Largest tire with 2" leveling kit?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NyGuy, Apr 10, 2021.
  1. Apr 10, 2021 at 5:17 AM
    NyGuy
    NyGuy [OP] Member
    Hello All!
    I have a 2012 Tacoma that I’m adding a 2” leveling kit to. What are the largest tires I can put on it? I can’t find this answer anywhere! I currently have the 18” chrome limited wheels in it I’d like to keep.
    Thanks in advance!
  2. Apr 10, 2021 at 5:41 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Sky is the limit, just grab your saw and imagination.
    Turdyota3000, JoshS and NBourque like this.
  3. Apr 10, 2021 at 5:44 AM
    NyGuy
    NyGuy [OP] Member
    I don’t want to change anything outside of maybe trimming a bit of the inner wheel well.
  4. Apr 10, 2021 at 5:59 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Ok, then check the threads here it’s been documented since these trucks have came off the manufacturing line.
    rocklobster2008 likes this.
  5. Apr 10, 2021 at 6:01 AM
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
    Can't find the answer anywhere :rofl:
  6. Apr 10, 2021 at 6:01 AM
    NyGuy
    NyGuy [OP] Member
    Yeah, I’m looking but it’s very easy to find so far. I’ll keep looking.
  7. Apr 10, 2021 at 6:22 AM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    For an 18" wheel I'd assume it's 265/65r18.
  8. Apr 10, 2021 at 6:24 AM
    NyGuy
    NyGuy [OP] Member
    Thanks! I’ll check out some pics to see if that size looks good.
  9. Apr 10, 2021 at 6:25 AM
    Patton250
    Patton250 Bible and Gun Clinger
    Brett
    Tampa Florida
    2021 Tacoma SR5
    It’s like searching for a needle in a haystack. I’m having a difficult time finding my answers so I believe him that he is too.
    Turdyota3000 likes this.
  10. Apr 10, 2021 at 6:27 AM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    A good tip instead of using the sites built-in search function is to use google and search this way: " biggest tire 2nd gen tacoma site:www.tacomaworld.com "
  11. Apr 10, 2021 at 6:28 AM
    ryfox0276
    Montana
    2013 RC 4x4
    wi_taco likes this.
  12. Apr 10, 2021 at 6:33 AM
    Patton250
    Brett
    Tampa Florida
    2021 Tacoma SR5
    I personally have spent several hours searching. I’m pretty much over it at this point. I’ve come to regret even wanting to change the tires on this thing. LOL. I pretty much come to the conclusion after reading so many different opinions on it that pretty much everyone just wings it. If it works yay if not booo and try again.
  13. Apr 10, 2021 at 6:36 AM
    ryfox0276
    Montana
    2013 RC 4x4
    Well there are a lot of factors to consider. The largest is how much you are willing to cut. But the largest tire size that can be run no rub/ without cutting is a 265/75r16, 265/70r17, or as mentioned above, a 265/65r18
    jackn7, vtown, wi_taco and 1 other person like this.
  14. Apr 10, 2021 at 6:39 AM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
  15. Apr 10, 2021 at 6:43 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
  16. Apr 10, 2021 at 6:47 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    18" Chrome wheels.
    Do those look like pole dancer shoes????
    Want guaranteed no trouble?.......then stay with the STOCK tire size. Just shift to a different tire type.
  17. Apr 10, 2021 at 6:48 AM
    Patton250
    Brett
    Tampa Florida
    2021 Tacoma SR5
    OK. So will that 265/75R16 fit on a 7jx16 ET 25 rim in a 2021 SR5 with no clearance problems? No cutting
  18. Apr 10, 2021 at 6:57 AM
    nopinch
    nopinch Active Member
    Broken Arrow , Ok
    This is the 2nd gen section.
    jackn7, Turdyota3000 and wi_taco like this.
  19. Apr 10, 2021 at 7:04 AM
    Patton250
    Brett
    Tampa Florida
    2021 Tacoma SR5
    FMD ‍:facepalm:
  20. Apr 10, 2021 at 7:17 AM
    NyGuy
    NyGuy [OP] Member
    Yup, I’ve come to the same conclusion. I’ll just take it to a tire place and try to figure it out.
    no pole dancer shoes! Stock rims!
    6 gearT444E likes this.
