Largest tires with bilstein 5100's set at 2.5"
Discussion in 'Wheels & Tires' started by Penz83, Dec 1, 2012.
  1. Dec 5, 2012 at 8:51 AM
    Penz83
    Penz83 [OP] Well-Known Member
    05 Tacoma pre runner dbcb short bed
    The more I read I don't think I will like the result of pre loading the stock springs to 2.5". I have seen some pictures of trucks with the 5100's set at 1.75" and they look ok but it's really not that much difference than stock. So I think to get a little more lift and still have a good ride I'm going to look into springs as well. Looks like 5100's set at .85" and eibach 1.6" lift springs is the way to go. That with a 1.5" aal in rear and I think I will be set.
  2. Dec 5, 2012 at 9:00 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    This was 18x9s with 285/60/18s with 2.5 up front/1.5 AAL out back with mud flaps removed and no frame chop. Had no rubbing. 31.5" OD on those tires. Not sure what bs the wheels had but edge of tire was 1.5 or 2" past wheel flares...........
  3. Dec 5, 2012 at 9:25 AM
    Penz83
    Looks sweet! That lift looks perfect, exactly what I am trying to achieve. I like the looks of the 285's as well, always have... I can do it with correct back spacing and or trimming for clearance, but the more I think about it 265's are more economical for what I need... But I like the look of the 285's... Is it worth it! Such hard decisions in life...
  4. Dec 5, 2012 at 10:00 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Yeah, I stayed with 265/70/16s this time with TRD Blisteins, .5" lift up front and no lift out back. 4.5 bs, -12 offset, 16x8 wheels. No trimming, no rubbing, cheaper tires & better mpg. Both were/are 2.7l 5 spd prerunners, just the 05 was access cab & the 08 is reg cab............
  5. Dec 6, 2012 at 10:24 AM
    Penz83
    I'm really stuck between the duratracs and the grabber at2's. I like the look I the duratracs but in size 265 they look roundish. The grabber at2's have more of a square look, and are more affordable, and have a better warranty... They both get good overall reviews so I can't go wrong either way. Anyone had both have any input?
  6. Dec 6, 2012 at 11:46 AM
    david2011sr5
    david2011sr5 Well-Known Member
    take a guess
    MA/VT
    2011 SR5 4x4
    afe pro dry, weather tech floor liners,5100's on all four corners@ 0, eibach 620 coils. toytec 3/4" spacer driver/s & passenger/s, rear spring tsb w/toytec 1" blocks, 4runner sport wheels, in channel vent visors, 1.25 spidertrax wheel spacers on the front, Wet Okole's, smity tow hook.
    Like someone said earlier you can run 275/70/17 with no issues that's what I'm running. Mine=32.4". My next set will be 255/80/17=33" which is another tire you could run without having issues. I saw you mention getting eibachs do it they are a great coil and paired with 5100's=awesome ride/handling.
  7. Dec 6, 2012 at 12:26 PM
    Penz83
    Yeah I'm going with the eibach springs for sure. I thought about 275's but neither the duratrac or the grabber at2 are available in 275/17. I want a 17" wheel so I will go with what's available for 17's. Thanks for the input on the springs, can't wait to get it all installed.
  8. Dec 6, 2012 at 7:09 PM
    david2011sr5
    take a guess
    MA/VT
    2011 SR5 4x4
    Post up some pics when you get everything installed
  9. Dec 6, 2012 at 7:31 PM
    Penz83
    For sure. I got a long list of stuff I want to do, just need the cash haha.
  10. Dec 6, 2012 at 9:58 PM
    david2011sr5
    take a guess
    MA/VT
    2011 SR5 4x4
    I hear ya. slowly but surely.
  11. Dec 7, 2012 at 2:23 PM
    Penz83
    Do you have any alignment issues at 2.5" of lift in the front? The more I read it's on the border line of needing different upper control arms...
  12. Dec 7, 2012 at 5:40 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I had to get LR UCAs to get the caster back at 2.5. Drove all twitchy until caster was added. 2-3 seems to be the sweet spot. mine was set at 2.7 and drove great.
  13. Dec 7, 2012 at 6:25 PM
    Penz83
    Sounds like I really should not go over 1.75" without uca's... Ok thanks for the input!
  14. Dec 7, 2012 at 8:01 PM
    david2011sr5
    take a guess
    MA/VT
    2011 SR5 4x4
    NO UCA's needed. Not exactly sure on how much lift I ended up with, but I'm at 23" from hub to fender. Thats with 5100's@0, eibachs 620's and toytec .5"spacer. the toytec spacer =.75" of lift. Personally I think your be fine if you keep it at 2.5 or under.
  15. Dec 7, 2012 at 9:02 PM
    #35
    andrew8404
    andrew8404 Well-Known Member
    ANDREW
    Albuquerque, NM
    17 DCSB TRD OR 4x4 (Sold) 19 Ford Ranger Sport XLT 4x4
    I'm at 2.5 with no issues and in spec.
  16. Dec 8, 2012 at 7:07 PM
    #36
    Penz83
    Maybe I'll just go with 2.5 and see if I have any issues, if I do I can always lower it thanks to the 5100's.
  17. Dec 8, 2012 at 7:22 PM
    #37
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    At 2.5" lift in the front on stock uca's, my alignment was technically" within specification" . I was very happy about this until I drove at highway speeds and I realized my truck was prone to wandering. You will definitely lose caster and increase your camber when you run a 2.5" lift . More adjustable uca's will counter this if set corrrectly. Needless to say, I did change out my uca's.
  18. Dec 10, 2012 at 8:37 AM
    #38
    Penz83
    What is a good uca for 2.5" lift?
  19. Dec 10, 2012 at 9:02 AM
    #39
    magnetic11
    magnetic11 Well-Known Member
    "some nuke plant"
    11 trd sport
    Fab fours front and rear bumpers, B.A.M.F. weld on rock sliders, softopper, removed mud flaps and D-Badged everything. Icon 2.5 Extended Travel coil-overs, Total Chaos upppers, 2.0 Icon extended travel shocks with the resi's and Dekar Leaf packs.
    i rub with 255/75/17 and no cutting. i know that i still need to adjust the front up a little more and it should b fine.
  20. Dec 10, 2012 at 9:07 AM
    #40
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I tried to warn them about the loss of caster which will leave the truck "technically" within spec but drive like shit on uneven surfaces, wander in grooves on frwy & windy situations. Lack of caster won't wear the tires but will wear on your last nerve as far as being annoying as hell.........
    LR are the most budget priced if you don't want higher priced ones with uniball ball joints. Those have better articulation for offroad but more prone to the elements of offroading fouling them if not maintenanced regularly. The LR's have regular ball joints with a boot on them for longevity but give up about an inch of articulation.
