Largest Tire Size Running Bilstein 6112/5160?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rnicholls, Jun 6, 2017.
  1. Jun 6, 2017 at 7:29 PM
    CZ5ANM Taco
    CZ5ANM Taco Well-Known Member
    BC, Canada
    2016 DCSB Manual 35x11.5s
    Front Suspension King Ext Fronts 700# Icon UCA delta joints JD fab spindle gussets All Pro cam tabs DuroBumps Warfab steering sleeves Rear Suspension Old Man Emu leafs -Radflo Ext travel rears Timbrens ubolt flip kit SCS stealth 6 Wheels 35x11.5 Maxxis Razr [ 34.5 x 9.75 on 8.5 rim not on truck] Heavy Stuff Relentless front bumper Smitty 3rd Gen winch Big County Customs skid plates Arc One industries rear HC bumper RCI sliders Misc Arb dual compressor Arb rear locker Pelfreybilt fuse panel tray Cali raised ditch light mounts Cali raised bed stiffeners 5th Gen 4runner LED fog lights Racks Retraxone XR tonneau Yakima load bars Sherpa Roof Rack Camping Smittybilt Tent Dometic CFX50 fridge
    Post #116 sandytaco from thread I linked has a stock trd or. Stock height can run the 255's.
    In anycase fact of the matter is that you are lifting your vehicle therefore rub goes out the window for overall diameter of the tire. (With the assumption you're going up 1.65 inches to 2) Like I said before wheel offset will dictate if it's going to rub or not.
    Trd pro Tacoma rims don't quite push out as far as trd pro 4Runner wheels.
    In anycase you asked for the largest size, myself and a few others have given you the Tallest size. Some people like wider tires. Go for 285's and chances are with what ever wheels you want the rub issue will come up again. Offset is damn important on these trucks if you're mess with height and width. However saws and hammers can fix any rub.
    rnicholls[QUOTED][OP] likes this.
  2. Jun 6, 2017 at 8:18 PM
    rnicholls
    rnicholls [OP] Well-Known Member
    2016 TRD OR DCLB
    Excellent info, thank you!
    TacoStorm likes this.
