Largest tires for 3" lift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ian Foulkes, Jan 16, 2025.
  1. Jan 16, 2025 at 11:50 AM
    Ian Foulkes
    Ian Foulkes [OP] New Member
    2023 Tacoma SR
    3 inch leveling kit
    I got a 3 inch leveling kit on a 2023 SR I'm trying to figure out the biggest tires I can run without having to worry about cutting or rubbing.
  2. Jan 16, 2025 at 11:53 AM
    BillF1564
    BillF1564 Well-Known Member
    2021 Tacoma SR
  3. Jan 16, 2025 at 12:24 PM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    A lift doesn't help clear any bigger tires. Soooooo skinny 33's (the same as a stock truck)
    TacoGranny and DavesTaco68 like this.
  4. Jan 16, 2025 at 12:39 PM
    Ian Foulkes
    2023 Tacoma SR
    3 inch leveling kit
    well let me change the question can I run 285/75r16?
  5. Jan 16, 2025 at 12:43 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    You should be expanding your question with the wheel specs
  6. Jan 16, 2025 at 1:03 PM
    TailHook
    TailHook If You’re Good At Something, Never Do It For Free
    Alan
    Southern UT
    2018 TRDOR 4X4, 2007 Sequoia 4X4
    Not sure who made this, but here ya go...
    GTGallop, RIX TUX, jrzjoe and 2 others like this.
  7. Jan 16, 2025 at 1:17 PM
    Ian Foulkes
    2023 Tacoma SR
    3 inch leveling kit
    I'll have to get back to you on that I have no clue and I'm not near the truck, I know it doesn't have an offset/ it's 0
  8. Jan 16, 2025 at 1:26 PM
    airforceb2cc
    Don
    KCMO
    You will have to trim a little and get a near perfect alignment. Or cut the cab mount.
  9. Jan 16, 2025 at 1:30 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Somebody needs to update that, some of the offsets have been wrong since it was created and still haven’t been updated.
    SGJarrod, Ian Foulkes[OP] and Vlady like this.
  10. Jan 16, 2025 at 1:46 PM
    lit_taco4x4
    lit_taco4x4 IG and YT: @2a_crawlcamper
    Louie
    2018 Tacoma TRD Pro
    JD fab LT, Archive and Deavers, King shocks, Dual locked, Dual T case, Tundra steering rack, 39’s
    you can fit up to 40 inches maybe even 42 inches. Now driving it, that’s a different story
    SloTaco13, RIX TUX and BillF1564 like this.
  11. Jan 16, 2025 at 2:46 PM
    TailHook
    Alan
    Southern UT
    Sounds like you just volunteered...
  12. Jan 16, 2025 at 2:50 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Sorry to hear that (if it's a spacer lift)... Anywho if you stick to stock rims, you will have less chance of rubbing with those 285's. Once you change the offset, than anything goes.
    71tattooguy likes this.
  13. Jan 16, 2025 at 3:20 PM
    Vlady
    Issy, WA
    Tocamo[QUOTED] likes this.
  14. Jan 16, 2025 at 7:15 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Yup, the chance is always there. It really is hit or miss with each Taco.
  15. Jan 16, 2025 at 8:05 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    more info needed......
    why a lift?.......
    why bigger tires needed?......
  16. Jan 16, 2025 at 8:17 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    if he has a spacer lift then it technically would help as its limiting up travel.
  17. Jan 16, 2025 at 8:18 PM
    devinzz1
    devin
    2023 aclb trd or mt
    those fit stock with the right offset. around +10. stock wheel with a 3/4" spacer will achieve this.
  18. Jan 17, 2025 at 7:10 AM
    airforceb2cc
    Don
    KCMO
    Even with a 1.5" spacer (3" at the hub) lift, the centerline of the hub will still pass the cab mount at full stuff (bottomed out shock) so the lift will help from the tire hitting the upper inner fender, however it will still hit the cab mount first and rub. But yes, fully stuffing a spacer lifted truck without putting a bump stop spacer on will use the shock as the bump stop and destroy the shock. So tire rubbing is the least of anyone's concern...haha
    Tocamo likes this.
  19. Jan 17, 2025 at 8:22 PM
    dryheat
    dryheat Well-Known Member
    Hold on he's not near the truck
  20. Jan 17, 2025 at 9:07 PM
    Willy Lump Lump
    Willy Lump Lump Well-Known Member
    21’ dcsbmt
    This and that
    Prolly he’s in Florida they get lots of snow, I hear everyone’s getting new tires….
    RIX TUX[QUOTED] likes this.
