Largest tires on First gen Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tronracer, Dec 4, 2019.
  1. Dec 4, 2019 at 11:57 AM
    Tronracer
    Tronracer [OP] Well-Known Member
    Marc
    Sewell, NJ
    2015 Tacoma Off-road
    Toytec lift
    Hi all,
    What is the largest tire I could fit on a 15 inch rim on a 1998 stock SR5 without lifting it?
    Thanks!!
  2. Dec 4, 2019 at 11:59 AM
    Clearwater Bill
    Billy
    Largo Florida
  3. Dec 4, 2019 at 12:06 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    How much cutting and welding are you willing to do? You could fit 35s
  4. Dec 4, 2019 at 12:07 PM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    I think he's wanting to keep it stock if he doesn't even want to life it.
    Tronracer[OP] likes this.
  5. Dec 4, 2019 at 12:08 PM
    Wulf
    rock raisin
    Maybe, never hurts to ask
    Thunder Fist[QUOTED] likes this.
  6. Dec 4, 2019 at 12:26 PM
    Tronracer
    Marc
    Sewell, NJ
    Toytec lift
  7. Dec 4, 2019 at 12:41 PM
    Clearwater Bill
    Billy
    Largo Florida
    Use the tire calculator linked in the thread to determine the 15" equivalent.
    LukeCC likes this.
  8. Dec 4, 2019 at 12:47 PM
    05prerun82
    05prerun82 Your local friendly Taco Mule TTC#0202
    Brandon
    Fredericksburg
    2006 aclb prerun
    Memphis sound system volant cold air intake
    How much cutting do you want to do
  9. Dec 4, 2019 at 12:52 PM
    eon_blue
    Azusa, CA
    You can fit 32s and not rub depending on your wheel backspacing. 33s will require pinch weld trimming at least and probably some lift.
  10. Dec 4, 2019 at 12:53 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Fotey fo's.
    Gunshot-6A likes this.
  11. Dec 4, 2019 at 1:06 PM
    02hilux
    Planet: EARTH
    4dz
  12. Dec 4, 2019 at 1:38 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    The largest size tire you can get with no rubbing and no other modifications is printed on your door sticker. i.e. whatever size it came with.
    My 265/75r16's (*barely* larger than stock, a ~31.9") on stock rims rubbed (the frame) even with more than 1" or lift.
    Also keep in mind that most lifts don't change IF a tire will rub, but WHEN it rubs.
    Put on bigger tires without other modifications and you'll more than likely rub the tires somewhere. Where and how much depends on a lot of factors. The rub I had certainly didn't make it undriveable, but it was pretty annoying in parking lots.
    jeremy5000 and Hamer95USA like this.
  13. Dec 5, 2019 at 5:48 AM
    Tronracer
    Marc
    Sewell, NJ
    Toytec lift
    What do you mean, "life it"?
  14. Dec 5, 2019 at 6:16 AM
    Thunder Fist
    David
    Birmingham, AL
    Like, so many.
    Typo. I meant "lift" it.
  15. Dec 5, 2019 at 8:23 AM
    Tronracer
    Marc
    Sewell, NJ
    Toytec lift
    OMG. Sorry about that. Of course that's what you meant.
  16. Dec 5, 2019 at 9:25 AM
    Clearwater Bill
    Billy
    Largo Florida
    You're one of our sharper knives. So is a first gen truism or something?
    Because it doesn't appear to always apply to 2nd and 3rd gen
  17. Dec 5, 2019 at 9:31 AM
    jbrandt
    Justin
    Correlation or causation. Not sure which, lol...
    cornbread_wy likes this.
  18. Dec 5, 2019 at 1:01 PM
    Tronracer
    Marc
    Sewell, NJ
    Toytec lift
    I found this site... Looks like the largest I could fit on the stock setup is the current size 31/10.5/15
  19. Dec 5, 2019 at 1:15 PM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    Dis man :sawzall::welder::itllbuffout:
  20. Dec 5, 2019 at 1:46 PM
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    As the other mentioned, you can't go much bigger than stock. People lift to avoid the rubbing but I don't like that band-aid, if you are actually off-roading then its going to get really bad.
    I'm on 31s with spacers (Tundra brakes) and had to do the pinch weld mod. I'm barely lifted though- my Icons are at the Icon factory pre-load + weight of my front bumper- the ride is great though and the droop range feels awesome when pushing it. I do want so more lift/compression room but I won't go much higher to retain a good amount of droop. There is still some minor rubbing so I'm going to have to do the tub mod (cut into the cabin, make a piece of metal plate, weld in).
    There are people here that will fit big tires and big lifts and make that sound like a fix, but IMO if you can't cycle your suspension while turning, its still a fail.
