largest tire size
Discussion in 'Wheels & Tires' started by takaya49, Jan 22, 2010.
  1. Jan 22, 2010 at 8:28 PM
    takaya49
    takaya49 [OP] Pacific Rim Mushrooms
    Brent
    Vancouver BC
    tacos
    Fox C/O long travel shox with resi, piggy back fox rears, TC UCA's, ICON AAL, Addicts/17 toyo MT, Mr. Marv set up,
    I have a 3" susp lift on regular tires 31"x10.5"x15"
    and wanted to know whats the largest tire size that can fit on that rim?
  2. Jan 22, 2010 at 8:37 PM
    DTacoms
    DTacoms Well-Known Member
    Frisco, Texas
    05 4x4 DC LB BSP
    Can you provide more info of your truck?
  3. Jan 22, 2010 at 8:43 PM
    takaya49
    Brent
    Vancouver BC
    tacos
    1998 ext cab tacoma 3 inch donahoe suspension
    stock 15" rims
  4. Jan 22, 2010 at 8:47 PM
    DTacoms
    Frisco, Texas
    05 4x4 DC LB BSP
    So, it's a 1st gen. You have 3" suspension, so I suppose you can run 33"s. As far tire width, I can't tell as I don't know the stock rim's width.
    Someone with 1st gen should be helping you soon.
  5. Jan 22, 2010 at 8:53 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    Correct, it really depends on the width of your rims.. and maybe even an offset as well?
    A 285/70 is 31.7 inch diameter and 285/75 is 32.8 inch diameter. As you can see, the 2nd number (rim width) makes a difference in the overall dimensions.
    I'd recommend a thinner tire for better MPG and less chance of rubbing.
  6. Jan 24, 2010 at 11:55 AM
    takaya49
    Brent
    Vancouver BC
    tacos
    isnt the second number (75) a percentage of the height ? (distance from the rim to the end of the tread) and 285 the width?
  7. Jan 24, 2010 at 2:31 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Correct.
  8. Jan 24, 2010 at 4:25 PM
    takaya49
    Brent
    Vancouver BC
    tacos
    I'd like to go with the 285/75 15
    anyone know if they might rub a 98 with 3 inch lift on stock rims?
