Largest tires with a 2” lift and 16” Ray 10
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RiverTaco1000, Apr 15, 2019.
  1. Apr 15, 2019 at 7:11 AM
    RiverTaco1000
    RiverTaco1000 [OP] Member
    2016 Blazing Blue TRD OR
    Stock
    What’s the largest tires that’ll fit a 2” lift with no rubbing?
    I was thinking a 285/70/16 Wild Peak would look nice
  2. Apr 15, 2019 at 7:13 AM
    Longboard1110
    Longboard1110 ...................
    San Jose
    A few things
    265/75/16 with no rubbing
  3. Apr 15, 2019 at 7:18 AM
    @T.A.C.O.M.A
    @T.A.C.O.M.A Well-Known Member
    Los Angeles
    295/75r16. Run it.
    jimbro likes this.
  4. Apr 15, 2019 at 7:18 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    315/75/16
    evansdmax and @T.A.C.O.M.A like this.
  5. Apr 15, 2019 at 7:19 AM
    Apollo14
    Apollo14 EEF Brand Ambassador
    Jonathan
    Vail, CO
    2018 Cement Taco TRDOR DCSB
    Lol. He’s just gonna have to tub the bed and do a little inner fender well trimming up front.
    285s are too wide. You might be able to get away with 275s depending on tire.
  6. Apr 15, 2019 at 9:13 AM
    RiverTaco1000
    Stock
    Think I can get away with 275s in Wild Peak AT3’s or stick with 265s to be safe?
  7. Apr 15, 2019 at 12:03 PM
    jimbro
    jimbro Well-Known Member
    Jim
    Manoa, Hawaii
    2024 Bronze Oxide Tacoma Trailhunter
    Leitner rack
    265s are the largest tire proven to fit without any rubbing or trimming.
  8. Apr 15, 2019 at 12:09 PM
    Solenya
    Solenya Well-Known Member
    Southern California
    2018 SSM Tacoma TRD Sport 4x4 DCSB (TOTALED OCT 2023)
    265/75r16s without rubbing. I ran those in a Falken Wildpeaks in stock Sport suspension with no rubbing whatsoever. Ran 16x8 SCS F5s with a 3.5BS -25 offset.
    Currently on 285/75r16s BFG KO2s on close to a 3 inch lift. Same wheel specs. I did CMC and have trimmed/heat gunned some sections of my fender. Minimum rubbing still. Best bet is to go 265 if you don’t want rubbing or to deal with trimming.
  9. Apr 15, 2019 at 12:13 PM
    Apollo14
    Jonathan
    Vail, CO
    I still think 265 is plenty wide for 95% of wheeling and still looks beefy
    m603holden and Gunshot-6A like this.
  10. Apr 15, 2019 at 12:31 PM
    RiverTaco1000
    Stock
    Yeah man, don’t want to get crazy with it. Just a nice tasteful yet aggressive look
  11. Apr 15, 2019 at 12:42 PM
    TacoJohn4x4
    TacoJohn4x4 Captain Save-A-Ho
    Central Valley
    2002 Tacoma DC 4x4
    35” YOU CAN DO IT!
    coopcooper and @T.A.C.O.M.A like this.
  12. Apr 15, 2019 at 1:10 PM
    coopcooper
    alberta canada
    You could also join the skinny tire gang and run 255/85/16s
  13. Apr 15, 2019 at 1:15 PM
    evansdmax
    evansdmax Well-Known Member
    Evan
    Western NC
    2017 TRD OR BBP 6 SPEED MT
    Just ordered my 255/85/16 masterctaft courser cxt’s going to get them tomorrow!!! Had 255 on my 2nd gen and loved them!! I had the coopers then just gonna try these mastercrafts this time
  14. Apr 15, 2019 at 1:21 PM
    CitationJeff
    CitationJeff Active Member
    Jeff
    2019 TRD OR SB
    I am getting 255/80/17's tomorrow, Toyo AT II's. Let me know how they work for you!!
    evansdmax[QUOTED] likes this.
  15. Apr 15, 2019 at 2:18 PM
    evansdmax
    Evan
    Western NC
    Will do
  16. Apr 15, 2019 at 2:21 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    265/75R16 ST Maxx on a 2.5ish lift and I rub like a mofo on the plastic liners in front when I turn to full lock or full stuff. The Maxxs are like .5 inches bigger than a KO2 in that same size.
    BassAckwards likes this.
  17. Apr 15, 2019 at 3:25 PM
    tacomarin
    tacomarin ig: @travelswithchubbs
    Bay Area
    2018 DCLB TRD OR
    Prinsu Cab and Top Rack VO Drifter LED Interior, License Plate, and Reverse Lights Huskyliner Weather Beater floor mats Salex Center Console Organizers 35% Front/15% Rear Tint Debadged and De-stickered Anytime Front and Rear Cameras Brute force front bumper BAMF HC Dual swing out 285/75r17 BFG KO2 Front: ADS 2.5, EXT, RR, Clickers Rear: OME Dakar HD, ADS 2.5, EXT, RR, Clickers Stainless steel brake lines (+4 in rear) Wheeler's Offroad Superbumps Front and Rear Wheeler's Offroad U-bolt flip ECGS CV Axle Bushing SCS Stealth 6 17x8.5 wheels, matte dark bronze
    Yup, same except only when turning and stuffing. You can run 265/75/16 on stock wheels and not rub, but if you start moving your wheels outboard like the Ray 10's do then even they will rub on the liners. Hell, stock tires would probably rub too.
  18. Apr 15, 2019 at 4:18 PM
    Apollo14
    Jonathan
    Vail, CO
    You probably added an extra inch or so by going with 75 profile size. Stock wheels are 265/70R16s. A 75 adds about 13.25mm (about .52in) all around to the side wall.
  19. Apr 15, 2019 at 6:20 PM
    trackdaybro
    trackdaybro Well-Known Member
    You didn’t rub with 265/75/16 on 3.5 BS F5s and stock suspension? Did you wheel with that setup? That’s what I’d like to go for but don’t want to trim just for 265s.
  20. Apr 15, 2019 at 7:26 PM
    TacoJohn4x4
    Central Valley
    2002 Tacoma DC 4x4
    Have you tried to get an alignment. They might be able to adjust your upper if not your lower caster for better clearance.
    Gunshot-6A[QUOTED] likes this.
