Largest Tires On 1996 Stock Taco 4x4
Discussion in '1st Gen. Tacomas (1995-2004)' started by Aquasonic, Feb 25, 2013.
  1. Feb 25, 2013 at 10:55 PM
    Aquasonic
    Aquasonic [OP] Active Member
    Near Columbus Georgia
    1996 LX 4x4 2.7L4
    I'm trying to track down answers specific to my 1996 Tacoma before I shell out a fortune on new tires. I've read most of the threads, but don't see info on the 1996.
    I bought my son the 1996 for his 16th Birthday a couple of weeks ago. It has the stock 15" steel wheels with the P225/75 R15 tires.
    I picked up a set of 16x7 alloys from a 2003 tonight. Here are my questions:
    1. I've heard I can run the 265/75/16 tires with the stock suspension. Any opinions?
    2. What about the 265/70/16 tires? Better or worse?
    3. I understand that for strictly on-road driving the "C" rating is fine?
    4. Is that a "P"265 or "LT"265 that I would need?
    5. Last question... I have the 2.7L 5-Speed. According to the door sticker, it has the 3.58 gears. I don't know how accurate that sticker is since it runs 2400 rpm's @ 65 mph and has plenty of pep. Would those gears and those tires turn this Taco into a dog?
  2. Feb 25, 2013 at 11:00 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
  3. Feb 26, 2013 at 7:03 AM
    Aquasonic
    1996 LX 4x4 2.7L4
    Thanks for the chart. It's a little different from the one I found in another thread.
    Door code is B02A, which according to this chart is 3.73, which makes me feel a little better.
    I went with the 16" alloy wheels for looks and because down here the 31x10.5x15 tires run about $70 more than the 265/75/16.
  4. Feb 26, 2013 at 8:53 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Wow..never thought id hear that an r16 tire cost lest then an r15..
    with 3.73s a 31'' tire will bog it down just a bit. Im shocked honestly to see 3.73 in a 4x4.
  5. Feb 26, 2013 at 9:31 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    X2, 1 inch bigger rim would have cost me like 30 more a tire or something.
    And you have the 3.73?? That's weird. I thought that gear ratio was 2nd gen territory. I have the 2.7 x cab 4x4 with 4.56, not sure why yours is so different for just being a 5 spd. And the biggest tire you can fit with everything is going to be a 32. The p and lt are for passenger and light truck respectively, so go with lt.
  6. Feb 26, 2013 at 10:46 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    3.73s usually came in prerunners. Most 5 speed 4 bangers i have seen have either 4.10s or 4.30s.
    Just goes to show how weird Toyota can be..one of the many oddities they do.
  7. Feb 26, 2013 at 11:55 AM
    z71bowhunter
    z71bowhunter Well-Known Member
    Randy
    Temple,Ga
    96 Tacoma Ex-Cab 4x4
    What about a automatic 2.7 in a 96 4x4 ??? i got stock 225 75 15 tires and im turning about 2700rpm @ 70mph
  8. Feb 27, 2013 at 8:29 AM
    Aquasonic
    1996 LX 4x4 2.7L4
    That's what I'm turning at 70 mph also. I hope my sticker is wrong??? I'm turning about the same rpm's as I did years ago in my 1986 4Runner. It had 4.56 gears.
    I was told yesterday by my tire guy that I needed the "P" instead of the "LT" since the "LT" was a 10-ply and wasn't necessary on my Tacoma. I assume the "P" weighs less also?
  9. Feb 27, 2013 at 8:38 AM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    I ran 265/75/16's on my 96 when it was stock. Had very minimal rubbing against the frame at full turn. If you want the largest tire possible, these would be it.
  10. Feb 27, 2013 at 6:47 PM
    Aquasonic
    1996 LX 4x4 2.7L4
    Thanks for the help with my tire and wheel questions. I got the 265/75/R16's mounted today and my son loves them. I actually think I could have gone a little larger:eek:. There was only a slight loss of power. Now to track down a more accurate speedometer gear...lol.
  11. Feb 27, 2013 at 7:02 PM
    PcBuilder14
    Brent
    Nor Cal
    Read this...
  12. Feb 28, 2013 at 7:06 AM
    Aquasonic
    1996 LX 4x4 2.7L4
    Thanks. I saw that and have it bookmarked even though nothing comes up when I punched in those numbers on that link.
    My local Dealer would only sell me the gear that "Came in my vehicle" according to VIN. I'll try a few other dealers after I see what gear is already in there and which way I can go.
    I swapped the stock gauge cluster for one with a tach and set the speedometer needle to where it matched my GPS speed 100% with the old tires.
    I may try the same again with the new tires before tracking down a gear.
    I had to play around with the fuel gauge needle to get it correct and I missed by 1/4 tank...I ran out of gas...almost...with the needle showing 1/4 tank. That's a simple fix. Glad I had extra gas in the back.
    Do any of you have a low fuel factory light? I was testing to see when my light came on but apparently this 96' doesn't have one.:( I plan to re-set the needle to the bottom of the last mark above the "E" so my son knows when he is out.
  13. Feb 28, 2013 at 9:05 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    96s don't have the fuel light. Don't set it at the 3/4 mark tho lol
    Hopefully your son is just smart enough to fill the truck when it needs it. That shouldn't really be a problem id imagine.
    very odd your dealer won't sell you the gear..thats stupid. You'd think they would sell you what ever ya want..haha
    your cluster doesn't have a tach? it should...
  14. Feb 28, 2013 at 9:15 AM
    PcBuilder14
    Brent
    Nor Cal
    The 2.7's didn't have one. Mine didn't...
  15. Feb 28, 2013 at 1:46 PM
    oldblue1968chevy
    oldblue1968chevy Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
    mine does (99)?
  16. Feb 28, 2013 at 1:50 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea my buddies has one too...
    Freaking Toyota..doing weird shit all the time haha
  17. Feb 28, 2013 at 1:54 PM
    paulbunyan
    paulbunyan Well-Known Member
    the tac in a 96 is an optional upgrade. I have one in my 96
  18. Feb 28, 2013 at 1:55 PM
    01GREENTACO
    01GREENTACO Not all who wander are lost
    Germantown, TN
    01 4WD
    Lost track many, many mods ago.
    Mine didn't have one at first. (2001 4cyl 5spd 4WD) but I bought one off a buddy who totaled his 2.7 TRD. Simple plug and play.
    And also my truck originally had 3.90 before I swapped out my factory rear end with a TRD one with a locker. Now I run 4:10
  19. Feb 28, 2013 at 2:02 PM
    mmcmahan2206
    mmcmahan2206 Well-Known Member
    McCall, Idaho
    00 Tacoma SR5 TRD 3.4L
    6" FabTech suspension 3" body lift, 35x12.50R15 BFG AT T/A KO tires, Mickey Thompson Sidebiter wheels, 4:88 front and rear gears, e-locker, "grey wire mod," Hella driving lights retroed to 55w 8000K HIDs, custom grill, Downey chrome air intake w/ AEM filter, AirAid throttle body spacer, Flowmaster exhaust, Alpine audio w/ 12" RF sub, racing bucket seats, black powdercoated toolbox, smoked out black taillights, black headlamps and corners, red LED interior lights, sway bar removed, rear shock relocation, u-bolt flip mod, 01 center console, Relentless Fab front plate bumper, LED fog lights.
    On my 1st Tacoma, which was a 1996, I put LT265/70r17 6 ply BFGs on that had no rubbing problems and it filled the wheelwell very well!
  20. Feb 28, 2013 at 6:08 PM
    PcBuilder14
    Brent
    Nor Cal
    I'm pretty sure it was only 95-97 2.7's that didn't have tachs.
