Largest engine you can possibly fit?
Discussion in '1st Gen. Tacomas (1995-2004)' started by CTomz, Jan 21, 2018.
  1. Feb 13, 2018 at 7:19 AM
    #41
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    Yup, that's the one. It was amazing how fast he built that thing too.
  2. Jan 17, 2019 at 1:32 PM
    #42
    Darth derp
    Darth derp Member
    Michael
    1996 extended cab manual Tacoma 4wd
    1.5-2" body lift
    Does anyone think you can fit a v8 4.7 l in a 1997?
  3. Jan 17, 2019 at 2:19 PM
    #43
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    yeah been done a lot.
  4. Jan 17, 2019 at 2:46 PM
    #44
    Darth derp
    Darth derp Member
    Michael
    1.5-2" body lift
    What about a 5.7? before I just ask a series of questions I'm trying to find the most customizable model of Tacoma.
  5. Jan 17, 2019 at 2:48 PM
    #45
    DeltaBravo
    DeltaBravo Do you know what nemesis means?
    Waste Management's residential dumpster rental allows you to quickly find the right size dumpster for your project, schedule delivery and pay, all in just a few steps.
    The vehicle commonly referred to as "The War Rig" is a 78 foot 18 wheeler based on a Tatra T815
    Put in a Supra motor DAWG
  6. Jan 17, 2019 at 2:56 PM
    #46
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    The UR series engines are very wide, they barely squeeze into a Land Cruiser 80 frame, might be possible on the Taco but I suspect you'd have to section the frame to give it birthing hips haha
  7. Jan 17, 2019 at 2:57 PM
    #47
    Blackdawg
    Monte
    Wyoming/St. Louis
    Pretty sure that's too big. the 5.7 is WIDE as hell.
    And what? The most customizable model? As in 1st gen vs 2nd and 3rd?
    Way more aftermarket support for 2nd/3rd gens. Not for motor swaps per say but overall.
    already been done a lot. I've thought of it. 2jz just doesn't have as nice a torque curve as the 5vzfe
  8. Jan 17, 2019 at 3:07 PM
    #48
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    CANBUS is a pain in the ass on a second gen compared to standard OBDII for motor swaps
  9. Jan 17, 2019 at 3:15 PM
    #49
    wesb1023
    wesb1023 Well-Known Member
    Westley
    Eastern NC
    04 Double Cab
    Idk about the 7.3. Are you talking about the old IDI or the heui models? Turbo or not? If you’re talking about the newer ones with the heui injectors, or either actually, a turbo relocation maybe called for. Which I guess you mean the heui model because you mentioned powerstroke. I guess the turbo could stick up through the hood, a little but damn that’s a big engine. The older idi 7.3l’s with the center mounted injection pump, probably wouldn’t be very hard to fit, it’s basically a big block v8. No electronics on the idi except the starter, alternator, and fuel shut off solenoid.
  10. Jan 17, 2019 at 3:26 PM
    #50
    Toyko Joe
    Toyko Joe Here for the pictures
  11. Jan 17, 2019 at 3:28 PM
    #51
    Flatout110
    Flatout110 Well-Known Member
    Tony
    Long Island, NY
    2019 Tacoma
    Engine oil By-pass filtration system. B&M transmission cooler Rustproofed
    Best option would be the new Cummins R2.8 swap engine
    Slashaar likes this.
  12. Jan 17, 2019 at 3:28 PM
    #52
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    lbz swap it, full race build boom 900hp 1600tq. hurt everyones feelings when you do pulls
  13. Jan 17, 2019 at 3:31 PM
    #53
    Darth derp
    Darth derp Member
    Michael
    1.5-2" body lift
    Yes, though I'm more looking for a more specific year. My goal is to build an old model into something I can go across the country in off-road (kind of like Alaska off-road warriors, if you have seen it) the bumpers and bed I will probably make myself but when it comes other mods like suspension lifts I will have to buy, obviously. if it hasn't already made itself apparent I don't know much about moding trucks so I don't really know the possibilities. The 1997 that I was thinking about rebuilding is my avatar.
  14. Jan 17, 2019 at 3:31 PM
    #54
    Flatout110
    Tony
    Long Island, NY
    2019 Tacoma
  15. Jan 17, 2019 at 3:40 PM
    #55
    Blackdawg
    Monte
    Wyoming/St. Louis
    WAY more suspension options for 2nd gens. Like a LOT.
    Pretty much anything worth anything is a custom setup for 1st gens. And is limited as it is unless you do SUA or links which idk if thats where you'll go or not.
  16. Jan 17, 2019 at 3:45 PM
    #56
    Flatout110
    Tony
    Long Island, NY
    2019 Tacoma
    Check JDM engines and look for any Toyota diesel that would bolt in. Toyota has always made an excellent diesel !!!
  17. Jan 17, 2019 at 4:00 PM
    #57
    Speedytech7
    Thats a 10k engine that doesn't produce much power and is electronically controlled so it doesn't even have the benefit of being simple.
  18. Jan 17, 2019 at 4:07 PM
    #58
    Darth derp
    Darth derp Member
    Michael
    1.5-2" body lift
    So for what I'm doing, I need to keep I need to try to keep the year before 2000.
  19. Jan 17, 2019 at 4:09 PM
    #59
    Flatout110
    Tony
    Long Island, NY
    2019 Tacoma
    Simple if you understand electronically controlled engines. ;) Not as difficult as everyone thinks !!!
  20. Jan 17, 2019 at 4:14 PM
    #60
    Speedytech7
    I do because tuning is my hobby. But for a lot of folks building rock solid off-road rigs, especially diesel. Less is more. The fully mechanical setup of a 4BT is more attractive. The weight maybe not so much though. Not as big of a deal if a sensor goes or a solenoid sticks on a road going car, you probably aren't far from service. A rig you trust to take you to the middle of nowhere is a bit different. But yeah for those of us that are comfortable tinkering you're right there is less risk. Still an over priced underpowered little engine though. It would be a better choice at about 4-5k for the entire package minus fuel cell
