Largest possible tyre size and reccomended rim size
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomatrdod, Nov 17, 2013.
  1. Nov 17, 2013 at 2:09 PM
    tacomatrdod
    tacomatrdod [OP] Well-Known Member
    Mud Country
    2010 tacoma trd offroad
    Toolbox, stereo upgraded a tad
    Can anyone help a new guy out here? I was hoping for some that don't rub on the inside, like some people don't mind this BUT... anyways. Basically i'm just looking for a simple answer to this burning question, and yes i've searched around a little bit, i guess i'm not as good as im sure somebody will answer this question with a link right away!
  2. Nov 17, 2013 at 2:12 PM
    Large
    Large Red
    You want absolutely no rubbing? Stick with the stock size.
  3. Nov 17, 2013 at 2:23 PM
    tacomatrdod
    Mud Country
    are you serious? You really can't go any larger? hmm... damn.
  4. Nov 17, 2013 at 2:26 PM
    Large
    Large Red
    Well, there is a guy running 37s with no lift and he don't rub, but to take in all the work required to do that is pretty intense. If you don't want to rub at all, stick with the stock size. Even going up 1 size, you will lose the flaps. Mind you, no truck is the same, it's possible you could go up 1 size and not rub but unlikely. I'm sure you will get "I went to 265/xx/xx and I don't rub" every now and then but if you don't want to take the chance you should stick with the size you know won't rub.
