Largest tire size on stock 5 lug
Discussion in '5 Lug' started by Taco515, Dec 7, 2010.
  1. Apr 29, 2021 at 6:43 PM
    #181
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    Depends on the year, the rims I posted I have waiting to put on are from the 90-2000s which I've test fit and do fit. If it's past the early 2000s model idk if they fit
    MarMarSux[QUOTED] likes this.
  2. Apr 30, 2021 at 11:06 AM
    #182
    MarMarSux
    MarMarSux Active Member
    Mark
    2000 2.4l 5-lug SR5 Extra Cab Taco
    Dead mice out of blower mod
    Awesome, thanks for your help!
    I got the info I needed and pulled the trigger. I'll post a picture with the new wheels once I get them on!
  3. May 11, 2021 at 6:53 PM
    #183
    MarMarSux
    Mark
    Hey guys, maybe there is a better thread to ask this, but does anyone know how to tell what tire size can fit a given wheel width? For example an 8” wide?
    Another question, is there any reason people do the “black box mod” rather than just remove the entire inner wheel well “cover”(for lack of a better term)?
  4. Sep 20, 2021 at 9:00 PM
    #184
    Iladvised
    Iladvised New Member
    1998 Tacoma ext 2wd manual
    Not very truck savy but trying to research and learn. 98 Tacoma ext if I ran 235/75-15 what time would I need to get? From reading the other post I wouldn't have any rub issues?
    Urkle86 likes this.
  5. Sep 28, 2021 at 9:20 PM
    #185
    Urkle86
    Urkle86 Well-Known Member
    2008 Tacoma 2.7 Base / 2010 4Runner Limited 4x4
    I’m running 31s on 15 inch rims the rubbing I encountered was front end,took the metal boxes behind the front wheel wells and trimmed the plastic lower fender. I also run spacers…. Not sure the size but it made my wheels not rub on the calipers. And yes I know should have gotten 16inch rims. To each their own..
    2008 though not sure this helps. Five luggers RWD FTW
    Daves300 likes this.
  6. Nov 4, 2021 at 6:03 PM
    #186
    kgb4187
    kgb4187 Member
    How much heavier are 17s with AT tires compared to similar 15s? I don't want to make my 2nd gen any slower than it already is.
  7. Nov 15, 2021 at 8:23 AM
    #187
    TwistedKicker22
    TwistedKicker22 Well-Known Member
    Manuel
    2015 Tacoma 2.7 5 Lug
    K&N. Magna Flow
  8. Nov 15, 2021 at 8:26 AM
    #188
    TwistedKicker22
    Manuel
    K&N. Magna Flow
    I got 15x10's Pro Comp 97 Series with 32x11.50r15 tires fit my 5 lug cutting the fenders and removing the plastics from under the fenders without a lift.. It depends what you are willing to do.. I have seen 31's without a lift by just removing the black box
  9. Feb 14, 2022 at 4:29 PM
    #189
    Beny08Taco
    Beny08Taco New Member
    Benito
    2008 Base Tacoma
    235/75/15
  10. Mar 3, 2022 at 1:49 PM
    #190
    Threadbare
    Threadbare Member
    Adam
    nigh-indestructible 2001 Silver Tacoma
    Leer camper shell, tatami mat in the back, bumper hitch, potential 4runner front bumper swap.
    Does this also apply to first gen tacomas? I have been searching all day for this info. (Helping out with a 2001 2.4 base model, and trying to figure out how big to reasonably go.)
    EDIT: It looks like 235/75/r15 is fine for 1st gen. Please correct me if I'm wrong.
  11. Mar 4, 2022 at 6:45 PM
    #191
    4bangertrav
    4bangertrav Member
    2015 2.7l 4wd AT
    Stock
    The same rules apply for a first gen. Owners manual in my 2.4 5lug states 235/75/15 is the max - if you want to go beyond this slightly without lifting you need to unbolt a seemingly useless black box from the inside of your wheel well that's only purpose is to prevent larger tires
  12. Mar 4, 2022 at 6:46 PM
    #192
    4bangertrav
    4bangertrav Member
    2015 2.7l 4wd AT
    Stock
    Does anyone know if a tire shop will install 30s for me if I do the black box mod myself? Specs in their systems will say a max is 235
  13. Sep 3, 2022 at 2:06 PM
    #193
    RodW98
    RodW98 Member
    Brody
    2010 Toyota Tacoma Base
    I got a set of 17s i plan on putting on my 2010 tacoma, stock height. Im trying to find a good size tire to put on the 17s. Does anyone know if 235/65/17 would be good on stock height 5 lug? Thanks
    elephantears09 likes this.
  14. Oct 30, 2022 at 6:26 PM
    #194
    Nazareth7
    Nazareth7 Well-Known Member
    2007 Tacoma 2x4
    That will work for you even by not doing the black box remove. Mine is currently running on 245/75/16s . Perfectly fine 5 lug.
  15. Oct 31, 2022 at 5:56 PM
    #195
    FoxxChoco808
    FoxxChoco808 Member
    Hawaii
    Gen 2 A Taco
    Did you have a lift or black box mod to rock those?
  16. Oct 31, 2022 at 7:57 PM
    #196
    Nazareth7
    2007 Tacoma 2x4
    I removed the black box easy tools. Only took me 3 minutes. And I can fit mine up to 32” tires easy . And no it’s doesn’t have lift it’s stock
    FoxxChoco808[QUOTED] likes this.
  17. Oct 31, 2022 at 7:59 PM
    #197
    FoxxChoco808
    FoxxChoco808 Member
    Hawaii
    Gen 2 A Taco
    thanks for the heads up!
  18. Oct 31, 2022 at 8:01 PM
    #198
    Nazareth7
    2007 Tacoma 2x4
    your speedometer will be funny tho , you’ll be traveling 8mph or more than your speedometer is telling you after those wheels . The faster your going the more different you’ll get.
  19. Jan 2, 2023 at 11:09 AM
    #199
    239_Yoda
    239_Yoda Member
    1999 Tacoma Std Cab Short Bed 2.4L 5spd
    Fr lowered 4.5", Rr Lowered 4", Belltech Shocks/Blocks, Custom Paint, 18" wheels, Custom sound system
    18", 18x8 front, 18x9 rear
    ToughTaco99, RodW98 and jgwilson88 like this.
  20. Feb 12, 2023 at 6:28 PM
    #200
    ToughTaco99
    ToughTaco99 Well-Known Member
    Jerry
    1999 White Tacoma Base
    Exhaust
    255/40/19
