Largest tire size with spacers
Discussion in 'Wheels & Tires' started by logcabinwc, Apr 4, 2012.
  1. Apr 4, 2012 at 8:42 PM
    logcabinwc
    logcabinwc [OP] Well-Known Member
    Micah
    SF East Bay
    08 4d 4x4 White V6 TRD
    Old Man Emu 885s with Nitrocharged 90000, Bilstein 5100 in the back with AllPro 3 spring progressive AAL, 16 inch Baja Black 6-spoke alloy wheels, Flow Master exhaust, bed lights, Pioneer HD radio, Uniden CB Radio, K&N Air filter, BAMF Sliders w/kickout, Relentless Aluminum IFS Skid, 24 LED light bar, custom/homebuilt expedition style bed rack and basket combo, and Body Armor rear plate bumper.
    Alright, i apologize if this has been asked an answered. Perhaps my searching skills aren't up to par. But what is the largest tire size that i can fit on 16in rims (specifically the toyota baja size spoke wheels) if i slap on the spidertrax 1.25" spacers. Now, i have the stock suspension on my trd dc 4x4... and I will be getting a set of bfg all terrains.. and i know the largest with stock stuff without lift of spacer is a 265/75/16. But are there larger tires that will still sit on the rims, that won't rub if i get some spacers? Any help would be great!
    Oh and are there any problems associated with spacers that i should know about?
  2. Apr 4, 2012 at 8:46 PM
    hudhawk
    hudhawk #texasforever
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    No. No lift = 265/75-16 or 265/70-17 largest size tire.
  3. Apr 4, 2012 at 8:51 PM
    logcabinwc
    Micah
    SF East Bay
    dang.. to bad. Oh well. thanks for you help! im still temped to get wheel spacers, i think they look pretty good, but i dont know if they look good enough to justify $200 for a set of four...
  4. Apr 4, 2012 at 8:54 PM
    hudhawk
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    If you plan on keeping the stock wheels forever, then the spacers will be worth it to give the truck a slightly wider stance, which looks a lot better IMO.
  5. Apr 4, 2012 at 8:56 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    1.25 spacers are more likely to CAUSE a rub with 265/70/17 or 265/75/16
  6. Apr 4, 2012 at 9:24 PM
    logcabinwc
    Micah
    SF East Bay
    Really? Why is that?
    Maybe just because its been a long day so i cant figure it out in my head but it would seem like the spacer would help just displace the further out..
    unless where it would rub wouldnt be on the inner side of the wheel well but rather the outer edge of the tire hitting the "forward" and "aft" part of the wheel well?
    (hope that made sense...)
  7. Apr 5, 2012 at 6:12 AM
    saaavage
    saaavage Well-Known Member
    Lancaster PA
    05 Sport QuadCab
    K&N air filter Weathertech floor mats to be continued...
    AGREED....I thought this would eliminate teh rubbing if anything.....?1
  8. Apr 5, 2012 at 6:40 AM
    saaavage
    Lancaster PA
    05 Sport QuadCab
    would the same be true for 285/70/17
    OR
    for 275/70/17 (more than likely this one over the first one...?)
  9. Apr 5, 2012 at 7:26 AM
    OZ-T
    Peter North
    British Columbia
    The spacer pushes the tire out , increasing the turning radius and making it more likely to rub at full lock esspecially at the rear of the fender well .
  10. Apr 5, 2012 at 7:27 AM
    OZ-T
    Peter North
    British Columbia
    There is no rubbing with a 265/75/16 or 265/70/17 on stock wheels
  11. Apr 5, 2012 at 7:28 AM
    OZ-T
    Peter North
    British Columbia
    I run 275/70/17 on stock wheels without spacers and have no rub
  12. Apr 5, 2012 at 7:28 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    I would suggest getting the wheel with the rim.
    Your not going to get far buying just a rim.
  13. Apr 5, 2012 at 8:15 AM
    OZ-T
    Peter North
    British Columbia
    Lol
  14. Apr 5, 2012 at 8:18 AM
    XXXX
    sKiP
    05 Prius
    with 8" spacers you could fit these on any Tacoma:confused:
  15. Apr 5, 2012 at 8:28 AM
    JonnyBb
    JonnyBb I have to return some videotapes
    Arkansas
    2010 TRD Sport DC LB 4x4
    Work in progress, but installed so far; 265/70/17 Duratracs, Spidertrax, OME885X coils with OME lean spacer, OME N140S and N182 shocks, Wheeler's 1.5" 3 Leaf Progressive AAL (kept the overload), LR UCAs. TP14 spacers
    100% true. I ran Spidertrax on Sport rims with 265/70/17 for two days. Rubbed like a mofo.
  16. Apr 5, 2012 at 8:36 AM
    cory2212
    cory2212 New Member
    cory
    el paso, tx
    2011 silver trd sport 4 dood
    i have a 2011 trd sport 4door how high do i need to lift it to put 37 in tires on it
  17. Apr 5, 2012 at 8:38 AM
    XXXX
    sKiP
    05 Prius
    Welcome to TW.
    20" of stacked lifts should work and you won't need to trim any fenders
  18. Apr 5, 2012 at 8:43 AM
    OZ-T
    Peter North
    British Columbia
    Boyd , try not to get banned before 1 PST , mkay ?
  19. Apr 5, 2012 at 8:45 AM
    XXXX
    sKiP
    05 Prius
    banned? All my answers are correct and stated in a polite manner. No TW COC has been breached.
  20. Apr 5, 2012 at 8:46 AM
    RJALLDAY702
    RJALLDAY702 U MAD? OH U MAD
    RJ
    Hermosa Beach
    08'
    6" Ruff Country DBL
    :puke:
