravel w/ king shocks or fox Caged bed Shackles rear suspension. Fox / king shocks custom front bumper Custom Glassworks extreme kit for 01-04 (only have hood and passenger side.. need driver panel) Supercharger + 8port intake manifold optima yellow top battery remounted new rims caged interior rear bench removal 4 sparc
  19. Apr 6, 2010 at 3:25 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Funny thing, my truck came with 285/60/18s (31.5") already on it. The speedo reads 70, the GPS says 68-69. Now that I have 275/65/18s (32.1") the speedo & GPS are in sync no matter what constant speed I travel. I wanna trust it but just doesn't seem right for some reason. Are the factory tire sizes 32" OD? Is it really just wrong from the factory as was stated? Why would that be? Same broke ass logic that puts shitty leafs, folding tailgate, squeaky slave cylinders and other such goodies on for years after they are known problems would be my guess.....or they just think they know everyone will be buying larger tires and are just being proactive?
  20. Apr 6, 2010 at 5:51 AM
    stenyeart
    stenyeart Well-Known Member
    Sean
    Lewiston, Idaho
    06 DC TRD OR SWB
    3" Toytec Lift w/ AAL, TRD CAI, Leer 700 Series, Hypertech Speedo Calibrator, Locker Anytime Mod, LR UCA's, OEM Roof Rack, Satoshi grill with Devil Horns Emblem, USA Spec PA-15 Toy Ipod Integration, Redline Tuning Hood Struts and EZ Down Tailgate.
    x2
