Largest size tire you can fit on a 1st gen tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by LAYOTABOY, Mar 13, 2013.
  1. Mar 13, 2013 at 12:21 PM
    LAYOTABOY
    LAYOTABOY [OP] Member
    micah
    covington
    00 Prerunner SR5 black on white
    2 kc daylighters, 3" rollbar 10k blue hids, painted tailights and side markers, 2.5" lift rough country, jl 500/5 class d hybrid amp, 4 p1 4ohm subs alpine headunit custom box
    i have a first gen tacoma with a 2.5 rough country lift. I am currently running 215/75R15 on my truck and wanted to go up ini size and width. i have a few tires in mind such as toyo open country AT II's. would it be possible to put on 245/80R15?
  2. Mar 13, 2013 at 12:29 PM
    Mrogers33
    Mrogers33 The way is open, the time is now
    Columbus, OH
    03 doublecab 4x4 grocery getter
    From what i have read on here that width will likely rub. I think 265/75/16 is the biggest people go on a stock setup with minimal rubbing. I have 265/70/16 on stock rims and no lift with no rubbing issues.
  3. Mar 13, 2013 at 12:31 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    You have a prerunner with 215/75R15?
  4. Mar 13, 2013 at 12:32 PM
    LAYOTABOY
    micah
    covington
    okay i appreciate it yet i still have the stock rims which is 15 do they make that size in 265/70/15?
  5. Mar 13, 2013 at 12:36 PM
    LAYOTABOY
    micah
    covington
    yes ISU2014 thats what ive had on the truck since it drove off the lot. I have always want to go taller or at least 2 inches wider
  6. Mar 13, 2013 at 7:34 PM
    Taylor
    Taylor Check out NASA Spec3!
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    265/70/16 is the stock tire size. That's what I've got.
  7. Mar 13, 2013 at 7:41 PM
    toastyjosh
    toastyjosh Well-Known Member
    northern New mexico
    95 dark green taco(sold), 2005 chevy 2500HD duramax
    Stuff some 33x10.50 bfgs under there.
  8. Mar 14, 2013 at 2:16 AM
    Snorkie
    Snorkie JEEP LYFE
    Jeep
    Rubicon
    Prius
    31X10.50-15 same as the 265/70/16
    Keep in mind that every tire is a different size.
  9. Mar 15, 2013 at 3:46 PM
    jdkilroy
    jdkilroy Well-Known Member
    Jon
    Southern NH
    '02 4x4 SR5 Access Cab
    you could get 16" steelies for that rig. I am running 235/85/16's with room to spare on a completely stock 2002. No rubbing issues what-so-ever.
    finslayer83, 1kdrye, copsnok and 4 others like this.
  10. Mar 20, 2013 at 1:10 PM
    LAYOTABOY
    micah
    covington
    how much would steelies run me?
  11. Mar 20, 2013 at 7:10 PM
    jdkilroy
    Jon
    Southern NH
    I got mine for ~ $50.00 each off eBay; they are toyota spares. Great steelies.
  12. Mar 21, 2013 at 1:26 AM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    If you have 15'' rims, why not some 32x11.5's?
    Mr. Mudskipper likes this.
  13. Mar 21, 2013 at 4:56 AM
    jdkilroy
    Jon
    Southern NH
    I believe that with no lift, that OP would have rubbing with 32's that are greater than 8 ~ 9" wide. Could be wrong on that but I'm pretty sure the only reason that I'm getting away with 32's right now (with no lift), is because they are skinnies (235's).
  14. Mar 21, 2013 at 5:15 AM
    TacoMX
    Jonathan
    Deltona, Florida
    I run 32X11.5X15 BFG KM2's w/ about 2.5'' of lift on the front end with zero rubbing
  15. Mar 21, 2013 at 6:34 PM
    jdkilroy
    Jon
    Southern NH
    Does it look like you might get away with 33's with the 2.5" lift ?
    The KM2's tend to run narrow in the tread, I run 33" KM2's on my 4Runner with ~ 3 " of lift and that works really well.
    For some reason, I thought that the OP was looking for biggest tire with no lift but after going back, noticed that he has ~ 2.5".
  16. Mar 22, 2013 at 8:52 PM
    LAYOTABOY
    micah
    covington
    Yes I'm looking for the largest size to run with a 2.5 rough country lift and I might just try to squeeze 33s under her and just see what happens prob not the best idea but hell totals run to the wheels fall off all you gotta do is put another set on and it's back running
  17. Mar 24, 2013 at 11:10 AM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    With enough beating and cutting you can stuff whatever size you want
  18. Mar 24, 2013 at 1:12 PM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    On my 2002 Taco I had the Rough country 2.5 lift as well. with a shackle lift in the rear.
    My stock tires were 265/75R16 that came on the steel wheels.
    With the lift, and ProComp 7089 wheels (4.5" backspacing) I was able to run 285/75/16 with very little rubbing. Only at full turn on certain hill angles.
    The Tires were General Grabber AT2's.
  19. Mar 24, 2013 at 3:53 PM
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    Yea I just got 32x11.50x15 BFG All Terrains in 15x8 pacer bullet holes. I got 1.5" wheels spacers to. I had to trim the bottom plastic bumper and some metal due to rubbing
  20. Mar 24, 2013 at 11:34 PM
    RGosen
    RGosen Well-Known Member
    Christ would now agree, don't get yourself nailed to a tree
    Kamloops B,C CANADA
    2000 toyota tacoma 4x4 2.7
    Cold air intake
    Vary true as I had a set of new 31X10.50-15 M/Ts on that rubbed my mud flaps as well as the plastic on the wheel well when I turned, switched out for another set of new 31X10.50-15 and they dont rub at all.
